Текущее время: 11 ноя 2026, 05:39
 Заголовок сообщения: HGST Password Reset?
СообщениеДобавлено: 31 дек 2018, 01:48
Hi.
I have a bunch of
HGST Z7K500-500 / HTS725050A7E630
Is it somewhat possible to unlock (date can be ignored/erased) and reuse the drives without special Hardware like PC-3000?
I'm more or less searching for a Tool like WDMarvel or so.
I also have serial interface programmer I could use, but I would need some real guide.
Even if a bunch of disk get's destroyed it doesn't matter, currently they are just laying around.
 Заголовок сообщения: Re: HGST Password Reset?
СообщениеДобавлено: 31 дек 2018, 02:51
Try to find the factory master password and use a program like Victoria to unlock it.
if it doesn't work out and the master password has been changed, then it is almost impossible without PC-3000.
СообщениеДобавлено: 31 дек 2018, 04:00
Have the generic "Masterpasswords" ever worked? I tested WDCWDC... on WD and it never worked and also on other drives like this HGST (with the generic "masterpassword", if there is one)
I read that ZU and other Tools won't work with HGST with Marvel Controller. I thought maybe I missed something and someone has an idea.
I think the Master is changed as they were used in ThinkPads, they are from kind of a whole sale. I have 1-2 HDDs with User-Password but I can't remove the Password without the Master, only change it.
PC-3000 vs. like 10 drives aren't worth the effort/money. They are all "just" 500GB.
СообщениеДобавлено: 31 дек 2018, 04:11
If you were in my city, I could help you, but you are in UK. I have a PC-3000.
Try to find a Data Recovery Service in your city
СообщениеДобавлено: 31 дек 2018, 07:32
really thank you.
I have seen vids about this model and pc-3000 but I think the time is not worth the money on this 500gb drives.
with a tool like wd marvel I would be fine but with all the tasks for this model with pc-3000 I think it outweights any benefit.
СообщениеДобавлено: 31 дек 2018, 15:24
you can try that
https://bios-pw.org/
The hard disk drive must be installed in the laptop on which the password was set.
СообщениеДобавлено: 31 дек 2018, 18:21
I know the site, but all disks are from thinkpads t440
СообщениеДобавлено: 04 янв 2019, 23:33
If somebody is interessted in buying this drives (only within europe). feel free to send PM.
6 locked drives.
В этой теме нет новых непрочитанных сообщений. gigabyte GA-G41MT-S2P rev: 1.3 Diagnostic plate ( --FF reset Flashing ) or (FF00 reset wiped out )
в форуме Gigabyte
eletmoraes
28 мар 2017, 18:44
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HGST Endurastar J4K320 HEJ423220H9E300 SMART BAD
Marwin
3394
02 апр 2018, 17:31
Storag Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Smooth для HGST Z5K500-500
vostin
16 дек 2018, 23:48
vostin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. клин HGST - не мертвый и не живой
[ На страницу: 1, 2 ]
oleglt
38
9204
06 апр 2019, 01:25
В этой теме нет новых непрочитанных сообщений. HGST hts545050b7e660 кем был?
gmosin
16 апр 2020, 14:17
gmosin Перейти к последнему сообщению
