Good afternoon,
I have problem with Asus GTX 960. There are no power on GPU and Memory. That is why I changed two components marked by green square on the front pcb. When the power doesn't apear I lifted GPU but it didn't change anything.
Once I forgotten plug the 6 pin connector and I measured powers on GPU and Memory. I was surprised that everything is ok. However, after I plug 6pin connector the powers have gone. Then I started measured INA3221 on the back of PCB (marked as green square). I changet it to new one. I found the broken resistors (marked red arrows). Two resistors under capacitor was replaced by 2x 20ohm. I have asus gtx 970 where are similar situation and there are 20ohm each. However, I dont know the resistor R1130 and I used 150ohm.
Now I have situation that when the 6pin is conected I haven't power on gpu and memory.
There are no shorts. The powers 12V 5V 3,3V present. What I schould check now?
I have to stress that GPU is lifted so I can't check screen without 6pin connector. I would like to solve it first and then I will put GPU back.
Is anyone have any idea?
Is anyone know which (size) resistor schould be used on R1130 and R1129?
