Текущее время: 28 ноя 2026, 04:32
 Заголовок сообщения: Sarphie Radeon RX 560 Pulse 4GB (works only 3GB)
СообщениеДобавлено: 26 июл 2018, 21:04
I have problem with Radeon RX 560 Pulse 4GB. There was burned a fuse (pci express with letter R). I have checked short circuit using with multimeter but there wasn't "beeping". Moreover I tried check it again using power supply (1V and 4A) but nothing goes hot.
The graphic card work (computer start). I have tested it in furmark and in 3dmark. Futhermore i teseted it in cryptomining (there was about 8mh/s for eth, this card have about 10mh/s). That was very strange for me so I have checked how many memory is use in GPU_Z. There is only 3GB.
I feel that one of memory chip is broken but I would to be sure. I can't find the same chip in the stock. The memory is Micron RT8880C.
So there is my question:
Is the memory chip is broken?
Is there are any method to veryfy which memory is broken?
What it can be if not memory chip and how can I do to check it?
I made some photos
 Заголовок сообщения: Re: Sarphie Radeon RX 560 Pulse 4GB (works only 3GB)
СообщениеДобавлено: 27 июл 2018, 07:41
Micchaleq писал(а):
There is only 3GB.
Windows 7 have a bug with some radeon cards/drivers. Try reinstall win 7 or install win 10.
СообщениеДобавлено: 27 июл 2018, 12:14
I have got a windows 10 already. GPU-Z shows that graphic card has got 4gb memory but after run for example mining GPU-z show that 3GB is used only. It is problem with graphics cart but I wonder if it could be the fault of the memory controller (if not memory chip).
СообщениеДобавлено: 27 июл 2018, 12:19
Try flash bios and reinstall os, looks like software errors.
В этой теме нет новых непрочитанных сообщений. apphire Radeon RX 560 Pulse 4Gb OC
apach71
1902
05 окт 2022, 18:32
SXRON Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. sapphire pulse radeon rx 560 g4 нет картинки через dvi
Digidoid
26 май 2021, 14:25
В этой теме нет новых непрочитанных сообщений. Gainward RTX3070 only works with AMD Mainboard/CPU
Dance0fArrows
2185
09 сен 2023, 23:30
Opacky Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus UM5401QA - OLED191W (UM5401QAB R3.1) NOT negociating 20V and works only on battery
DanqeR
566
21 июл 2026, 12:11
DanqeR Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sapphire Pulse Radeon RX560 4Gb нет изо
gosha_z
10 мар 2020, 15:26
Сейчас этот форум просматривают: Yandex [BOT] и гости: 28
