Текущее время: 22 ноя 2024, 00:26
 Заголовок сообщения: Lenovo ideapad 100-15IBD (CG410/CG510 NM-681A rev:1.0) Short Circuit at PL701 (+1.05VS)
СообщениеДобавлено: 29 янв 2019, 15:35
This laptop was brought to me, someone tried to repair it before, there were traces of flux under the combine (cpu+mcp).
When power from charger is applied, the always present (дежурка) voltages are there: PL304 - 5v, PL303 - 3.3v.
There is 3v on SPI and on power button.
When power button is pressed, the power on LED lights, no other voltages on coils appear, no fan spinning. If I press and hold the power buton for 4+ seconds, the LED turns off as it should.
The board is DIS (NV920).
Coil resistance:
PL303 (3.3V) = 380R
PL304 (5V) = 510R
PL705 (VGA CORE) = 23.7R
PL706 (VGA CORE) = 23.6R
PL501 (1.35v) = 296R
PL302 (BAT) = 735R (battery removed)
PL9 (CPU CORE) = 9.8R
PL701 (+.05VS) = 1R ?!
I removed PL701, the "short" is on the "consumer" side, eg. MCP part of the Combine. Injected voltage, it drops severely, but no heat dissipation, nowhere, not even on the MCP part, and that's what's bugging me. On that very low resistance,there should be something burning hot.
Can I be fairly sure that the MCP is fused bad and return the laptop (I don't have the proper equipment to replace 1000+ ball BGA), or search for shorted capacitor under the MCP?
Thank you.
 Заголовок сообщения: Re: Lenovo ideapad 100-15IBD (CG410/CG510 NM-681A rev:1.0) Short Circuit at PL701 (+1.05VS)
СообщениеДобавлено: 29 янв 2019, 16:38
Yes!
СообщениеДобавлено: 29 янв 2019, 17:43
Thank You. This thread can be closed.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo IdeaPad 100-15IBD (CG410/CG510 NM-A681 Rev: 1.0) Bios
rafab
27 апр 2016, 16:24
harry_i Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo ideapad 100-15IBD (cg410/cg510 NM-A681 Rev: 1.0) Нет дежурки, нет питания мульта. Нужны датажиты на шим
arseniy1991
14 июн 2016, 16:54
arseniy1991 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo ideapad 100-15IBD (cg410/cg510 NM-A681 Rev: 1.0) Помогите определить шим
alias095
3495
29 дек 2016, 07:24
alias095 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo IdeaPad 100-15IBD (CG410/CG510 NM-A681 Rev: 1.0) Нет инициализации
piramida712
23 фев 2017, 22:43
piramida712 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo ideapad 100-15IBD (CG410/CG510 NM-A681 rev 1.0) Опознать микросхему.
seik
11 май 2017, 18:40
seik Перейти к последнему сообщению
Сейчас этот форум просматривают: liova, solik и гости: 79
