Текущее время: 21 ноя 2024, 17:12
 Страница 1 из 1 [ Сообщений: 20 ]
 Заголовок сообщения: acer zc-700g problem bios ..
СообщениеДобавлено: 20 фев 2019, 12:27
Заблокирован
acer zc-700g i have download bios from acer site CAB file and i must cut in win hex but new file is smallest then old one I m very confused ..I found on this site bios ,but when i flash by programmer ,does not pc show pictures ,only on 1333 mhz ram memory ,that reason why I need new one.Here are two bios ,one is cab one is bin ..Maybe some one can hellp me ..
https://mega.nz/#!UMw3SYbI!7yfP_sApJsmv ... 1uiP_iL-Is
https://mega.nz/#!EARCRAIT!JxeA0CBD7m1S ... v4K-1lUcyY
 Заголовок сообщения: Re: acer zc-700g problem bios ..
СообщениеДобавлено: 20 фев 2019, 16:51
bokin021 писал(а):
one is cab
Not cab, but extension is cap.
Try download and unpack version BIOS R01.B2. Found two files R01-B2.CAP, 2092.bin. First file have then same size as R01-B3.BIN. Second may be found by similar information in file test.BIN.
СообщениеДобавлено: 20 фев 2019, 23:38
Заблокирован
https://mega.nz/#!QZxzEayQ!BppVJVsFXTao ... peNWwtjU6k
this is file from acer site ,what is write bios?Can you explain me?When open this file of 2.2 kb in win hex is total diferent then old bin
СообщениеДобавлено: 21 фев 2019, 00:43
Similar problem resolved in https://remontcompa.ru/1659-vosstanovle ... ast-3.html
Try translate this page.
СообщениеДобавлено: 21 фев 2019, 10:36
Заблокирован
no solution on this site for my case..
СообщениеДобавлено: 21 фев 2019, 14:29
You first saved the original BIOS to file *.bin from the flash memory chip?
СообщениеДобавлено: 21 фев 2019, 18:38
Заблокирован
yes i did
https://mega.nz/#!JVZGRSZR!qjkk7zC3niAO ... -7E4ZXtQwA
СообщениеДобавлено: 21 фев 2019, 19:59
Old BIOS and laptop error what ? If old and test BIOS produced the same error then problems in hardware.
СообщениеДобавлено: 21 фев 2019, 22:58
Заблокирован
I have done pc everything is ok now..Thank s lot..
СообщениеДобавлено: 26 фев 2019, 14:41
Заблокирован
I have another strange problem..When I restart ,then next time does not show screen and than ,when i change other memory module,turn on normal after next restart and again same problem only hellp when I change module ..I dont know what to do ,i have update bios ,also change ec bios ,memory are 100% ok..Maybe some one have similar problem?
СообщениеДобавлено: 26 фев 2019, 16:18
Try remove all memory modules and CR-2032 battery. Power on. Power off. Install battery. Power on. Power off. Install memory. Power on and reset values to default settings in BIOS Setup.
СообщениеДобавлено: 26 фев 2019, 16:20
Заблокирован
i did alredy that but same happen..Very strange problem
СообщениеДобавлено: 27 фев 2019, 18:09
Заблокирован
Something else I can do?
СообщениеДобавлено: 27 фев 2019, 18:29
Your restart is really restart or sleep, or hibernate mode? Check settings in Windows.
СообщениеДобавлено: 27 фев 2019, 19:18
Заблокирован
restart even when i plug out charger same does
СообщениеДобавлено: 01 мар 2019, 14:10
Заблокирован
Aspire ZC-700G maybe someone have EC bios
СообщениеДобавлено: 04 мар 2019, 21:03
Заблокирован
How I can extract EC bios from bios from site ?Please I need very much or some one have it from back up?
СообщениеДобавлено: 05 мар 2019, 22:49
Заблокирован
Please can someone can help me for EC bios ?
СообщениеДобавлено: 20 мар 2019, 18:44
Заблокирован
no ec bios :((
СообщениеДобавлено: 20 мар 2019, 18:55
Try solve problem by viewtopic.php?f=181&t=2460&hilit=%2Aextract+EC+bios%2A
В этой теме нет новых непрочитанных сообщений. acer aspire zc-700g (ipmbw-br) shcematic
bokin021
03 окт 2019, 17:56
Timurio73 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Fujitsu LifeBook NH532 (Intel i5 3230m Nvidia 640m LE) Problem with RAM memory , also Problem with Graphic dri
в форуме Fujitsu-Siemens
draganzile
01 авг 2016, 18:08
draganzile Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell 3521 (Display problem help me) Display problem
в форуме Dell
ahmeterengul
12 июн 2017, 11:22
ahmeterengul Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony Vaio VPCEA32EG (MXB-223 M971 MAIN BOARD 6 LAYER ) Bios Password Problem
в форуме Sony
usmankhan
10 авг 2016, 15:33
and555 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS A52F-SX627D (WIN8) Problem BIOS
FComp
13 окт 2016, 07:50
bass Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 7
