Текущее время: 21 ноя 2024, 22:57
 Заголовок сообщения: Power source dell Model H275P-01 P / N: HP-L2767F3P won't start
СообщениеДобавлено: 02 янв 2020, 03:58
I suspected the integrated TNY278 that I tried to replace with a new one but after replacing the component the defect persists.
The voltage on the green wire at the source output does not exist.
The voltage over the electrolytic capacitor of primary after the rectifying bridge is around 175V (B+) or so.
I tried to find the schematic diagram but couldn't
 Заголовок сообщения: Re: Power source dell Model H275P-01 P / N: HP-L2767F3P won't start
СообщениеДобавлено: 03 янв 2020, 02:55
seems it is simply forward PSU with one high voltage mosfet like 2SK2654. (8-9 Amper 900-1100 Volt)
http://images.100y.com.tw/pdf_file/2SK2654.pdf
PWM regulated by something like UC3843.
https://www.elektroda.pl/rtvforum/topic2909875.html
http://deleted.vlab.su/view3/9420909/ade3263 ... 2fe9/1200/
Sunny Model ATX-250W
check all small elektrolitic capacitors around TNY
СообщениеДобавлено: 03 янв 2020, 05:33
my question is , is it normal for the voltage on pins 2 and 4 of TNY278 to be almost equal around 165 v?
СообщениеДобавлено: 03 янв 2020, 12:26
for 4 normal for 2 nonnormal
СообщениеДобавлено: 04 янв 2020, 11:27
Мда у них еще и стандарты под 110 вольт
СообщениеДобавлено: 04 янв 2020, 14:45
да не, судя по картинке, туда половинка выпрямленного поступает
СообщениеДобавлено: 05 янв 2020, 04:57
This power supply uses a voltage switch. At the entrance after the rectifying bridge is used 2 200v electrolytic capacitors
СообщениеДобавлено: 05 янв 2020, 22:35
comon sistem, discussion is about what entrance voltage You have: ~110 or ~230
I think half of rectified ~230V come to 4 pin of UC3843
rectified ~230 is about 324V, and half of it is 162V
rectiefied ~110 is 155V
PS. You wrote in english, so look like You are from US (where is popular ~110V), but Your nikname "eletmoraes" look liks more to spanish or romanesc (latin) language countries where ~230V dominated.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. X230 Won't turn on (X230 Won't turn on) X230 Won't turn on
zenelli
26 сен 2015, 06:25
Arrester Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Xbox One S has all the voltages, but still won't start.
borisz94
30 сен 2024, 22:47
borisz94 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. power source model DSA-500VE -12v low voltage
eletmoraes
10 апр 2015, 05:56
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. power source 30V / 5A yaxun произошла перегрузка, разорвав дорожку пластины. model YX-305D
в форуме Ремонт ИБП | UPS repair
eletmoraes
03 окт 2022, 05:25
В этой теме нет новых непрочитанных сообщений. power source Dell H220AS-00 Not initialized, totally dead
eletmoraes
14 янв 2017, 20:12
Witewut Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 12
