Текущее время: 21 ноя 2024, 18:38
 Заголовок сообщения: Macbook Pro 13" A1708 (820-00840-A) No image
СообщениеДобавлено: 16 май 2019, 20:36
Hi, another weird problem with a macbook.
I'm trying to repair this Macbook Pro 13" A1708, (820-00840-A) it has no image, but backligth is working ok.
All voltages are good, but has no vcore. L7410, L7420 and L7430 have voltage (cpu vcore) but only for half a second.
The weird thing is that cpu gets hot, and fan spins. (also osx pendrive install usb, blinks as it were booting from it)
Someone experienced something like this?
Could be a damaged cpu or bios corrupted?
Thanks in advance.
 Заголовок сообщения: Re: Macbook Pro 13" A1708 (820-00840-A) No image
СообщениеДобавлено: 17 май 2019, 09:02
Can You connect external display?
СообщениеДобавлено: 17 май 2019, 09:49
Hi Shooter75, yes I can connect an external display whith usb-c to hdmi adapter but there is no image via external.
The point is that without cpu vcore is not possible to guet video, but there is a normal voltage there (at the vcore coils) for a moment.
Thanks for your help.
СообщениеДобавлено: 17 май 2019, 11:20
If video-drain wasn't found at init-algorithm, vcore dosn't appear.
СообщениеДобавлено: 17 май 2019, 12:33
Hi Shooter75, what do you mean with "video-drain".
Could you explain it?
Wich part of the circuit?
Thanks.
СообщениеДобавлено: 17 май 2019, 15:39
Do You understand "video-source"? :-):
Video-drain is antipod of. :mi_ga_et:
Wow - Any external/internal display.
Without any V-D, vcore don't appear.
1. Verify AUX ch at eDP on MB.
2. If no detection packets appears - GT2.eDP channel is damaged.
3. And measure eDP-mux(TB-host), if it has it's power when You connecting external display.
4. If You have same situation with AUX ch at TB-host, - Your GT2 is damaged.
You can backup Your original EFI and try any from 00840 with cleared ME.
This will not to be stable, but You can detect efi-crashes.
СообщениеДобавлено: 17 май 2019, 19:37
Shooter75
Yea, it is clear for me now.
I'm going to test the communication with lcd panel and will post the results.
Thanks again.
[size=85]Posted after 3 hours 27 minutes 32 seconds:[/size]
Hi, I have measured EDP_INT_AUX_N signal and EDP_INT_AUX_N, and both have a burst of pulses in the boot process.
Probably these pulses don't get its destination to lcd, so I'm going to order the flex cable and test again.
I have also measured pwm circuits for PPVCCGT_S0G voltage, and only get pulses for a moment at pin 1 of coil L7410. Pin 1 of L7420 and L7430 has nothing.
If the new flex video cable doesn't solve the problem, I will investigate if there is a problem with phase 2 and phase 3 of PPVCCGT_S0G pwm circuit.
Thanks and hope to have good news soon.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro A1708 (820-00840) не включается
в форуме Apple
eremenko_aleksey
6534
22 июн 2018, 14:05
eremenko_aleksey Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MacBook Pro (A1708 (820-00840)) Залит, нет включения, нет связи usbc
в форуме Apple
zoidberg
23 апр 2019, 20:01
zoidberg Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MacBook Pro A1708 ME (820-00840) очистить ME
в форуме Apple
skipass
14 дек 2019, 15:19
Aniev Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MAcbook Pro A1708 (820-00840-a) опознать микросхему
в форуме Apple
segaK_yar
2394
20 мар 2020, 16:41
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. macbook pro A1708 (820-00840-a) не вкл, залит, нет питания на F3010
[ На страницу: 1, 2 ]
в форуме Apple
segaK_yar
33
5771
19 фев 2021, 17:53
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 27
