Текущее время: 29 ноя 2026, 16:23
 Заголовок сообщения: dell vostro 1520 (LA-4595p) windows won't install
СообщениеДобавлено: 31 июл 2019, 19:59
i have this laptop by windows not install and stuck on windows logo in every version of windows ( 7,8,10 xp ,...)
this work i did
1-changing hard
2-program bios
3-changing ram
4-changing cpu
5-changing IO
6-heat on gpu sb and nb
7-remove sd card ic (some time this ic make disturbance)
8-clean board
9-try install from flash disk and dvd
10-i removed all unnecessary component and tried to install but not help
11-even tried install with external lcd and keyboard and removed self lcd
12-change cpu ic ISL....
i very confused that's problem did any body have any idea ?
(this picture of logo keep motioning and wont freezed but no comes more )
 Заголовок сообщения: Re: dell vostro 1520 (LA-4595p) windows won't install
СообщениеДобавлено: 31 июл 2019, 20:21
Try to see the system log on another work computer. There may be useful information.
СообщениеДобавлено: 01 авг 2019, 02:12
Whrere the log stored ?
СообщениеДобавлено: 01 авг 2019, 08:16
System log files are located in the following directory: %SystemRoot%\system32\winevt\Logs\
System log file is System.evtx
СообщениеДобавлено: 01 авг 2019, 09:35
Try to change CPU capacitors, next step - change NB
СообщениеДобавлено: 01 авг 2019, 17:18
Ok i will do
СообщениеДобавлено: 01 авг 2019, 17:48
Such an effect can be when problems with graphics
Куплю ум, мозг не предлагать - не приживается
СообщениеДобавлено: 01 авг 2019, 23:11
You told me to reball chip ?
СообщениеДобавлено: 02 авг 2019, 10:15
I changed the chip
СообщениеДобавлено: 04 авг 2019, 18:54
every work in top i did but not help
СообщениеДобавлено: 04 авг 2019, 19:10
Have you tried other operating systems? Does Ubuntu work? FreeDOS? Does memtest pass?
It makes no sense to randomly mess with the hardware when you have no idea what could be wrong, you're going to make it worse. Might as well replace the entire board now and save yourself some time.
СообщениеДобавлено: 05 авг 2019, 18:51
i want to fight with this board till repair it
В этой теме нет новых непрочитанных сообщений. dell vostro 1520 (vostro 1520) one row in new keyboard dosnt work
в форуме Dell
omidhadian
06 мар 2018, 15:02
penkoloda Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. vostro 1520 (la-4595p) Снесены элементы
в форуме Dell
fixit
2827
01 авг 2018, 13:58
fixit Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus (x550jx) cant install windows
narges
29 авг 2019, 00:04
Kim_555 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Vostro 1520 UMA (LA-4596P) No LVDS (crt working)
в форуме Dell
R EZ A
29 авг 2023, 19:41
ricarry Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Power source dell Model H275P-01 P / N: HP-L2767F3P won't start
eletmoraes
3346
05 янв 2020, 21:35
Witewut Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 33
