Текущее время: 14 ноя 2026, 08:18
 Заголовок сообщения: Toshiba Portégé Z30t-C (fux3sy2 A4149A) no image, boot hangs.
СообщениеДобавлено: 19 сен 2018, 01:10
Toshiba Portégé Z30t-C fux3sy2 A4149A boot hangs.
Hi I have the above laptop with a bios related issue. ( I think)
The pch-bios had been reprogrammed with different dumps and no success.
I want to reprogram the SMSC MEC1632-AUE, but there is no schematic nor boardview.
Anyone knows witch points from pcb should I connect to svod programmer?
 Заголовок сообщения: Re: Toshiba Portégé Z30t-C (fux3sy2 A4149A) no image, boot hangs.
СообщениеДобавлено: 19 сен 2018, 08:37
Some more info: there are pulses on pch-bios, and also in pin 30 of both ddr3 slots, there are pulses. (DDR3_DRAMRST#)
Is it not rare that DDR3_DRAMRST# signal be a burst of pulses?
СообщениеДобавлено: 20 сен 2018, 19:36
https://www.youtube.com/watch?v=6b4-hei ... 3&hl=en_US
This video from Sergey Vertyanov shows how to read the SMSC MEC1632, but seems that there is some problem. ( I can not understand really)
I can see the datasheet for the SMSC MEC1632. ( I'm googled it but have no luck)
Can someone share this datasheet?
Can someone explain the problem to read the SMSC MEC1632 shown in this video?
Regards
СообщениеДобавлено: 20 сен 2018, 20:54
andromedax
in MEC1632 JTAG locked.
No DUMP, no solution ...
Программатор SUCCESSOR/JIG V2/3.
Пост карты DDR234/NGFF_GoWin/KFCT_BIG
СообщениеДобавлено: 21 сен 2018, 00:28
Vertyanov_SS писал(а):
andromedax
Then solution is change MEC1632 for a new one.
I wonder if the new chip is already programmed for this motherboard and if it is possible to upgrade its firmware via windows bios update. (and corrupted if something goes wrong)
If someone can share more information it would be great.
Regards.
СообщениеДобавлено: 21 сен 2018, 07:43
andromedax
If everything was so simple .... ))
СообщениеДобавлено: 21 сен 2018, 11:59
andromedax
Yea, you are right, manufactures don't make "things" easy for technicians.
What is worse, doesn't seem this are going to be better.
Thanks for your help.
СообщениеДобавлено: 21 сен 2018, 12:07
It is necessary to clearly know that the fault is associated with this chip.
You can buy a faulty card and remove it.
This is still the only reasonable option.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Portege Z30-C1320 (FUX3SY2 A4149A) снять пароль
в форуме Toshiba
clock
28 ноя 2018, 23:10
clock Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba portege m500 PPM50L (portege m500) ОЗУ 667МГЦ 2 Гб не запускается Винда
в форуме Toshiba
brotherm
01 ноя 2019, 10:20
Azazehl Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. toshiba satellite z30-c-10k (fux3sy2) нужен дамп биос
в форуме Toshiba
Sergey75
16 июл 2017, 22:21
Sergey75 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Portege 7140CT (Portege 7000) Батарея BIOS и два HDD
в форуме Toshiba
UMVolt
07 апр 2025, 21:58
UMVolt Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv plasma sony KDL-46ex725 image with black stripe at the top of the image
eletmoraes
06 сен 2017, 16:25
eletmoraes Перейти к последнему сообщению
