feedme писал(а):
с ключом -е 1 попробуйте, что покажет
В общем с -е 1 без ошибок
С -е 100 ошибки такого типа
RR
FBIOA[ 31: 0] 0 4386434 0 0 0
FBIOA[ 63: 32] 0 4383058 0 0 0
FBIOB[ 31: 0] 0 4387244 0 0 0
FBIOB[ 63: 32] 0 4387022 0 0 0
FBIOC[ 31: 0] 0 4390694 0 0 0
FBIOC[ 63: 32] 0 4382652 0 0 0
FBIOD[ 31: 0] 0 4381856 0 0 0
FBIOD[ 63: 32] 0 4386836 0 0 0
FBIOE[ 31: 0] 0 4383382 0 0 0
FBIOE[ 63: 32] 0 4386712 0 0 0
FBIOF[ 31: 0] 0 4382270 0 0 0
FBIOF[ 63: 32] 0 4389068 0 0 0
С -с 1 ошибки такие
SUBPART RANK0 RD ERR RANK0 WR ERR RANK1 RD ERR RANK1 WR ERR UNKNOWN ERR
FBIOA[ 31: 0] 205984 2523682 0 0 0
FBIOA[ 63: 32] 210592 2486202 0 0 0
FBIOB[ 31: 0] 210272 2488388 0 0 0
FBIOB[ 63: 32] 208800 2539618 0 0 0
FBIOC[ 31: 0] 209056 2535180 0 0 0
FBIOC[ 63: 32] 212000 2479736 0 0 0
FBIOD[ 31: 0] 213600 2481964 0 0 0
FBIOD[ 63: 32] 208480 2527808 0 0 0
FBIOE[ 31: 0] 209472 2536190 0 0 0
FBIOE[ 63: 32] 213696 2487236 0 0 0
FBIOF[ 31: 0] 212416 2484452 0 0 0
FBIOF[ 63: 32] 207232 2526404 0 0 0
Добавил в запуск перед матс строку mods gputest.js -mfg -skip_rm_state_init
ЛОГ Модс выглядит следующим образом
MODS start: Mon Dec 23 23:44:49 2019
Command Line : gputest.js -mfg -skip_rm_state_init
CPU
Foundry : GenuineIntel
Name : Intel(R) Pentium(R) CPU G4400 @ 3.30GHz
Family : 6
Model : 14
Stepping : 3
Version
MODS : 367.38
OperatingSystem: Linux (x86_64)
Kernel : 4.1.2-gentoo
KernelDriver : 3.63
HostName : tinylinux
Smbios version [0x300] is not supported
gpu 0 dev.sub 0.0
PCI Location : 0x00, 0x02, 0x00, 0x00
DID : 0x1b06
Raw ECID : 0x00fff18000000031d3c82191
ECID : PCTF88-06_x-1_y07
Device Id : GP102
Revision : a1
NV Base : 0xf6000000
FB Base : 0xe0000000
IRQ : 11
NV_PMC_INTR_0 bit 30 high.
Trying to clear interrupt by writing 0x2 to register 0x12004c
Successfully cleared GPU's interrupt state.
Failed to read good Jtag Ctrl Status
WARNING... Failed to unlock Jtag for access!
Chipset
VID : FFFF (Unknown)
DID : FFFF (Unknown)
Rm call failed. default Disabled.
Chipset ASPM : Disabled
Chipset LTR : Enabled
Failed to open file gldGP102.bin
Error 000000000467 : Global.LoadGoldenValuesHelper No such file or directory.
Error 000000000467 : Global.LoadGoldenValues No such file or directory.
Error 000000000467 : Global.InitializeGpuTests No such file or directory.
gputest.js : 36
mfg.spc : 9
boards.js : 5
boards.db : 3087
boards_gp102.db: 10
boards_gp106.db: 37
GpuDevMgr not initialized. Device shutdowns will likely do nothing.
Error Code = 000000000467 (No such file or directory.
