Текущее время: 26 ноя 2026, 22:16
 Заголовок сообщения: Acer 5741G (Compal LA-5891P) turns off randomly
СообщениеДобавлено: 29 май 2019, 13:00
Hi,
have an issue with an Acer 5741G (Compal LA-5891P) that turns off randomly.
Seems that is a temperature problem, but the thermal paste and the heat pipe assembly has been changed.
The first boot it is stable 2 minutes or so, then it turns off, since this time it only stays on for 6 or 7 seconds. (sometimes a bit more)
All voltages are good and also ddr and cpu have been tested.
The weird thing is that it can be in bios setup for more than 2 hours without any problem. (only if bios setup is enter while it is cold enough)
Power button circuit is tested and has no problems in it, also ec-bios and pch-bios are good.
Can someone give me a hint to solve the issue?
В сети
 Заголовок сообщения: Re: Acer 5741G (Compal LA-5891P) turns off randomly
СообщениеДобавлено: 29 май 2019, 15:03
Is the CPU voltage stable? use an oscilloscope
Ремонт ноутбуков в Шадринске
СообщениеДобавлено: 29 май 2019, 18:33
Yes cpu voltage is stable and has no ripple. (only has the small variations that are normal during boot)
I have activated F12 in bios setup in order to select boot device, and when boot, if detects F12, shows the boot menu forever, but if select a device and press enter, it turns off.
Regards.
В сети
СообщениеДобавлено: 29 май 2019, 19:43
remove battery cmos
СообщениеДобавлено: 29 май 2019, 22:11
Цитата:
remove battery cmos
The cmos battery had been removed at first, and did some test without it, but now it's soldered again.
I will remove again and continue the test without it.
I have put a password on boot, and it start always asking for the password, and doesn't turns off, only when I write the password and press enter, it turns off.
A very weird thing.
Hope someone has had this problem before and can help me.
Thanks.
В сети
СообщениеДобавлено: 30 май 2019, 09:29
If U9 is installed, raise the 6th pin. If this solves the problem, replace the graphics processor.
СообщениеДобавлено: 30 май 2019, 18:15
PU30 is not soldered in the circuit since I started to make the tests, but I have not tested U9.
I will try it and post if success or not.
Regards.
Posted after 2 hours 38 minutes 41 second:
hi, majemus I have removed U9 and it works and loads windows. :ya_hoo_oo: :ya_hoo_oo:
I will put a new U9 and will test. (it's easy than change the gpu)
I will let you know the results.
В сети
СообщениеДобавлено: 30 май 2019, 21:25
If you replace the U9, this will not solve the problem. The problem is with the thermal diode of the GPU. When replacing the U9, you will have a thermal effect on the GPU and it will work, but it will not fix it.
СообщениеДобавлено: 31 май 2019, 18:36
It works ok without U9, but I have ordered a new gpu.
I think the new gpu will solve the problem definitely.
Thanks for your help.
В сети
В этой теме нет новых непрочитанных сообщений. Hp g62-b19sl (Turns on LED power alone) Turns on LED power alone
amennone
09 фев 2018, 00:38
desertearch Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo T460s (Compal NM-A421) After 10 seconds turns off. No screen, no beeps.
derick
30 ноя 2020, 19:55
derick Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 01:11
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 3542 (cedar intel mb ) turns off after 30 mins
в форуме Dell
ayad
13 ноя 2019, 15:59
youngwar Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Msi R7 370 2g armor turns on and off 2 seconds later
TheMArcos
2912
10 май 2020, 19:16
TheMArcos Перейти к последнему сообщению
Сейчас этот форум просматривают: alekkisl, Longreid и гости: 178
