Текущее время: 29 ноя 2026, 17:05
 Страница 80 из 228 [ Сообщений: 6830 ]  На страницу Пред.  1 ... 77, 78, 79, 80, 81, 82, 83 ... 228  След.
Куратор темы: Vertyanov_SS
 Заголовок сообщения: Re: Программатор для ENE/ITE/MEC/Nuvoton TETRIS/SPIDER/JAWS (Vertyanov_JIG)
СообщениеДобавлено: 11 сен 2019, 17:22
Cink
скрин из оболочки или лог пришлите на почту
Что бы увидеть скрытое сообщение Вам необходимо зарегистрироваться и войти на форум официально
Программатор SUCCESSOR/JIG V2/3.
Пост карты DDR234/NGFF_GoWin/KFCT_BIG
СообщениеДобавлено: 12 сен 2019, 09:42
IT8987E CXA
after first programming can't read/write again.
Flash inserted.
Soft version --> 7.9.7163.63
Mode selected --> External board
Vertyanov JIG FW_v43
2F2F7B91632DBDF165C3C665
[A906GP4Z][413930364750345A]
[X44672] [583434363732FF122B0B]
## JIG registered ##
ITE EC external board.
Settings for external board sent successfully!
Save the file: C:\Users\Pityu\Desktop\Acer F5-573G-52M7\ITE_2.bin
12-Sep-19 9:31:23 AM
Check connection ...
ITE we do not respond!
Check the connection and settings.
MB powered? (00)
I try different EC chip I read it many time. After first programming I can't connect to it.
There is some kind protection?
It is fault?
Somebody have this situation programming in external mode?
Я использую Гугл переводчик.
СообщениеДобавлено: 12 сен 2019, 09:46
Pityu
Please dump for write paste here.
СообщениеДобавлено: 12 сен 2019, 09:59
Attached!
СообщениеДобавлено: 12 сен 2019, 12:06
It has not been written that Tetris supports 8987. It supports 8580/8585/8586/8587.
8987 has some differences.
ZQK_8587 power lines 3v3 differences
ZAA_8987 power lines 3v3 differences
GND 8987 (left) VS 8587 (right)
I had everything as you described.
I began to understand and the solution is this.
I used a SPIDER.
1 I cut the tracks to the contacts of the EC 3/113/122 near the spider connector.
2 I soldered jumper 106-121 on the spider connector (3v)
3 I soldered jumper 91-104 (EC) on the spider connector
Do not forget about the ITE mechanism that I wrote about earlier (power-on self-programming. Options).
*HERE*
My Log
2F2F7991732DBDF165C3C665
[AL040I60][414C303430493630]
[W74594] [573734353934FF0C1F06]
12.09.2019 13:20:46
2F2F79917B2DBDF165C3C665
Received ITE ID -> 8987 rev -> 01
INFO. Size embedded FLASH EC 128KB!
Save the file: C:\Users\SS_BIG\Desktop\8987\MY_OLD.bin
12.09.2019 13:20:59
Init ITE ... complete.
Reading, please wait ... complete.
12.09.2019 13:21:09
12.09.2019 13:21:15
Write to ITE file: C:\Users\SS_BIG\Desktop\8987\QUANTA ZAA.bin
Loaded from file to buffer 20000h bytes.
INIT complete.
ERASE ...
ERASE complete.
The number of bytes value of FFh -> 62610
Writing, please wait ... complete.
Verify ... complete.
The data is the same!
12.09.2019 13:22:30
12.09.2019 13:22:34
Save the file: C:\Users\SS_BIG\Desktop\8987\READ_AFTER_WRITE.bin
12.09.2019 13:22:54
12.09.2019 13:23:04
12.09.2019 13:25:22
2F2F7991712DBDF165C3C665
12.09.2019 13:25:27
12.09.2019 13:25:32
12.09.2019 13:25:39
INIT complete.
ERASE ...
ERASE complete.
12.09.2019 13:26:53
12.09.2019 13:27:01
Save the file: C:\Users\SS_BIG\Desktop\8987\READ_AFTER_WRITE2.bin
12.09.2019 13:27:23
12.09.2019 13:27:32
СообщениеДобавлено: 12 сен 2019, 16:01
Hello, sorry for my non russian speak.
I want to know if there is some case where keyboard converter module is necessary?
Thanks in advance.
СообщениеДобавлено: 12 сен 2019, 16:15
gelang
If we are talking about BIG_KB_TEST ....
It is needed if the FFC of the keyboard contains more than 32 contacts. If there are less than 32 contacts, then the programmer will be enough.
СообщениеДобавлено: 12 сен 2019, 17:06
Yes, happy to know his name. Is it BIG_KB_TEST we see here?
useless in this case i believe cause gl553vd has 17 pins connector.
Thanks a lot sir Vertyanov, i'll contact you for purchase.
Последний раз редактировалось Vertyanov_SS 28 янв 2020, 16:05, всего редактировалось 1 раз.
СообщениеДобавлено: 12 сен 2019, 17:10
gelang
*** Переходная плата с разьемами на борту CONN_MIX32 600р КАРТИНКА
СообщениеДобавлено: 21 сен 2019, 10:58
Lenovo Y520-15IKBA
мульт IT8226E BXA
NM-B281 KB_pins=32 (JKB1) 08MM PD0=2 PD1=11 PD2=16 PD3=8 PD4=17 PD5=15 PD6=19 PD7=1 BUSY=5 STB=13 AFD=3 INIT=10 SLIN=12 KSI4=9 KSI5=7
СообщениеДобавлено: 23 сен 2019, 19:21
Доброго времени.Программатор вер.3,1,брал в Одессе,накрылась epm240t100c5n,где можно заказать на замену?
СообщениеДобавлено: 24 сен 2019, 10:19
basta777
как определили ? Лог есть или совсем труп?
Заказать можно у меня прошитую или ставите чистую и получаете "лекарство".
Оба варианта по 10 usd.
СообщениеДобавлено: 24 сен 2019, 10:52
коротнул случайно,труп полный,греется кренка 3.3в
---------- Добавлено спустя 1 минуту 16 секунд: ----------
как заказать?
СообщениеДобавлено: 24 сен 2019, 11:18
DAG7BFMB8D0 REV:D
KB9027Q B
KSO3=15 KSI4=28 KSI7=31 KSI6=30 KSI5=27
Ум на лице – это еще не признак ума. Все глупости на земле делаются именно с этим выражением лица.
СообщениеДобавлено: 24 сен 2019, 11:34
basta777 писал(а):
как заказать?
У Максима в Одессе есть в наличии.
СообщениеДобавлено: 24 сен 2019, 11:44
Подскажите как с ним связаться можно?Через сайт?
СообщениеДобавлено: 24 сен 2019, 13:26
Міша Смич Не все так просто. У Макса может и есть, но скорее всего для 3.2 прошитые, а топология 3.1 и 3.2 отличается. Втупую заменять нельзя.
Таким образом, или новую впаивать или спецом под 3.1 прошитую.
Контакты Макса на этом сайте - баннер второй слева висит ....
СообщениеДобавлено: 24 сен 2019, 19:36
Vertyanov_SS
Здравствуйте. Хотел бы приобрести программатор вместе с кабелем EDID. Что для этого нужно?
/ Ответил в личку /
Последний раз редактировалось Vertyanov_SS 25 сен 2019, 09:13, всего редактировалось 1 раз.
СообщениеДобавлено: 24 сен 2019, 20:15
В Украине это проще через Максима сделать, я это имел в виду, у вас же поставки налажены :-):
СообщениеДобавлено: 25 сен 2019, 11:56
LA-E831P kb9022q
LA-E831P KB_pins=32 LEFT DOWN 1MM KSO3=15 KSI4=28 KSI7=31 KSI6=30 KSI5=27
СообщениеДобавлено: 26 сен 2019, 18:42
Барзанукаев Ислам писал(а):
Нажмите на это поле, чтобы приблизить изображение.
если нажать да то
Mode selected --> Check ALTERA pin
85858591692DBDF165C3C665
[A506CIGL][413530364349474C]
[U79132] [553739313332FF032427]
ALTERA SPI TEST
SPI data to pins from 1 to 32
error, pin 1
error, pin 2
error, pin 3
error, pin 4
error, pin 5
error, pin 6
error, pin 7
error, pin 8
error, pin 9
error, pin 10
error, pin 11
error, pin 12
error, pin 13
error, pin 14
error, pin 15
error, pin 16
error, pin 17
error, pin 18
error, pin 19
error, pin 20
error, pin 21
error, pin 22
error, pin 23
error, pin 24
error, pin 25
error, pin 26
error, pin 27
error, pin 28
error, pin 29
error, pin 30
error, pin 31
error, pin 32
Detected problems with the chip.
ALTERA is damaged and needs to be
replaced or fw update.
My email: VertyanovSS@gmail.com
Добрый день! Аналогичная проблема , сбросите инструкцию ?
СообщениеДобавлено: 26 сен 2019, 19:22
serginio
Мне в почту свой лог пришлите.
СообщениеДобавлено: 28 сен 2019, 19:15
Заблокирован
Asus X450JN (motherboard SV41JN)
X450JN KB_pins=24 PD0= PD1= PD2= PD3= PD4= PD5= PD6= PD7= BUSY= STB= AFD= INIT= SLIN= KSI4= KSI5=
Need values
THANKS
СообщениеДобавлено: 29 сен 2019, 12:49
ploty
Please use a circuit diagram, boardview or special device as described in the instructions.
СообщениеДобавлено: 29 сен 2019, 15:49
Заблокирован
Can you help me find pinout. Is my first time trying to edit kb conect pins. Your a professional. You can right this for me please?
СообщениеДобавлено: 29 сен 2019, 18:50
msi ge62
kb9028q
MS-16J41 KB_pins=26 LEFT UP 1MM KSO3=23 KSI4=14 KSI7=11 KSI6=12 KSI5=13
СообщениеДобавлено: 29 сен 2019, 21:03
Здравствуйте Сергей хотел бы приобрести еще EDID кабель для прошивок матриц программатор ваш pcb ver 3.2 очень понравился
/Ответил в личку /
СообщениеДобавлено: 30 сен 2019, 08:35
ploty
Write me the serial number of the programmer or the log from the shell
More or less like this
Цитата:
[A506CIGL][413530364349474С]
[U79132] [553739313332FF932427]
СообщениеДобавлено: 30 сен 2019, 11:38
Заблокирован
[AH05RK8X][41483035524B3858]
[U81389] [553831333839FF0B0619]
30-09-2019 09:40:43
FTDI driver version 21228
Version FW JIG M328_EPM240_v34
is this ?
СообщениеДобавлено: 30 сен 2019, 12:00
30-09-2019 09:40:43
Why are you showing edited texts?
I answered already in the mail that you bought a fake.
Why should I provide technical support?
You were offered a way out of the situation.
PS Интуиция мне подсказала и я не ошибся. Клон и без регистрации )) Еще и текст корректировался.
---------- Добавлено спустя 19 минут 25 секунд: ----------
this is what the uncorrected text looks like
Цитата:
Soft version -->> 7.9.7163.63
Mode selected -->> ITE (IT8XXX)
## JIG not registered! ##
on/off counter=14
and this part from the old version is added
В этой теме нет новых непрочитанных сообщений. Куплю адаптеры TETRIS + SPIDER (Vertyanov JIG) Украина
в форуме Куплю | Buy
logros
30 ноя 2022, 00:20
Evstafiev Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Программатор для прошивки ENE/ITE/MEC/Nuvoton V2
alias095
22043
25 май 2017, 01:16
alias095 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Продаю программатор для прошивки ENE/ITE/MEC/Nuvoton (Vertyanov_JIG V2)
FearCult
15 май 2017, 07:31
FearCult Перейти к последнему сообщению
Belebirda
22 июн 2017, 14:02
Belebirda Перейти к последнему сообщению
scrofula
18 ноя 2017, 12:52
scrofula Перейти к последнему сообщению
Сейчас этот форум просматривают: Anatol83, Smoker и гости: 15
