Текущее время: 02 июн 2024, 11:56
mia
Заголовок сообщения: Re: chieftec cft-850-14c sudden shutdown with or without load. Добавлено: 28 май 2019, 08:17 |
Зарегистрирован: 14 сен 2018, 18:14 Наличности на руках: 1,279.27
Сообщения: 2529 Откуда: Odesa,Ukraine
montarbo писал(а): Recently I started getting random sudden shutdown. I narrowed it to the PSU. Why don't you say what changes have occurred hardware/software in your system, after which you have fallen into the present situation? Maybe there is an overload of one power supply, and the other is not. Compare the characteristics of power supplies.
mia
Заголовок сообщения: Re: chieftec cft-850-14c sudden shutdown with or without load. Добавлено: 04 июн 2019, 14:31 |
In most cases, for normal operation of the power supply, the + 5V channel must always be loaded. The label on the power supply case shows the maximum permissible combined load, for example + 5V and + 12V or + 5V + 12V + 3.3V, etc. When checking 3.3V, be sure to connect the load to the contact with the orange and brown wires, the voltage across the load is measured through the brown wire.
