Текущее время: 22 ноя 2024, 09:25
 Заголовок сообщения: Philips 50PVS6262/60 (TPM17.7E LA) что то не так с ОЗУ?
СообщениеДобавлено: 30 янв 2020, 10:39
Всем привет! Передал сосед на прошивку EMMC Philips 50PVS6262/60, платформа TPM17.7E LA. Прошил, на аппарат не ожил. Подрубил к компу и лог меня, так сказать, немного запутал. По схеме 2 канала памяти, в логе 3 и по объему что то не так.
Сам лог:
Boot-
DRAM Channel A Calibration.
DRAM A Size = 1024 Mbytes.
DRAM Channel B Calibration.
DRAM B Size = 512 Mbytes.
DRAM Channel C Calibration.
DRAM C Size = 256 Mbytes.
Boot
Start Pmain
EMMC boot
CID:0x187cc499
:0x300293f2
:0x30344736
:0x11010030
LZHS addr:0x00100040
LZHS size:0x000d5770
LZHS size:0x0004ff9c
LZHS checksum:0x000000e3
LZHS begin
LZHS ok
Boot
Start Lmain
MT5886 Boot Loader v0.10
MUSB_Init : ++
It has 2 USB Port,is 1, 1, 0, 0(1=using, 0=not use).
USB0: Set GPIO43 = 1.
USB1: Set GPIO45 = 1.
USB Port 0 is initial.
USB Port 1 is initial.
Set port-0 to Host mode.
Set port-1 to Host mode.
Support network!1st MAC in EEP is valid (70:af:24:02:98:ea)
1st : (70:af:24:02:98:ea)
2nd : (70:af:24:02:98:ea)
Boot reason: A/C power on!!
[QHB] Previous system state is on, not enter QHB.
read from eeprom ioff 0 phy_off 10784
IR DATA register : 0x 0
T8032 init A/C on case loader stage...
Load T8032 FW (addr: 0x d57afc, size: 21841)success!!
° xxxxxxxxxxьT8032 FW version: 6
° xxxxxxxxxxьT8032 change to loader stage...
LDR_FlashCopy 0xf010 0x5a380 0x80
[MSDC] LOADER FAST READ EMMC!
[MSDC] Init config, cid = 0x11010030, dsc=0x187cc499, rca=0x300293f2, ocr=0x30344736
[MSDC] loader RCA 1, 1
[MSDC] MT22662:11010030:30344736:300293f2:187cc499
[MSDC] id1:00303034 id2:47363002
[MSDC] eMMC Name: UNKNOWN
[MSDC] ---MSDC Set FIFO path and Init---
[MSDC] Prepare set msdc Bus Clock as HS25(MHz),src 3 ,mode 0, div 4
[MSDC] Set Bus Clock as HS25(MHz) Success!,src 3 ,mode 0, div 4
[MSDC] MsdcSmapleDelay: u4IC_Value = 0x5886
[MSDC] Use NEW AutoK idea ,ignore the old ett param
[MSDC] Set pad driving as 5 !
[MSDC] [eMMC2DRAM]enter into SDR50 Mode, max dtr 200000000
[MSDC] Prepare set msdc Bus Clock as HS0(MHz),src 0 ,mode 0, div 16
[MSDC] Set Bus Clock as HS0(MHz) Success!,src 0 ,mode 0, div 16
[MSDC] Set pad driving as 0 !
[MSDC] Prepare set msdc Bus Clock as HS50(MHz),src 3 ,mode 0, div 2
[MSDC] Set Bus Clock as HS50(MHz) Success!,src 3 ,mode 0, div 2
[MSDC] --ENTER RPMB--
[MSDC] --EXIT RPMB--
[MSDC] Clock frequency = 900 MHz, Clock period = 1111 ps, 1 delay cell = 16 ps
[MSDC] TCMGET_DLYCELL_PERT = 69
PDWNC_Init
eLedSystemPowerOn
The init function of this module is NULL
AP force LOGO disabled
This startup is AC power up.
Do USB upgrade
u1USBBlock = 0x01d05600
USB: Vbus turn up time = 414 ms, Max =1000 ms.
Connect interrupt = 0x10, pBase = 0xf0051000.
USB-1: insert.
Device High speed.
MGC_HostEnumerator:MGC_EnumStateGetMaxDevice
HubPort-0: Device reset.
Silent Reset: Root device = 0x01d06604, Reset.
MGC_HostEnumerator:MGC_EnumStateReset
HubPort-0: Device address = 1.
MGC_HostEnumerator:MGC_EnumStateSetAddress
MGC_HostEnumerator:MGC_EnumStateGetFullDevice
HubPort-0: idVendor = 0x0471.
HubPort-0: idProduct = 0x7600.
HubPort-0: bcdDevice = 0x0100.
HubPort-0: Lang Id: 0x409.
HubPort-0: Manufacturer: MediaTek Inc..
HubPort-0: Product: 802.11 n WLAN.
HubPort-0: SerialNum: 000000000.
MGC_HostEnumerator:MGC_EnumStateSizeConfigs
MGC_HostEnumerator:MGC_EnumStateGetConfigs
MGC_HostEnumerator:MGC_EnumStateConnectDevice
USB Enumerator: find device driver
MGC_HostFindDriver:++
MUSB_TARGET_CLASS case 2:bMatch =1, 0x0,0x0
MUSB_TARGET_CLASS case1:bMatch =0,0x8,0xff
MUSB_TARGET_ACCEPT:bMatch = 0
MUSB_TARGET_CLASS case 2:bMatch =0, 0x9,0x0
HubPort-0: Driver not support, class = 0x0.
HubPort-0: Device is not accepted.
HubPort-0: Device unsupported.
MGC_HostEnumerator: break connect device
USB-1: ClassCode= 0x0, u4Diff=0 ms.
MUSB_GetInsert return 0
No USB device.
USB upgrade stop
Flash load lzhs header from 0x80000 to dram(0x1d06810), size=2048
Decompression uboot to 0x01000000...
Flash load image from 0x80000 to dram(0x1d06810), size=0x3e89d
TRUSTZONE_IN_CHB TCMGET_CHANNELA_SIZE 1024M, TCMGET_CHANNELB_SIZE() 512M u4TzLzhsDstDram 0x5e405000
Loader_GetPartIDByName SUCC!
Flash load tz from 0x317470(part_4) to dram(0x100000), size=0xf0952
LZHS start
LZHS done
TZ LZHS decode suc! src=0x100010,dst=0x5e405000,psize=0x454000,lsize=0xf0952,chk=0x7d
LZHS start
LZHS done
Starting image...
DRAM: WARNING: Caches not enabled
MMC:
0.0.0.0
In: Out: Err: Net:
OK
OK
welcome to lk/MP
boot args 0x0 0x16fe 0x100 0x8040
HKDF-SHA256 Verification: PASS
initializing trusty (Built: 16:20:33 Mar 14 2019)
Initializing Trusted OS SMC handler
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Parsing String = 76,-1,-1,176,-1,-1
[ 0.000000] Parse Done: msdc [0] = 76
[ 0.000000] Parse Done: msdc [1] = -1
[ 0.000000] Parse Done: msdc [2] = -1
[ 0.000000] Parse Done: msdc [3] = 176
[ 0.000000] Parse Done: msdc [4] = -1
[ 0.000000] Parse Done: msdc [5] = -1
[ 0.109847] _log2usb_3init_module
[ 0.110449] [ 0.118728] star: star_probe entered
[ 0.118792] star: BASE: mac(0xf0032000), pinmux(0xf000d400),ipll(0xf000d000),pdwnc(0xf0028000),bim(0xf0008000)
[ 0.118817] star: StarGetHwMacAddr,STAR_My_MAC_H(0x70af),STAR_My_MAC_L(0x240298ea)
[ 0.118862] star: Internal Vitesse PHY
[ 0.118868] star: PHY addr = 0x0000
[ 0.170563] star: StarGainSet to 31
[ 0.201878] star: Ethernet enable powerdown!
[ 0.201909] star: EthTool installed
[ 0.202333] star: star_init_procfs entered
[ 0.202366] star: star_probe success.
[ 0.202377] star: star_init success.
[ 0.205592] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.206601] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.207610] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.208618] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.209626] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.210634] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.211643] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.212651] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.213660] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.214668] mt53xx-u3phy f00d0000.ssusb1-phy: FM_OUT value: 0
[ 0.218734] [USB] usb_set_configuration =>
[ 0.218996] [USB] usb_set_configuration <=
[ 0.219367] [USB] usb_set_configura] usb_set_configuration <=
[ 0.219792] MUC_init:pUSBpdwncIoMap = 0xf0028000
[ 0.222372] [USB] usb_set_configuration =>
[ 0.222614] [USB] usb_set_configuration <=
[ 0.224558] mtk-msdc f006d000.MSDC0: kernel 3.18 driver probe!
[ 0.224602] mtk-msdc f006d000.MSDC0: ioremap host->base = 0xf006d000
[ 0.224611] mtk-msdc f006d000.MSDC0: ioremap host->sclk_base = 0xf000d380
[ 0.224621] mtk-msdc f006d000.MSDC0: ioremap host->hclk_base = 0xf000d384
[ 0.224629] mtk-msdc f006d000.MSDC0: hw_func=eMMC
[ 0.224695] msdc_aes_init: yifan aes init ok
[ 0.224702] msdc_aes_init: _pu1MsdcBuf_Aes_Align is 0xc05d5c80, _pu1MsdcBuf_AES is 0xc05d5c4d
[ 0.224724] mtk-msdc f006d000.MSDC0: [msdc_select_clksrc|1465] -> select clk source 0(24000000Hz)
[ 0.224735] mtk-msdc f006d000.MSDC0: [msdc_select_clksrc|1465] -> select clk source 3(384000000Hz)
[ 0.224825] set ios, power_mode=1, bus_width=0, clock=0
[ 0.236174] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.236183] ###set driving clk 5, cmd 5, dat 5
[ 0.236358] mtk-msdc f006d000.MSDC0: [msdc_set_mclk|1647] -> Set<400KHz> Source<384000KHz> -> real<400KHz> state<0> mode<0> div<240> hs400_src<0>
[ 0.251180] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.251192] mtk-msdc f0012000.MSDC1: kernel 3.18 driver probe!
[ 0.251218] mtk-msdc f0012000.MSDC1: ioremap host->base = 0xf0012000
[ 0.251227] mtk-msdc f0012000.MSDC1: ioremap host->sclk_base = 0xf000d32c
[ 0.251236] mtk-msdc f0012000.MSDC1: ioremap host->hclk_base = 0xf000d3a0
[ 0.251245] mtk-msdc f0012000.MSDC1: hw_func=SD
[ 0.251291] mtk-msdc f0012000.MSDC1: [msdc_select_clksrc|1465] -> select clk source 0(24000000Hz)
[ 0.251302] mtk-msdc f0012000.MSDC1: [msdc_select_clksrc|1465] -> select clk source 2(192000000Hz)
[ 0.251449] set ios, power_mode=1, bus_width=0, clock=0
[ 0.253659] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.254667] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.254969] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.254976] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.257446] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.266169] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.266178] ###set driving clk 5, cmd 5, dat 5
[ 0.266349] mtk-msdc f0012000.MSDC1: [msdc_set_mclk|1647] -> Set<400KHz> Source<192000KHz> -> real<400KHz> state<0> mode<0> div<120> hs400_src<0>
[ 0.281258] mtk-msdc: MediaTek MSDC Driver
[ 0.281296] [msdc_debug_proc_init]: successfully create /proc/msdc_debug
[ 0.281307] [msdc_debug_proc_init]: successfully create /proc/msdc_help
[ 0.281318] [msdc_debug_proc_init]: successfully create /proc/msdc_tune
[ 0.281329] [msdc_debug_proc_init]: successfully create /proc/msdc_tune_flag
[ 0.287019] msdc_register_ett => CONFIG_MTK_USE_NEW_TUNE & CONFIG_MTK_USE_LEGACY_TUNE all undefined!!!!!!!!!!!!!!!!
[ 0.287030] kernel get CID: 0x11010030, 0x30344736, 0x300293f2, 0x187cc499
[ 0.287339] set ios, power_mode=2, bus_width=0, clock=400000
[ 0.287886] mtk-msdc f006d000.MSDC0: [msdc_command_start|2059] -> msdc0 select card<0x00010000>
[ 0.299170] mmc0: BKOPS_EN bit enable
[ 0.300276] set ios, power00000
[ 0.300284] set ios, power_mode=2, bus_width=0, clock=50000000
[ 0.300294] ###set driving clk 5, cmd 5, dat 5
[ 0.301450] mtk-msdc f006d000.MSDC0: [msdc_set_mclk|1647] -> Set<50000KHz> Source<384000KHz> -> real<48000KHz> state<0> mode<0> div<2> hs400_src<0>
[ 0.301468] mtk-msdc f006d000.MSDC0: [msdc_command_resp_polling|2282] -> XXX CMD<6> MSDC_INT_CMDTMO Arg<0x03b70201>
[ 0.301482] mtk-msdc f006d000.MSDC0: [msdc_dump_trans_error|4117] -> XXX CMD<6><0x3b70201> Error<-110> Resp<0x0>
[ 0.301515] set ios, power_mode=2, bus_width=3, clock=50000000
[ 0.301854] ###init card OK###
[ 0.302133] partition overflow, boot0 not alloc device node
[ 0.302139] partition overflow, boot1 not alloc device node
[ 0.302214] mmcblk0rpmb: mmc0:0001 004G60 partition 3 512 KiB
[ 0.306019] mtk-msdc f0012000.MSDC1: [msdc_ops_get_cd|4797] -> Card insert<0> Block bad card<0>
[ 0.306s_wi
INIT: version 2.86 booting
Loading /etc/profile...
warning: can't open /etc/mtab: No such file or directory
none on /proc type proc (rw)
none on /sys type sysfs (rw)
none on /opt type tmpfs (rw)
none on /dev/shm type tmpfs (rw)
none on /var/run type tmpfs (rw)
Running rc.local...
/basic/3rd_ini/tvis/global_env_setup.ini: line 2:
: command not found
net.ipv4.tcp_window_scaling = 6
net.core.rmem_max = 1048576
° xxxxxxxxxxx°шHR xя
real0m0.761s
user0m0.000s
sys0m0.555s
Check 3rd_rw -yf...
e2fsck 1.41.14 (22-Dec-2010)
/dev/mmcblk0p13: recovering journal
Superblock last mount time is in the future.
(by less than a day, probably due to the hardware clock being incorrectly set) Fix? yes
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mmcblk0p13: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mmcblk0p13: 8743/32000 files (0.9% non-contiguous), 31213/128000 blocks
# mount 3rd DMVERITY(SquashFS read-only)
mount: block device /dev/mapper/dm-3 is write-protected, mounting read-only
real0m0.019s
user0m0.000s
sys0m0.000s
# mount 3rd_rw
# mount perm
Mount downloadable ...
real0m0.004s
user0m0.000s
sys0m0.000s
insmod arm mali ko
tty_mngr_init
Input: CLI
<Ctrl-I>: switch to mw_cli.
<Ctrl-A>: switch to app_man.
<quit>: switch to app_man.
Not first bootup
/basic/stress.sh: line 6: /tmp/debug/kmemleak: Permission denied
mali modules inserted OK!
commandline read: app_man
~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.5.3 |~~~~~~~~~~~~~~~~~~~~~~~~~~
(c) 2001-2010 The world wide DirectFB Open Source Community
(c) 2000-2004 Convergence (integrated media) GmbH
(*) DirectFB/Core: Multi Application Core. (Tue Jan 8 17:14:19 CST 2019)
(*) Direct/Memcpy: Using libc memcpy()
(*) Fusion/SHM: Using MADV_REMOVE (3.18.25.0 >= 2.6.19.2)
(*) Direct/Thread: Started 'Fusion Dispatch' (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
(*) Direct/Thread: Started 'Fusion Deferred' (-1) [MESSAGIN OTHHER/OTTER /0] <8388608>...
(*) DirectFB/MT53: DFB[vir=0x65c6f000,phy=0x65c6f000,size=0x3edf000]
(*) DirectFB/MT53: t_crsr[vir=0x69b4e000,phy=0x69b4e000,size=0xa000]
(!) DirectFB/MT53: FBIO_CRSR_INFO failed!
--> Invalid argument
(*) Direct/Thread: Started 'Virtual Input' (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
(*) DirectFB/Input: Virtual Input 0.0 (Convergence GmbH)
input thread's parent pid is 576 tid is 576
(*) Direct/Thread: Started 'RC Input' (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
(*) DirectFB/Input: MediaTek RC Input 0.1 (Denis Oliver Kropp)
[DirectFB]: Wait to Init IR...!
(*) Direct/Thread: Started 'Hotplug with Linux Input' (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
(*) DirectFB/Input: Hot-plug detection enabled with Linux Input Driver
(*) [NETEVT]open net evnet 0
(*) [NETEVT]create thread 0
(*) Direct/Thread: Started 'net event' (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
(*) [NETEVT]thread-0
(*) DirectFB/Input: DFB NetEvent Device 0.1 (Mediatek)
(*) MediaTek/Driver: Mapp[ 2.377066] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x3
[ 2.377332] mtk-msdc f006d000.MSDC0: [msdc_partition_encrypted|532] -> rpmb skip enc
[ 2.377731] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x0
[ 2.378123] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x3
[ 2.378640] mtk-msdc f006d000.MSDC0: [msdc_partition_encrypted|532] -> rpmb skip enc
[ 2.378721] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x0
[ 2.391283] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x3
[ 2.391331] mtk-msdc f006d000.MSDC0: [msdc_partition_encrypted|532] -> rpmb skip enc
[ 2.391405] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x0
[ 2.418802] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x3
[ 2.418936] mtk-msdc f006d000.MSDC0: [msdc_partition_encrypted|532] -> rpmb skip enc
[ 2.419767] mtk-msdc f006d000.MSDC0: [msdc_do_request|2775] -> partition_access is 0x0
ed shared command queue control structure to 0xb307d000
(*) MediaTek/Driver: Mapped DMA region to 0xb303d000
(*) MediaTek/Driver: GFX_CmdQueInit( 0xb307d000, 0x91750 )
(*) DirectFB/Graphics: MediaTek 53xx 0.3 (Denis Oliver Kropp)
(*) DirectFB/Core/WM: SaWMan 0.2 (directfb.org)
dfb_set_cursor_border [0,0-1920,0-1080]
(*) SaWMan/Config: Parsing config file '/etc/sawmanrc'.
(*) SaWMan: Initializing stack 0x40398600 for tier 0x544a3000, 0x0, layer 0, context 0x4008a000 [6]...
(*) SaWMan: Initializing stack 0x40398500 for tier 0x544a3800, 0x0, layer 1, context 0x4008aa00 [9]...
(*) SaWMan: Initializing stack 0x40398400 for tier 0x544a4000, 0x0, layer 2, context 0x4008a400 [12]...
(*) SaWMan/Init: Layer 0: 1280x720, ARGB, options: 0
(*) SaWMan/Init: Border 0: 426x240, LUT8, options: 8
(*) SaWMan/Init: Layer 1: 1280x720, ARGB, options: 0
(*) SaWMan/Init: Border 1: 426x240, LUT8, options: 8
(*) SaWMan/Init: Layer 2: 16x16, ARGB, options: 0
(*) SaWMan/Init: Border 2: 426x240, LUT8, options: 8
start to run task
[AM][ProcessControl.cpp][setState][2795]dtv_app_mtk:(4 -> 1 )
task finished
start to run task
[AM][ProcessControl.cpp][setState][2795]browser_base:(4 -> 9 )
task finished
start to run task
[AM][ProcessControl.cpp][setState][2795]netflix:(4 -> 9 )
task finished
start to run task
[AM][ProcessControl.cpp][setState][2795]dialserver:(4 -> 9 )
task finished
start to run task
[AM][ProcessControl.cpp][setState][2795]securetime:(4 -> 9 )
task finished
start to run task
[AM][ProcessControl.cpp][setState][2795]diskcache:(4 -> 9 )
[ERROR][SocketProcessControl.cpp:sendCmd]diskcache not init
task finished
[securetime]>[SECURETIME] [myThread:99]Secure time Thread ran!
[dialserver]>am client thread start
[Netflix] enter disk cache Main() new HQ
Start initDFB.
[AM][ProcessControl.cpp][setState][2795]diskcache:(9 -> 2 )
[dialserver]>[DIAL]YouTube is Running
[dialserver]>[DIAL]send am started
[dialserver]>
[dialserver]>[DIAL] am started out
[dialserver]>[DIAL]run dial...
[AM][ProcessControl.cpp][setState][2795]dialserver:(9 -> 2 )
(*) Direct/Thread: Started 'Fusion Deferred' (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
(*) Dir[ 2.716473] Unable to handle kernel paging request at virtual address 0000a840
[ 2.722880] pgd = c0004000
[ 2.725566] [0000a840] *pgd=00000000
[ 2.729127] Internal error: Oops: 80f [#1] PREEMPT SMP ARM
[ 2.734590] Modules linked in: mali mtk_mod(PO) fusion(O)
[ 2.739969] CPU: 0 PID: 523 Comm: DrvPanelPowerOn Tainted: P O 3.18.25 #1
[ 2.747790] task: c6d8a800 ti: c69dc000 task.ti: c69dc000
[ 2.754043] PC is at vIO32Write1BMsk+0x2c/0x38 [mtk_mod]
[ 2.760073] LR is at HalCriticalStart+0x1c/0xa4 [mtk_mod]
[ 2.763848] pc : [<bf0b491c>] lr : [<bf0b4eb8>] psr: 20000193
[ 2.763848] sp : c69ddee8 ip : 061a0619 fp : 00000000
[ 2.775288] r10: 00000000 r9 : 00000000 r8 : 00000000
[ 2.780496] r7 : 00000000 r6 : 00000019 r5 : 0000a840 r4 : 00000000
[ 2.787006] r3 : 00000019 r2 : 00000000 r1 : c69dded8 r0 : 60000113
[ 2.793517] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 2.800907] Control: 10c5383d Table: 0502806a DAC: 00000015
[ 2.806621]
[ 2.806621] SP: 0xc69dde68:
[ 2.810872] de68 c69dde9c c05c62c0 ffff17bf c005ca44 c69dde9c 80000113 00000000 bf0b491c
[ 2.819030] de88 20000193 ffffffff c69dded4 00000000 00000000 c0011c58 60000113 c69dded8
[ 2.827189] dea8 00000000 00000019 00000000 0000a840 00000019 00000000 00000000 00000000
[ 2.835347] dec8 00000000 00000000 061a0619 c69ddee8 bf0b4eb8 bf0b491c 20000193 ffffffff
[ 2.843504] dee8 00000000 bf91c5c8 00000000 c6aff900 bf5cac98 bf418e04 bf9144b4 bf414a2c
[ 2.851663] df08 bf92ffa0 bf454618 00000000 bf3b1740 00000000 00000000 bf5cac98 c6aff900
[ 2.859822] df28 00000000 bf3b180c 00000024 bf5bfe00 c6aff900 81530000 08ea0020 4d412402
[ 2.867980] df48 00000000 bf5cad40 00000000 00000000 0000020b 0000004a c6aff940 c0034704
[ 2.876140]
[ 2.876140] R1: 0xc69dde58:
[ 2.880391] de58 a199d4e0 00000000 00000000 c69dde9c c69dde9c c05c62c0 ffff17bf c005ca44
[ 2.888550] de78 c69dde9c 80000113 00000000 bf0b491c 20000193 ffffffff c69dded4 00000000
[ 2.896708] de98 00000000 c0011c58 60000113 c69dded8 00000000 00000019 00000000 0000a840
[ 2.904866] deb8 00000019 00000000 00000000 00000000 00000000 00000000 061a0619 c69ddee8
[ 2.913025] ded8 bf0b4eb8 bf0b491c 20000193 ffffffff 00000000 bf91c5c8 00000000 c6aff900
[ 2.921183] def8 bf5cac98 bf418e04 bf9144b4 bf414a2c bf92ffa0 bf454618 00000000 bf3b1740
[ 2.929342] df18 00000000 00000000 bf5cac98 c6aff900 00000000 bf3b180c 00000024 bf5bfe00
[ 2.937500] df38 c6aff900 81530000 08ea0020 4d412402 00000000 bf5cad40 00000000 00000000
[ 2.945662] Process DrvPanelPowerOn (pid: 523, stack limit = 0xc69dc238)
[ 2.952344] Stack: (0xc69ddee8 to 0xc69de000)
[ 2.956687] dee0: 00000000 bf91c5c8 00000000 c6aff900 bf5cac98 bf418e04
[ 2.964845] df00: bf9144b4 bf414a2c bf92ffa0 bf454618 00000000 bf3b1740 00000000 00000000
[ 2.973004] df20: bf5cac98 c6aff900 00000000 bf3b180c 00000024 bf5bfe00 c6aff900 81530000
[ 2.981162] df40: 08ea0020 4d412402 00000000 bf5cad40 00000000 00000000 0000020b 0000004a
[ 2.989320] df60: c6aff940 c0034704 dead0118 00000000 dead0118 c6aff900 00000000 00000000
[ 2.997479] df80: c69ddf80 c69ddf80 00000000 00000000 c69ddf90 c69ddf90 c69ddfac c6aff940
[ 3.005637] dfa0: c0034628 00000000 00000000 c000e100 00000000 00000000 00000000 00000000
[ 3.013795] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.021954] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 dead0118 dead0118
[ 3.031977] [<bf0b491c>] (vIO32Write1BMsk [mtk_mod]) from [<bf418e04>] (vDrvSCPQInit+0x98/0xc0 [mtk_mod])
[ 3.041626] [<bf418e04>] (vDrvSCPQInit [mtk_mod]) from [<bf414a2c>] (vDrvScposResume+0x4c/0xe8 [mtk_mod])
[ 3.051164] [<bf414a2c>] (vDrvScposResume [mtk_mod]) from [<bf454618>] (vDrvVideoOut_PM_Resume+0x3c/0xbc [mtk_mod])
[ 3.061570] [<bf454618>] (vDrvVideoOut_PM_Resume [mtk_mod]) from [<bf3b1740>] (vApiPanelPowerSequence+0x500/0x50c [mtk_mod])
[ 3.072761] [<bf3b1740>] (vApiPanelPowerSequence [mtk_mod]) from [<bf3b180c>] (LDR_PmxDisplayHWInit+0x74/0x78 [mtk_mod])
[ 3.083722] [<bf3b180c>] (LDR_PmxDisplayHWInit [mtk_mod]) from [<bf5bfe00>] (_ParallelInitThread+0x70/0x5ac [mtk_mod])
[ 3.094487] [<bf5bfe00>] (_ParallelInitThread [mtk_mod]) from [<bf5cad40>] (ThreadProc+0xa8/0xac [mtk_mod])
[ 3.103150] [<bf5cad40>] (ThreadProc [mtk_mod]) from [<c0034704>] (kthread+0xdc/0xf0)
[ 3.109883] [<c0034704>] (kthread) from [<c000e100>] (ret_from_fork+0x14/0x34)
[ 3.117080] Code: e5952000 e1a03187 e1c24314 e1843316 (e5853000)
[ 3.123148] Disable IRQ, CPU loops forever.
[ 3.127322] CPU1: stopping
[ 3.130011] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P O 3.18.25 #1
[ 3.137136] [<c0013bc8>] (unwind_backtrace) from [<c0011210>] (show_stack+0x10/0x14)
[ 3.144856] [<c0011210>] (show_stack) from [<c03d4608>] (dump_stack+0x8c/0xd0)
[ 3.152057] [<c03d4608>] (dump_stack) from [<c0013108>] (handle_IPI+0xd0/0x1e4)
[ 3.159346] [<c0013108>] (handle_IPI) from [<c0008610>] (gic_handle_irq+0x54/0x5c)
[ 3.166897] [<c0008610>] (gic_handle_irq) from [<c0011cc0>] (__irq_svc+0x40/0x74)
[ 3.174357] Exception stack(0xc7467fa0 to 0xc7467fe8)
[ 3.179395] 7fa0: c79ef2b0 00000000 00002b44 c0018480 c7466000 c7466030 10c0387d c05a1a4c
[ 3.187553] 7fc0: 0000406a 410fd032 00000000 00000000 00000000 c7467fe8 c000ecc4 c000ecc8
[ 3.195707] 7fe0: 60000113 ffffffff
[ 3.199185] [<c0011cc0>] (__irq_svc) from [<c000ecc8>] (arch_cpu_idle+0x2c/0x38)
[ 3.206564] [<c000ecc8>] (arch_cpu_idle) from [<c0047f88>] (cpu_startup_entry+0xe0/0x13c)
[ 3.214721] [<c0047f88>] (cpu_startup_entry) from [<000086a4>] (0x86a4)
[ 3.221311] CPU3: stopping
[ 3.224003] CPU: 3 PID: 0 Comm: swapper/3 Tainted: P O 3.18.25 #1
[ 3.231126] [<c0013bc8>] (unwind_backtrace) from [<c0011210>] (show_stack+0x10/0x14)
[ 3.238849] [<c0011210>] (show_stack) from [<c03d4608>] (dump_stack+0x8c/0xd0)
[ 3.246051] [<c03d4608>] (dump_stack) from [<c0013108>] (handle_IPI+0xd0/0x1e4)
[ 3.253341] [<c0013108>] (handle_IPI) from [<c0008610>] (gic_handle_irq+0x54/0x5c)
[ 3.260892] [<c0008610>] (gic_handle_irq) from [<c0011cc0>] (__irq_svc+0x40/0x74)
[ 3.268352] Exception stack(0xc746bfa0 to 0xc746bfe8)
[ 3.273390] bfa0: c7a012b0 00000000 00000fc6 c0018480 c746a000 c746a030 10c0387d c05a1a4c
[ 3.281548] bfc0: 0000406a 410fd032 00000000 00000000 00000000 c746bfe8 c000ecc4 c000ecc8
[ 3.289703] bfe0: 60000013 ffffffff
[ 3.293180] [<c0011cc0>] (__irq_svc) from [<c000ecc8>] (arch_cpu_idle+0x2c/0x38)
[ 3.300558] [<c000ecc8>] (arch_cpu_idle) from [<c0047f88>] (cpu_startup_entry+0xe0/0x13c)
[ 3.308714] [<c0047f88>] (cpu_startup_entry) from [<000086a4>] (0x86a4)
[ 3.315307] CPU2: stopping
[ 3.317999] CPU: 2 PID: 0 Comm: swapper/2 Tainted: P O 3.18.25 #1
[ 3.325122] [<c0013bc8>] (unwind_backtrace) from [<c0011210>] (show_stack+0x10/0x14)
[ 3.332844] [<c0011210>] (show_stack) from [<c03d4608>] (dump_stack+0x8c/0xd0)
[ 3.340046] [<c03d4608>] (dump_stack) from [<c0013108>] (handle_IPI+0xd0/0x1e4)
[ 3.347337] [<c0013108>] (handle_IPI) from [<c0008610>] (gic_handle_irq+0x54/0x5c)
[ 3.354887] [<c0008610>] (gic_handle_irq) from [<c0011cc0>] (__irq_svc+0x40/0x74)
[ 3.362347] Exception stack(0xc7469fa0 to 0xc7469fe8)
[ 3.367385] 9fa0: c79f82b0 00000000 000014ae c0018480 c7468000 c7468030 10c0387d c05a1a4c
[ 3.375543] 9fc0: 0000406a 410fd032 00000000 00000000 00000000 c7469fe8 c000ecc4 c000ecc8
[ 3.383698] 9fe0: 60000013 ffffffff
[ 3.387175] [<c0011cc0>] (__irq_svc) from [<c000ecc8>] (arch_cpu_idle+0x2c/0x38)
[ 3.394553] [<c000ecc8>] (arch_cpu_idle) from [<c0047f88>] (cpu_startup_entry+0xe0/0x13c)
[ 3.402709] [<c0047f88>] (cpu_startup_entry) from [<000086a4>] (0x86a4)
And Justice for All
 Заголовок сообщения: Re: Philips 50PVS6262/60 (TPM17.7E LA) что то не так с ОЗУ?
СообщениеДобавлено: 24 фев 2020, 20:28
Ctrl-I, Ctrl-A ни как не влияет на загрузку.
И как понимаю из лога, это 3 канала памяти:
Как то можно проверить память из загрузчика? На самой плате все напряжения присутствуют. Думали прошивка, притащили ко мне, а вот фигвам.
And Justice for All
СообщениеДобавлено: 16 апр 2020, 07:30
Пришла рабочая плата, подключил, посмотрел лог, все верно, один канал видит только половину ОЗУ.
Лог
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.04.16 10:01:03 =~=~=~=~=~=~=~=~=~=~=~=
Boot-
DRAM B Size = 1024 Mbytes.
Boot
Start Pmain
EMMC boot
CID:0x517eb4df
:0x30029ace
:0x30344736
:0x11010030
LZHS size:0x000fa6f8
LZHS size:0x0005c644
LZHS checksum:0x0000009e
LZHS begin
LZHS ok
Boot
Start Lmain
MUSB_Init : ++
Support network!1st MAC in EEP is valid (70:af:24:63:a1:20)
1st : (70:af:24:63:a1:20)
2nd : (70:af:24:63:a1:20)
POWER ON
EEPDTV_GetCfg
EEPDTV_GetCfg
EEPDTV_GetCfg
Load T8032 FW (addr: 0x d61cc8, size: 21781)success!!
° xxxxxxxxxxьT8032 FW version: 11
LDR_FlashCopy 0xf010 0x66a00 0x80
[MSDC] Init config, cid = 0x11010030, dsc=0x517eb4df, rca=0x30029ace, ocr=0x30344736
[MSDC] MT22662:11010030:30344736:30029ace:517eb4df
[MSDC] Support HS400, card type ext_csd[196]0x57
[MSDC] Support HS200, card type ext_csd[196]0x57
[MSDC] u4mask = 0x3
[MSDC]
Cur info: id1 = 0xb4df3002, id2=0x9ace3034,flag 0xaabbccdd,speedmode 5, dlycell 72
[MSDC]
-----The information is match, Alrady run autok before, ignore this time--
[MSDC] Load Param:
[MSDC] K_IOCON: 0x200000a
[MSDC] K_PAD_TUNE0: 0x102c2000
[MSDC] K_PAD_TUNE1: 0x0
[MSDC] K_PATCH_BIT0: 0x403c0006
[MSDC] K_PATCH_BIT1: 0xfffe4349
[MSDC] K_PATCH_BIT2: 0x848a1803
[MSDC] K_EMMC50_CFG0: 0xe889f2
[MSDC] K_DATphy=0x8a55f000,size=0xa000]
(*) Direct/Thread: Started &#39;Virtual Input&#39; (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
input thread&#39;s parent pid is 628 tid is 628
(*) Direct/Thread: Started &#39;RC Input&#39; (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
(*) Direct/Thread: Started &#39;Hotplug with Linux Input&#39; (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
(*) Direct/Thread: Started &#39;net event&#39; (-1) [INPUT OTHER/OTHER 0/0] <8388608>...
(*) MediaTek/Driver: Mapped shared command queue control structure to 0xb2fcc000
(*) MediaTek/Driver: Mapped DMA region to 0xb2f8c000
(*) MediaTek/Driver: GFX_CmdQueInit( 0xb2fcc000, 0xadec0 )
(*) SaWMan/Config: Parsing config file &#39;/etc/sawmanrc&#39;.
mali memory_usage_confugured
start to run task
[AM][ProcessControl.cpp][setState][2962][tid677]dtv_app_mtk:(4 -> 1 )
task finished
start to run task
[AM][ProcessControl.cpp][setState][2962][tid677]browser_base:(4 -> 9 )
task finished
start to run task
task finished
start to run task
[AM][ProcessControl.cpp][setState][2962][tid677]dialserver:(4 -> 9 )
task finished
start to run task
[AM][ProcessControl.cpp][setState][2962][tid677]securetime:(4 -> 9 )
task finished
[dialserver]>
[dialserver]>[DIAL][MS_CLIENT_init][multi_screen_client.c][341][685] Enter
[dialserver]>[DIAL][mtk_ntv_client_init][multi_screen_client.c][129][685]Enter
[AM][ProcessControl.cpp][setState][2962][tid687]dialserver:(9 -> 2 )
[dialserver]>commandline read: dialserver
[dialserver]>
[dialserver]> *--------------) FusionDale v0.8.1 (--------------*
[dialserver]> (c) 2006-2007 directfb.org
[dialserver]> -----------------------------------------------
[dialserver]>
[dialserver]>(*) Fusion/SHM: Using MADV_REMOVE (3.18.25.0 >= 2.6.19.2)
[dialserver]>(*) Direct/Thread: Started &#39;Fusion Dispatch&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[dialserver]>(*) Direct/Thread: Started &#39;Fusion Deferred&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[dialserver]>[DIAL][mtk_ntv_client_register_listener][multi_screen_client.c][199][685] Enter, ntvcoma_client = 0x38c58
[dtv_app_mtk]>InitDRM
[dtv_app_mtk]>sh: /basic/bin/mtk_indicator: No such file or directory
° xxxxxxxxxxь[dtv_app_mtk]>[MWIF2-VDP]register src chg call back in vdp_if2
[browser_base]>[bws_app][Default][L1034]main : Browser Process Enter
[browser_base]>[bws_app][Default][L2264]ParseCommonProfile : load profile fail /3rd_rw/internet_browser/browser_config.ini: 1
[browser_base]>[xbrowser][x_browser_log_enable][8223][681]enable x_browser error log output
[browser_base]>[bws_app][Critical][L2312]ParseCommonProfile : u4OperaArgNum= 13
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[0]= --hw-dfb
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[1]= --disable-hbbtv-security-manager
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[2]= --disable-databases
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[3]= --enable-spatial-navigation
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[4]= --allow-file-access-from-files
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[5]= --dfb-window-mode
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[6]= --enable-impl-side-painting
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[7]= --dfb-memory-limit-mb=80
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[8]= --dfb-compositor-memory-limit-mb=80
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[9]= --http-cache-size=20
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[10]= --allow-running-insecure-content
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[11]= --log-level=0
[browser_base]>[bws_app][Critical][L2360]ParseCommonProfile : opera_argv[12]= --unsafely-treat-insecure-origin-as-secure=http://app.10ft.itv.com/,http://discoveryapp-staging.cloud.digitaluk.co.uk,http://refplayer.cloud.digitaluk.co.uk,http://ic.c4assets.com
[browser_base]>[bws_app][Critical][L2380]ParseCommonProfile : sMemLimit is 419430400
[browser_base]>[bws_app][Critical][L2408]ParseCommonProfile : Rendering backend info, type(1), [w, h]=[1920, 1080], layer(2)
[browser_base]>[bws_app][Critical][L1324]Parse_Arguments : opera_run = ui_html5
[browser_base]>/3rd/internet_browser/browser: unrecognized option &#39;--allow-running-insecure-content&#39;
[browser_base]>/3rd/internet_browser/browser: unrecognized option &#39;--dfb-explicit-double-buffer&#39;
[browser_base]>/3rd/internet_browser/browser: unrecognized option &#39;--with-feature:ooif-renderer-aware=off&#39;
[browser_base]>/3rd/internet_browser/browser: unrecognized option &#39;--hw-dfb&#39;
[browser_base]>/3rd/internet_browser/browser: unrecognized option &#39;--v8-cache-option=code&#39;
[browser_base]>/3rd/internet_browser/browser: unrecognized option &#39;--http-cache-size=20&#39;
[browser_base]>/3rd/internet_browser/browser: unrecognized option &#39;--log-level=0&#39;
[browser_base]>[bws_app][Critical][L1521]Init : Enter
[browser_base]>[bws_app][Default][L3320]am_init : Init AM client with name browser_base
[browser_base]>am client thread start
[browser_base]>[bws_app][Critical][L1560]Init : OPERA_HOME: /3rd_rw/internet_browser/opera_home
[browser_base]>[bws_app][Critical][L1563]Init : OPERA_DIR: /3rd/browser_engine/opera_dir
[browser_base]>/3rd/browser_engine/setup_fontconfig.sh: Please wait while Fontconfig updates its cache...
[browser_base]>/3rd/browser_engine/setup_fontconfig.sh: The cache is up to date.
[browser_base]>[bws_app][Critical][L1575]Init : cmd(cp -rf /3rd/internet_browser/userjs/* /tmp/browser/userjs; sync)
[browser_base]>[bws_app][Critical][L1213]_set_time_zone : tz(0) dst(0) tz_string(UTC+0:00)
[browser_base]>[bws_app][Critical][L1590]Init : call c_opera_hbbtv_reg_browser_com_nfy to register callback to communicate with dtv_svc, ret=0
[browser_base]>[bws_app][Critical][L1594]Init : Call c_opera_hbbtv_release_res to release HbbTV resource!
[browser_base]>initUIHtml5Layer: ENTER
[browser_base]>[bws_app][Critical][L4619]chk_root_ca_file : Debug executing command -- md5sum -c /3rd_rw/internet_browser/opera_home/cert9.db_from_3rd.md5 -s
[browser_base]>[bws_app][Critical][L4620]chk_root_ca_file : Debug executing command -- md5sum -c /3rd_rw/internet_browser/opera_home/cert9.db_from_3rd.md5 -s
[browser_base]>sh: md5sum: command not found
[dtv_app_mtk]>[ FakeDM ] Init...
[dtv_app_mtk]>
[FakeDM] Init FM...
[dtv_app_mtk]>
/dev is created./mnt is already existed. That is OK.
[dtv_app_mtk]>
/mnt/usb is created.[FakeDM] FM inited...
[dtv_app_mtk]>
[DM]libmtp version: 0.3.6
[dtv_app_mtk]>
[browser_base]>[bws_app][Critical][L4626]chk_root_ca_file : Check integrity by /3rd_rw/internet_browser/opera_home/cert9.db_from_3rd.md5 or /3rd_rw/internet_browser/opera_home/key4.db_from_3rd.md5 NG
[browser_base]>[bws_app][Default][L4630]chk_root_ca_file : Executing cp -p /3rd/internet_browser/opera_home/.pki/nssdb/cert9.db /3rd_rw/internet_browser/opera_home/.pki/nssdb
[dtv_app_mtk]>
[DM] _dm_cb_msg_thread enter
[dtv_app_mtk]>
[DM] _dm_cb_ex_msg_thread enter
[dtv_app_mtk]>
[DM] _dm_nfy_req_thread enter
[dtv_app_mtk]>
[DM] _dm_open_dev_thread: entered
[dtv_app_mtk]>
[FakeDM] Init DLNA...
[dtv_app_mtk]>
[DM] _dm_mhl_oc_thread: entered
[dtv_app_mtk]>
[FakeDM] DLNA inited...
[dtv_app_mtk]>
[FakeDM] Init SMB...
[dtv_app_mtk]>
[DM] _dm_nfy_req_thread get_nl_sock:24
[dtv_app_mtk]>
[FakeDM] SMB inited...
[dtv_app_mtk]>
[FakeDM] do coldboot start...
[dtv_app_mtk]>mount: mount point /proc/bus/usb does not exist
[dtv_app_mtk]>
[DM] usbfs mounted.
[dtv_app_mtk]>
_dm_get_attr_product_id filename = /sys/devices/platform/MtkUsbHcd.0/idProduct .
[dtv_app_mtk]>
{<DM>} [_dm_get_attr_product_id:995] open idProduct fail, errno = No such file or directory
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/devices/platform/MtkUsbHcd.0/idVendor .
[dtv_app_mtk]>
{<DM>} [_dm_get_attr_vendor_id:1036] open idVendor fail, errno = No such file or directory
[dtv_app_mtk]>
{<DM>} [dm_mtp_get_dev_pvid:552] ui2_product_id = 0, ui2_vendor_id = 0
[dtv_app_mtk]>
[is_mtp_device_be_handled:425] Parse device PVID fail, ret = -1
[dtv_app_mtk]>
_dm_get_attr_product_id filename = /sys/devices/platform/MtkUsbHcd.1/idProduct .
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/devices/platform/MtkUsbHcd.1/idVendor .
[dtv_app_mtk]>
[dtv_app_mtk]> ~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.5.3 |~~~~~~~~~~~~~~~~~~~~~~~~~~
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]> (c) 2001-2010 The world wide DirectFB Open Source Community
[dtv_app_mtk]> (c) 2000-2004 Convergence (integrated media) GmbH
[dtv_app_mtk]>
[dtv_app_mtk]> ----------------------------------------------------------------
[dtv_app_mtk]>
[dtv_app_mtk]>(*) DirectFB/Core: Multi Application Core. (Thu Mar 28 19:17:53 CST 2019)
[dtv_app_mtk]>
_dm_get_attr_product_id filename = /sys/devices/platform/MtkUsbHcd.1/usb4/idProduct .
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/devices/platform/MtkUsbHcd.1/usb4/idVendor .
[dtv_app_mtk]>
start dm_mount mtpvolume.
[dtv_app_mtk]>(*) Direct/Memcpy: Using libc memcpy()
[dtv_app_mtk]>(*) Fusion/SHM: Using MADV_REMOVE (3.18.25.0 >= 2.6.19.2)
[dtv_app_mtk]>
[FakeDM] do coldboot end!!!
[dtv_app_mtk]>
Call simple-mtpfs shell script...
[dtv_app_mtk]>(*) Direct/Thread: Started &#39;Fusion Dispatch&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[dtv_app_mtk]>(*) Direct/Thread: Started &#39;Fusion Deferred&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[dtv_app_mtk]>{<DM>} [dm_simple_mtpfs_mount:661] mtp mount fail, exit code: 1
[dtv_app_mtk]>
[DM]Mnt path empty.
[dtv_app_mtk]>
_dm_get_attr_product_id filename = /sys/devices/soc/f00d4000.ssub1/idProduct .
[dtv_app_mtk]>(*) DirectFB/MT53: DFB[vir=0x8a569000,phy=0x8a569000,size=0x48a9000]
[dtv_app_mtk]>
[dtv_app_mtk]>(*) DirectFB/MT53: t_crsr[vir=0x8a55f000,phy=0x8a55f000,size=0xa000]
[dtv_app_mtk]>(!) DirectFB/MT53: FBIO_CRSR_INFO failed!
[dtv_app_mtk]> --> Invalid argument
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/devices/soc/f00d4000.ssub1/idVendor .
[dtv_app_mtk]>
[dtv_app_mtk]>(*) MediaTek/Driver: Mapped shared command queue control structure to 0xaef03000
[dtv_app_mtk]>(*) MediaTek/Driver: Mapped DMA region to 0xa567f000
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>(*) MediaTek/Driver: GFX_CmdQueInit( 0xaef03000, 0xabec2ed0 )
[dtv_app_mtk]>(*) DirectFB/Graphics: MediaTek 53xx 0.3 (Denis Oliver Kropp)
[dtv_app_mtk]>dfb_set_cursor_border [0,0-1920,0-1080]
[dtv_app_mtk]>
[dtv_app_mtk]>(*) SaWMan/Config: Parsing config file &#39;/etc/sawmanrc&#39;.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_product_id filename = /sys/devices/soc/idProduct .
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/devices/soc/idVendor .
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_product_id filename = /sys/devices/soc/f00d0000.ssusb1-phy/phy/idProduct .
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/devices/soc/f00d0000.ssusb1-phy/phy/idVendor .
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p1
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p1
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p2
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p2
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p3
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p3
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p4
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p4
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p5
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p5
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p6
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p6
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p7
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p7
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p8
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p8
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p9
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p9
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0rpmb
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0rpmb
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p10
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p10
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p11
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p11
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p12
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p12
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p13
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p13
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p14
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p14
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p15
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p15
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p16
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p16
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p17
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p17
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p18
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p18
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p19
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p19
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p20
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p20
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p21
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p21
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p22
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p22
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p23
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p23
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p24
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p24
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p25
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p25
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p26
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p26
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p27
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p27
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p28
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p28
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p29
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p29
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p30
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p30
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p31
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p31
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p32
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p32
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p33
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p33
[dtv_app_mtk]>
[DM]..... ..... dev_name is mmcblk0/mmcblk0p34
[dtv_app_mtk]>
[DM]Dev changed:Add mmcblk0p34
[dtv_app_mtk]>
ci_oceanblue_initCred TZ no perm, get file length 5124
[dtv_app_mtk]>
ci_oceanblue_initCred data1 69 data2 131
[dtv_app_mtk]>
{CI_glue}- host burned PROD key
[dtv_app_mtk]>
88888888888888 PHYSICAL_Init() entered 888888888888888
[dtv_app_mtk]>
88888888888888 ITC_Init() entered 888888888888888
[dtv_app_mtk]>
[dtv_app_mtk]>
ci_oceanblue_readAuthContext ui2_src_length 0
[dtv_app_mtk]>
[dtv_app_mtk]>
ci_oceanblue_readAuthContext before _ci_oceanblue_read_file
[dtv_app_mtk]>
ci read file fail: -1, F:ci_oceanblue_storage.c, L:294
[dtv_app_mtk]>
[dtv_app_mtk]>
ci_oceanblue_readAuthContext _ci_oceanblue_read_file failed -1
[dtv_app_mtk]>
88888888888888 PHYS_DRVOpen() entered 888888888888888
[dtv_app_mtk]>
EEPROM size is 0x70.
[dtv_app_mtk]>
[SCC] _scc.c:1158 x_sema_create h_scc_lock:16862583 success
[dtv_app_mtk]>
{CDB} Can not create a handle to DB object [name: FLM_MASTER_LIST]
[dtv_app_mtk]>
{_dfb_enable_layer}t_op.u.set_plane.i4_idx=1, b_enable=0
[dtv_app_mtk]>
[* GL DFB *] Create plane (ON layer) :1014d2f
[browser_base]>[bws_app][Default][L4635]chk_root_ca_file : Executing cp -p /3rd/internet_browser/opera_home/.pki/nssdb/key4.db /3rd_rw/internet_browser/opera_home/.pki/nssdb
[AM][ProcessControl.cpp][setState][2962][tid642]browser_base:(9 -> 2 )
stacking [0x0], layer_id [0]
[browser_base]>am client init [browser_base]
[browser_base]>[bws_app][Default][L4642]chk_root_ca_file : Executing md5sum cert9.db_from_3rd.md5 > /3rd_rw/internet_browser/opera_home/cert9.db_from_3rd.md5
[browser_base]>[bws_app][Default][L4647]chk_root_ca_file : Executing md5sum key4.db_from_3rd.md5 > /3rd_rw/internet_browser/opera_home/key4.db_from_3rd.md5
[browser_base]>[bws_app][Critical][L3946]net_detect_init : create net_detect_thread successfully
[browser_base]>[bws_app][Critical][L3835]net_detect_thread : Enter
[browser_base]>[bws_app][Critical][L3839]net_detect_thread : name(browser_net_det), tid(935), id(-1360763904)
[browser_base]>[xbrowser][_bws_ipc_receiver_main][185][956]_bws_ipc_receiver_main, thread id -1369152512
[browser_base]>[xbrowser][_bws_ipc_receiver_main][189][956]_bws_ipc_receiver_main,ident in thread tid is :956
[browser_base]>_BWSInitStuffs[L343]Enter_BWSCoreThread[L300]Enter
[browser_base]> ~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.5.3 |~~~~~~~~~~~~~~~~~~~~~~~~~~
[browser_base]> (c) 2001-2010 The world wide DirectFB Open Source Community
[browser_base]> (c) 2000-2004 Convergence (integrated media) GmbH
[browser_base]> ----------------------------------------------------------------
[browser_base]>
[browser_base]>(*) DirectFB/Core: Multi Application Core. (Thu Mar 28 19:17:53 CST 2019)
[browser_base]>(*) Direct/Memcpy: Using libc memcpy()
[browser_base]>(*) Fusion/SHM: Using MADV_REMOVE (3.18.25.0 >= 2.6.19.2)
[browser_base]>(*) Direct/Thread: Started &#39;Fusion Dispatch&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[browser_base]>(*) Direct/Thread: Started &#39;Fusion Deferred&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[browser_base]>(*) DirectFB/MT53: DFB[vir=0x8a569000,phy=0x8a569000,size=0x48a9000]
[browser_base]>(*) DirectFB/MT53: t_crsr[vir=0x8a55f000,phy=0x8a55f000,size=0xa000]
[browser_base]>(!) DirectFB/MT53: FBIO_CRSR_INFO failed!
[browser_base]> --> Invalid argument
[browser_base]>(*) MediaTek/Driver: Mapped shared command queue control structure to 0xace3c000
[browser_base]>(*) MediaTek/Driver: Mapped DMA region to 0xacdfc000
[browser_base]>(*) MediaTek/Driver: GFX_CmdQueInit( 0xace3c000, 0x1378d8 )
[browser_base]>(*) DirectFB/Graphics: MediaTek 53xx 0.3 (Denis Oliver Kropp)
[browser_base]>dfb_set_cursor_border [0,0-1920,0-1080]
[browser_base]>(*) SaWMan/Config: Parsing config file &#39;/etc/sawmanrc&#39;.
[browser_base]>[0101/020004.083884:INFO:opera.cc(204)] Creating Opera instance...
[browser_base]>[681:960:0101/020004.177899:4038932:INFO:tv_memory_allowance_controller.cc(67)] Memory controller enabled. Allowance: 400MB
[browser_base]>Initializing Opera 4.11.3.57.Wagoner2.279 (aeb3b0dcb9ce43f7283d96f6b91139f17d7a19ff) [ pid = 681 ] ...
[browser_base]>Device Model Name = Philips-MTK5802-2k18
[browser_base]>[681:960:0101/020004.375947:4236978:WARNING:opera.cc(116)] /3rd/internet_browser/chrome-sandbox does not exist
[browser_base]>[681:960:0101/020004.376016:4237024:INFO:opera.cc(437)] Disabling the setuid sandbox, since it&#39;s not available
[browser_base]>[681:960:0101/020004.393873:4254904:INFO:shell_main_delegate.cc(293)] Chosen locale file: /3rd/browser_engine/opera_dir/locale/en-US.pak
[browser_base]>[681:960:0101/020004.444982:4306012:ERROR:zygote_host_impl_linux.cc(107)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chrom ... lopment.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.
[browser_base]>[991:991:0101/020004.554283:4415601:INFO:tv_memory_allowance_controller.cc(67)] Memory controller enabled. Allowance: 400MB
[browser_base]>[991:991:0101/020004.562431:4423463:INFO:shell_main_delegate.cc(293)] Chosen locale file: /3rd/browser_engine/opera_dir/locale/en-US.pak
[browser_base]>[681:960:0101/020004.604163:4465198:INFO:shell_browser_main_parts.cc(363)] Using DirectFB backend.
[browser_base]>[681:960:0101/020004.604272:4465280:INFO:shell_browser_main_parts.cc(271)] Sandbox raw status=0 suid=0 namespace=0 pid=0 net=0 seccomp=0 tsync=0 yama=0 layer1=bad layer2=bad
[browser_base]>[681:1023:0101/020004.914392:4775431:INFO:url_filter.cc(286)] /3rd_rw/internet_browser/opera_home/url-filter.json doesn&#39;t exist. All URLs will be allowed.
[browser_base]>[681:960:0101/020004.978517:4839564:WARNING:proxy_service.cc(1545)] Failed to choose a system proxy settings fetcher for this platform.
[browser_base]>[681:1031:0101/020004.989221:4850285:ERROR:njse_loader.cc(61)] Plugin &#39;/3rd/browser_engine/opera_dir/jsplugins/controller.so&#39; not found. Skipping.
[browser_base]>[681:1031:0101/020004.989505:4850519:INFO:njse_loader.cc(69)] Loading plugin: /3rd/browser_engine/opera_dir/jsplugins/AvodQosPlugin.so
[browser_base]>[681:1031:0101/020004.996193:4857230:ERROR:njse_plugin.cc(53)] Error loading plugin &#39;/3rd/browser_engine/opera_dir/jsplugins/AvodQosPlugin.so&#39;: /3rd/browser_engine/opera_dir/jsplugins/AvodQosPlugin.so: undefined symbol: Avod_Socket_playready_sendmsg
[browser_base]>[681:1031:0101/020004.996417:4857428:INFO:njse_loader.cc(69)] Loading plugin: /3rd/browser_engine/opera_dir/jsplugins/spotifyjsplugin.so
[browser_base]>[681:960:0101/020005.052098:4913149:ERROR:directfb_surface_transport_factory.cc(346)] Not implemented reached in virtual void content::DirectFBSurfaceTransportFactory::SetDisplayColorSpace(ui::Compositor*, const gfx::ColorSpace&, const gfx::ColorSpace&)
[browser_base]>[681:960:0101/020005.052604:4913634:INFO:omi_window_manager.cc(666)] Watermark: disabled
[browser_base]>Pid:[681] Tid:[957] [CBWSSurface][ERROR][CreateForegroundSurface][279]CBwsSurface::CreateForegroundSurface, w 1920, h 1080
[browser_base]>[681:1031:0101/020005.136519:4997544:INFO:njse_loader.cc(69)] Loading plugin: /3rd/browser_engine/opera_dir/jsplugins/tvapi_jsplugin.so
[browser_base]>
[browser_base]> <dmsdetect>: dmsdetect/DmsDetectClass.cpp | 142 | Info | DmsDetectClass : DmsDetectClass, pid=681.
[browser_base]>.
[browser_base]>
[browser_base]> <sqlite>: ListScan.cpp | 104 | Info |
[browser_base]>ListScanClass() getpid() = 681.
[browser_base]>.
[browser_base]>[TVC_JSP] [jsplugin_init][8209] --> start TV jsplugin_init
[browser_base]>[TVC_MAIN][mtk_tvc_read_log_lvl][120] --default tvc log level: 0.
[browser_base]>
[browser_base]>[CB_SCAN] a_mtktvapi_cb_usb_detect_init pid=681.
input thread pid is 628 tid is 646
[browser_base]>
[AM][ProcessControl.cpp][setState][2962][tid642]dtv_app_mtk:(1 -> 2 )
[AM][AppManager.cpp][__am_switch_focus][1602][tid642]Switch focus to process dtv_app_mtk!! window 0x4039a800
[browser_base]>
[dtv_app_mtk]>
{_dfb_enable_layer}t_op.u.set_plane.i4_idx=3, b_enable=0
[browser_base]>[CB_SCAN] a_mtktvapi_cb_usb_detect_register_callback pid=681.pv_fct=0x9d6ec460
[browser_base]>
[browser_base]>[TVC_JSP] [jsplugin_init][8227] --> call a_dtv_jsp_init ret: 0.
original scheduler policy 0
[dtv_app_mtk]>
[* GL DFB *] Create plane (ON window (Shared)) :1014d2d
[browser_base]>[TVC_MAIN][_jsp_read_log_lvl][214] --default jsp log level: 0 interval=200
[dtv_app_mtk]>
DVB_SI_TKGS x_dvb_si_init 1823
[browser_base]>[TVC_JSP] [jsplugin_init][8248] --> end of TV jsplugin_init
scheduler nice 0
[dtv_app_mtk]>
[browser_base]>[681:1031:0101/020005.262763:5124006:INFO:njse_loader.cc(69)] Loading plugin: /3rd/browser_engine/opera_dir/jsplugins/flingoplugin.so
[dtv_app_mtk]> *--------------) FusionDale v0.8.1 (--------------*
original child scheduler policy 0 prio 0
[dtv_app_mtk]> (c) 2006-2007 directfb.org
[browser_base]>[681:1031:0101/020005.264441:5125707:INFO:njse_loader.cc(69)] Loading plugin: /3rd/browser_engine/opera_dir/jsplugins/huluplugin.so
[dtv_app_mtk]>
dvb_si_cli h_table_msg_q=16862447 h_table_root=16862444
[dtv_app_mtk]>
====Dump dvbs scan engine&#39;s config====
new child scheduler policy 2 prio 99
[browser_base]>[681:1031:0101/020005.265817:5127062:ERROR:njse_plugin.cc(53)] Error loading plugin &#39;/3rd/browser_engine/opera_dir/jsplugins/huluplugin.so&#39;: /3rd/browser_engine/opera_dir/jsplugins/huluplugin.so: undefined symbol: iHuluDbgEnable
[dtv_app_mtk]>
DVBS_CFG_IS_FULL_SCAN_SEQ_H_OVER_V =0
Start to wait IR event...
[browser_base]>[681:1031:0101/020005.265998:5127222:INFO:njse_loader.cc(69)] Loading plugin: /3rd/browser_engine/opera_dir/jsplugins/libwebaudio_jsp.so
[browser_base]>[681:1031:0101/020005.280273:5141516:INFO:njse_loader.cc(69)] Loading plugin: /3rd/browser_engine/opera_dir/jsplugins/SamTV_JSP.so
[browser_base]>[681:960:0101/020005.459865:5321111:ERROR:directfb_surface_transport_factory.cc(346)] Not implemented reached in virtual void content::DirectFBSurfaceTransportFactory::SetDisplayColorSpace(ui::Compositor*, const gfx::ColorSpace&, const gfx::ColorSpace&)
[browser_base]>Pid:[681] Tid:[681] [PIMGR][ERROR][vStrmMgr_Init][1613]Leave,vStrmMgr_Init, already inited
[browser_base]>[bws_app][Default][L3550]GoForegroundFromBackground : Enter
[browser_base]>[bws_app][Default][L3553]GoForegroundFromBackground : eLastWebType=0, eWebType=13
[browser_base]>[bws_app][Critical][L4736]ResetWindowInfo : Enter
[browser_base]>[bws_app][Critical][L2420]ParseAppProfile : Enter
[browser_base]>[bws_app][Critical][L2615]ParseAppProfile : sAppProfilePath is /3rd/internet_browser/apps/ui_720p/bws_profile.ini
[browser_base]>[bws_app][Critical][L2637]ParseAppProfile : sName is
[browser_base]>[bws_app][Critical][L2646]ParseAppProfile : eWindowType=1
[browser_base]>[bws_app][Critical][L2659]ParseAppProfile : width=1280
[dtv_app_mtk]>
[browser_base]>[bws_app][Critical][L2672]ParseAppProfile : height=720
[browser_base]>[bws_app][Critical][L2685]ParseAppProfile : fgIsTransparent=1
[browser_base]>[bws_app][Critical][L2698]ParseAppProfile : fgDisableSpatialNav=1
[dtv_app_mtk]>
DVBS_CFG_IS_MULTILINGUAL_SERVICE_NAME =0
[browser_base]>[bws_app][Critical][L2711]ParseAppProfile : fgDisableDefaultErrorPage=-1
[browser_base]>[bws_app][Critical][L2726]ParseAppProfile : sErrorPagePath=
[browser_base]>[bws_app][Critical][L2734]ParseAppProfile : fgIsDisableKeyboard=-1
[dtv_app_mtk]>
DVBS_CFG_IS_HEVC_SERVICE =1
[browser_base]>[bws_app][Critical][L2749]ParseAppProfile : fgEnableMouse=0
[dtv_app_mtk]>
DVBS_CFG_IS_SINGLE_TP_SCAN_NOT_DELETE_SERVICE =1
[browser_base]>[bws_app][Critical][L2762]ParseAppProfile : fgSetPlaybackInfo=-1
[dtv_app_mtk]>[MTDT][_mtdt_read_log_lvl][28] -- default log level: 8
[browser_base]>[bws_app][Critical][L2774]ParseAppProfile : fg_EME_DRM_Type=-1
[dtv_app_mtk]>[WIFI_MW]
[dtv_app_mtk]>
[browser_base]>[bws_app][Critical][L2786]ParseAppProfile : fg_supportVP9=-1
[dtv_app_mtk]>x_wifi_cli_init~~~
[browser_base]>[bws_app][Critical][L2798]ParseAppProfile : fg_support4K=-1
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Default][L2810]ParseAppProfile : fg_supportHDR=-1
[dtv_app_mtk]>insmod: can&#39;t read &#39;/lib/modules/mtk-hcd.ko&#39;: No such file or directory
[browser_base]>[bws_app][Critical][L2835]ParseAppProfile : fgCheckTypeSupported=-1
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Critical][L3039]ParseAppProfile : sBgColor=#000000
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Critical][L3056]ParseAppProfile : fgEnableLoadingIcon is not set, default as true
[dtv_app_mtk]>
[browser_base]>[bws_app][Critical][L3070]ParseAppProfile : fgSupportPreload=0
[dtv_app_mtk]>
DVBS_CFG_IS_SAVE_SCAN_CONFIG_BY_TSL =1
[browser_base]>[bws_app][Critical][L3084]ParseAppProfile : sURL is file:///3rd/html5/index.html
[dtv_app_mtk]>
DVBS_CFG_IS_FILL_GAP =0
[dtv_app_mtk]>===================
[dtv_app_mtk]>dfb_key_lan_load_keymap(rus,(null))
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
DVBS_CFG_IS_ASU_NOT_DEL_MUX_FOR_DEF_NETWORK_FULL =0
[dtv_app_mtk]>
DVBS_CFG_IS_ASU_UPD_SVL_FOR_CANCEL_OPERATION =0
[dtv_app_mtk]>
DVBS_CFG_IS_SAT_SEARCH_DETECT_ORBIT_BY_FULL_SCAN =1
[dtv_app_mtk]>
DVBS_CFG_IS_MUX_IDENTIFI_RULE1 =1
[dtv_app_mtk]>
DVBS_CFG_IS_MUX_IDENTIFI_RULE2 =0
[dtv_app_mtk]>
DVBS_CFG_IS_SERVICE_IDENTIFI_RULE_ONID_TSID_SVCID =0
[dtv_app_mtk]>
DVBS_CFG_IS_NON_LCN_FULL_SCAN_NOT_LOAD_NITa =1
[dtv_app_mtk]>
DVBS_CFG_IS_SCAN_PROGRESS_NON_ZERO =1
[dtv_app_mtk]>
DVBS_CFG_IS_DYN_UPDATE_MUX_INFO =0
[dtv_app_mtk]>
DVBS_CFG_IS_ITERATE_NON_LCN_CH_NUM_SELF =1
[dtv_app_mtk]>
DVBS_CFG_IS_RSLV_UNICABLE_CLLSN_BY_TSID =1
[dtv_app_mtk]>
DVBS_CFG_IS_NEUCLES_SCAN_UPDATE_SVL_INTERRUPT =0
[dtv_app_mtk]>
DVBS_CFG_IS_LINKAGE_BY_SILENT_CHANGE =1
[dtv_app_mtk]>
DVBS_CFG_IS_NIT_DESC_LOGICAL_CHANNEL_DESC_V2 =1
[browser_base]>[bws_app][Default][L2193]SetStartUrl : Leave, URL is file:///3rd/html5/index.html
[browser_base]>UsbDetectClass : ConstructInstance
[browser_base]>UsbDetectClass:PluginNotify : ConstructInstance
[browser_base]>[udetect] udetect_init.347: pid:681
[browser_base]>[bws_app][Critical][L4670]Custom_Pre_Init : Enter
[browser_base]>[bws_app][Critical][L4920]set_proxy_setting : Enter
[browser_base]>[udetect] udetect_init.379: init done.
[browser_base]>[TVC_MAIN]:Return fail:tv_ctrl_init:1397:-1
[browser_base]>-> using layer context config
[browser_base]>
[browser_base]>[bws_app][Critical][L4996]GetOSDLanguage : Set accept language as (ru) based on (rus)
[browser_base]>[bws_app][Critical][L5186]set_other_custom_config : Enter
[AM][ProcessControl.cpp][setState][2962][tid683]browser_base:(2 -> 2 )
[browser_base]>Pid:[681] Tid:[957] [PIMGR][ERROR][vStrmMgr_Init][1613]Leave,vStrmMgr_Init, already inited
[browser_base]>[681:1023:0101/020005.527119:5388371:ERROR:locale_util.cc(58)] Resource file for chosen locale not found: /3rd/browser_engine/opera_dir/locale/ru.pak
[browser_base]>[681:1023:0101/020005.527242:5388465:INFO:shell_content_browser_client.cc(329)] Chosen locale file: /3rd/browser_engine/opera_dir/locale/en-US.pak
[browser_base]>[bws_app][Default][L5026]set_user_agent : rBwsStartInfo.agent is NULL
[browser_base]>[bws_app][Critical][L85]CreateWindows : Enter
[browser_base]>[681:960:0101/020005.557620:5418875:INFO:quota_utils.cc(273)] OnSetTemporaryStorageLimit
[browser_base]>set transparent preference!
[browser_base]>[681:960:0101/020005.591937:5453180:WARNING:view_preferences.cc(132)] Disabling XHR origin checking allows any document in this view to send XHRs to any domain, which has serious security implications.
[browser_base]>[681:960:0101/020005.592110:5453333:WARNING:view_preferences.cc(143)] Disabling XHR mixed content checking allows Man-in-the-middle attacks against the XHR request.
[browser_base]>Pid:[681] Tid:[957] [HbbTV][UNKNOWN LEVEL][isHbbtvWindowType][235]bool isHbbtvWindowType()
[browser_base]>isHbbtvWindowType: tType = 1
[browser_base]>[bws_app][Critical][L134]CreateWindows : prWindow->pHandle is 0x249a00
[browser_base]>[bws_app][Critical][L732]certificate_manager_task : No updated root CA version info, just ignore the importing
[browser_base]>
[browser_base]>[bws_app][Critical][L140]CreateWindows : Leave
[browser_base]>[bws_app][Critical][L4915]Custom_Post_Init : Enter
[browser_base]>[bws_app][Default][L2518]ParseAppProfile : PHP brand, load 3rd_rw_device_brand of Philips brand.
[browser_base]>
[browser_base]>[bws_app][Critical][L2615]ParseAppProfile : sAppProfilePath is /3rd/internet_browser/apps/ui_html5/bws_profile.ini
[browser_base]>[bws_app][Critical][L2659]ParseAppProfile : width=1920
[browser_base]>[bws_app][Critical][L2672]ParseAppProfile : height=1080
[browser_base]>[bws_app][Critical][L3084]ParseAppProfile : sURL is file:///3rd/html5/php/dash/index.html
[browser_base]>[bws_app][Default][L2193]SetStartUrl : Leave, URL is file:///3rd/html5/php/dash/index.html
[browser_base]>[681:1023:0101/020005.613378:5474624:ERROR:locale_util.cc(58)] Resource file for chosen locale not found: /3rd/browser_engine/opera_dir/locale/ru.pak
[dtv_app_mtk]>
DVBS_CFG_IS_MON_AC_TUNER_LOST_SIGNAL =0
[browser_base]>[681:1023:0101/020005.613475:5474697:INFO:shell_content_browser_client.cc(329)] Chosen locale file: /3rd/browser_engine/opera_dir/locale/en-US.pak
[dtv_app_mtk]>
DVBS_CFG_IS_ALTER_TSL_OF_PRESET_SCAN =0
[dtv_app_mtk]>
DVBS_CFG_IS_NON_NETWORK_PRESET_SCAN_NOT_LOAD_NITa =0
[browser_base]>[681:960:0101/020005.629206:5490453:WARNING:view_preferences.cc(132)] Disabling XHR origin checking allows any document in this view to send XHRs to any domain, which has serious security implications.
[dtv_app_mtk]>
DVBS_CFG_IS_INHERIT_POSITION_FOR_LOSER =0
[browser_base]>[681:960:0101/020005.629359:5490583:WARNING:view_preferences.cc(143)] Disabling XHR mixed content checking allows Man-in-the-middle attacks against the XHR request.
[dtv_app_mtk]>
DVBS_CFG_IS_ENABLE_SYMBOL_RATE_AUTOMATIC =1
[dtv_app_mtk]>
DVBS_CFG_IS_LINKAGE_TYPE_4_AS_BARKER_CHANNEL =0
[dtv_app_mtk]>
DVBS_CFG_CYF_IS_ZERO_LCN_SERVICE_NOT_TO_INSTALL =0
[dtv_app_mtk]>
DVBS_CFG_CYF_IS_CHECK_PDS_FOR_PARSE_LCD =1
[dtv_app_mtk]>
DVBS_CFG_CYF_IS_CHECK_MUTI_PDS_FOR_PARSE_LCD =0
[dtv_app_mtk]>
DVBS_CFG_CYF_IS_LOAD_BAT_ID_BY_FEED =0
[dtv_app_mtk]>
DVBS_CFG_NCP_IS_ZERO_LCN_NOT_INSTALL =0
[dtv_app_mtk]>
DVBS_CFG_NCP_IS_CHECK_PDS_FOR_PARSE_LCD =1
[dtv_app_mtk]>
DVBS_CFG_PLS_IS_LOAD_NITa_CHECK_NETWORK_ID =1
[dtv_app_mtk]>
DVBS_CFG_PLS_IS_LOAD_NIT_CHECK_NETWORK_ID =0
[dtv_app_mtk]>
DVBS_CFG_PLS_IS_CHECK_PDS_FOR_PARSE_CHANNEL_DESCR3 =1
[dtv_app_mtk]>
DVBS_CFG_PLS_IS_VALID_RANGE_DFN1 =0
[dtv_app_mtk]>
DVBS_CFG_PLS_IS_VALID_RANGE_DFN2 =1
[dtv_app_mtk]>
DVBS_CFG_PLS_IS_VALID_RANGE_DFN3 =0
[dtv_app_mtk]>
DVBS_CFG_PLS_IS_INVALID_CP_ID_NOT_INSTALL =0
[dtv_app_mtk]>
DVBS_CFG_CND_IS_PARSE_SLD =1
[dtv_app_mtk]>
DVBS_CFG_M7_IS_NON_LCN_OR_ZERO_NOT_INSTALL =0
[dtv_app_mtk]>
DVBS_CFG_M7_IS_INSTALL_SERVICE_BY_SLD =1
[dtv_app_mtk]>
DVBS_CFG_M7_IS_INSTALL_SERVICE_BY_SLD_AND_FST =1
[dtv_app_mtk]>
DVBS_CFG_M7_IS_VALID_RANGE_DFN1 =0
[dtv_app_mtk]>
DVBS_CFG_M7_IS_VALID_RANGE_DFN2 =1
[dtv_app_mtk]>
DVBS_CFG_M7_IS_ORBIT_DISMATCH_OMIT_MUX =1
[dtv_app_mtk]>
DVBS_CFG_M7_IS_CARE_NETWORK_ID_FOR_LOADING_TABLE =0
[dtv_app_mtk]>
DVBS_CFG_DTK_IS_CHECK_MDU_RULE1 =0
[dtv_app_mtk]>
DVBS_CFG_DTK_IS_CHECK_MDU_RULE2 =1
[browser_base]>[bws_app][Critical][L134]CreateWindows : prWindow->pHandle is 0x4a1800
[dtv_app_mtk]>
DVBS_CFG_DTK_IS_MDU1_LOAD_SPECIAL_BAT_ID =1
[browser_base]>
[dtv_app_mtk]>
DVBS_CFG_DTK_IS_TUNE_MUX_BY_BAT =1
[dtv_app_mtk]>
DVBS_CFG_NNK_IS_LCN_HOME_MUX_PRIOR_TO_TUNING_MUX =1
[dtv_app_mtk]>
DVBS_CFG_NNK_IS_SPEC_DFN1 =0
[dtv_app_mtk]>
DVBS_CFG_NNK_IS_SPEC_DFN2 =1
[dtv_app_mtk]>
DVBS_CFG_NNK_IS_LCN_DESCRIPTOR_DFN1 =1
[browser_base]>[bws_app][Error][L2609]ParseAppProfile : sAppProfilePath is NULL, return
[dtv_app_mtk]>
DVBS_CFG_NNK_IS_LCN_DESCRIPTOR_DFN2 =0
[browser_base]>[bws_app][Critical][L4904]ResetWindowInfo : adv window url = https://adacc.nettvservices.com/adserve ... .baidu.com
[dtv_app_mtk]>
DVBS_CFG_SHD_IS_SERVICE_INFO_BY_SDTa =1
[dtv_app_mtk]>
DVBS_CFG_DSM_IS_INSTALL_SPECIAL_SAT_SVC_BY_SDSD_OF_NIT =0
[dtv_app_mtk]>
DVBS_CFG_SGT_IS_VALID_RANGE_DFN1 =1
[dtv_app_mtk]>
DVBS_CFG_SGT_IS_PARSE_SDTa_SDTo =0
[dtv_app_mtk]>
DVBS_CFG_ARN_IS_SUPPORT =1
[dtv_app_mtk]>
DVBS_CFG_TRC_IS_LOAD_SDTo =1
[dtv_app_mtk]>
DVBS_CFG_TRC_IS_ONE_REGION_STILL_NOTIFY =0
[dtv_app_mtk]>
DVBS_CFG_TRC_IS_REGION_FILTER_BY_TIME_ZONE =1
[dtv_app_mtk]>
DVBS_CFG_TRC_IS_FEDERAL_PREFIX_AS_VALID =0
[dtv_app_mtk]>
DVBS_CFG_TRC_IS_DYNAMIC_POSTFIX =1
[dtv_app_mtk]>
DVBS_CFG_TRC_IS_CHECK_UPDATE_STATUS =0
[dtv_app_mtk]>
DVBS_CFG_TRC_IS_PACK_MULTI_CH_LIST =1
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_TYPE =30
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_HD =0
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_CRNT_LCN =29
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_NAME =28
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_PROG_NUM =27
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_ON_ID =0
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_TS_ID =0
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_FREQUENCY =0
[dtv_app_mtk]>
DVBS_NON_LCN_SORTING_SVC_POL =0
[dtv_app_mtk]>
Init DSMCC[2][0][2]
[dtv_app_mtk]>
[Borger] [a_font_custom_init][350]
[dtv_app_mtk]>
{SVCTX} {SVCTX}Err: handle_get_type_obj(h_svctx=0) failed!
[dtv_app_mtk]>
i4_ret=-2, e_type=0, pv_obj=0xb0338000{MHEG5-MW} MHEG5 TPS start to setup
[browser_base]>[681:1023:0101/020005.641181:5502425:ERROR:locale_util.cc(58)] Resource file for chosen locale not found: /3rd/browser_engine/opera_dir/locale/ru.pak
[dtv_app_mtk]>
{MHEG5-MW} [MHEG5_NVM]rw root path = /3rd_rw
[browser_base]>[681:1023:0101/020005.641266:5502488:INFO:shell_content_browser_client.cc(329)] Chosen locale file: /3rd/browser_engine/opera_dir/locale/en-US.pak
[dtv_app_mtk]>
_rec_util_pool_alloc#1071 pv_phy_addr:0x898f5000 z_buf_size:4718592
[dtv_app_mtk]>
_rec_util_pool_alloc#1126 pt_rque_pool pv_buf_physi:0x898f5000 pv_buf_physi_align:0x898f5000 z_size_physi:1048576
[dtv_app_mtk]>
[browser_base]>[681:960:0101/020005.647209:5508452:WARNING:view_preferences.cc(132)] Disabling XHR origin checking allows any document in this view to send XHRs to any domain, which has serious security implications.
[dtv_app_mtk]>
Rec_util_thread:buffer addr 0x899f5000,pv_buf_physi:0x380000,size 3670016
[browser_base]>[681:960:0101/020005.647355:5508579:WARNING:view_preferences.cc(143)] Disabling XHR mixed content checking allows Man-in-the-middle attacks against the XHR request.
[dtv_app_mtk]>
{DT} Real Time Clock is available on this system.
[dtv_app_mtk]>
wakeup main reason = 6, sub_reason = 0
[dtv_app_mtk]>
quiet_hot_boot = 0
[browser_base]>[bws_app][Critical][L134]CreateWindows : prWindow->pHandle is 0x4a2200
[dtv_app_mtk]>
<><><><><><>{CH_HDLR} Current Channel Freq = 650000 kHZ<><><><><><>
[dtv_app_mtk]>
<AM> wakeup reason = 6
[browser_base]>
[dtv_app_mtk]>
[dtv_app_mtk]>
open svctx lock check OK in sys ap start!
[dtv_app_mtk]>
default acfg log lvl: 0
[dtv_app_mtk]>
[(null)]default phm log lvl: 4744
[dtv_app_mtk]>
[(null)]default nav log lvl: 13986
[dtv_app_mtk]>
<ACFG>EEP_FILE:EEP_FILE_PATH[/dev/flash_acfg_desc]
[dtv_app_mtk]>
<ACFG>EEP_FILE:Can&#39;t open EEPROM file
[dtv_app_mtk]>
EEPROM size is 0x4000.
[dtv_app_mtk]>
EEPROM size is 0x35b0.
[dtv_app_mtk]>
<ACFG> EEP_FILE: this mode have not be init !!
[dtv_app_mtk]>
<ACFG> EEP_FILE: a_cfg_eep_file_reset_header_data(1)!!
[dtv_app_mtk]>
{SVL} {SVL} open SVL [svl_id: 5] failed.
[dtv_app_mtk]>
{SVL} {SVL} open SVL [svl_id: 6] failed.
[dtv_app_mtk]>
{SVL} {SVL} open SVL [svl_id: 7] failed.
[dtv_app_mtk]>
[dtv_app_mtk]>
[ACFG] acfg_load_cch_info()
[dtv_app_mtk]>
[MWIF2-CLI][_TunerGet:364] eResult = -264
[dtv_app_mtk]>Set country code to [RUS] by SB_KEY_TYPE_COUNTRY_CODE
[dtv_app_mtk]>
[dtv_app_mtk]>sb_dvbs_check_flexiable_log_level:x_lol_get_rec_by_data_tag fail, i4_ret=-6, data tag=0 data length=0
[dtv_app_mtk]>
{unknown_x_sb_eng.c} builder data is not ready
[dtv_app_mtk]>
{DVBS_INFO} ( 8782)( dvbs_set) Set region id =0
[dtv_app_mtk]>
[ACFG] 2270 ui1_region_id=0
[dtv_app_mtk]>
[MWIF2-MPV]_CompIdtoEsId 451, ucEsId(255) error
[dtv_app_mtk]>[MWIF2-MPV]_CompIdtoEsId 451, ucEsId(255) error
[dtv_app_mtk]>[MWIF2-MPV]MPV_MwSet(0): MTVDEC_MM_SET_TV_NODATA_TIME_INFO.(16000)
[dtv_app_mtk]>DVBSI TUNER_TYPE = 1
[dtv_app_mtk]>
DVBSI DVBC_OPERATOR operator= 0
[dtv_app_mtk]>
DVBSI DVBS_OPERATOR operator= 0
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
TP vision IP SW - Mbdsl1(13.00.00.01)initializaiton-successful
[dtv_app_mtk]>
[BGM] set last RTC wakeup type: reason=256
[dtv_app_mtk]>
[dtv_app_mtk]>Set language to [rus] by SB_KEY_TYPE_GUI_LANG
[dtv_app_mtk]>
[_acfg_custom_pq_remap_picture_item_to_by_model_idx] the record id is not Correct [115]
[dtv_app_mtk]>
---a_cfg_custom_get_ACR_state--
[dtv_app_mtk]>
[APP TV] 235 get acr enabled: 0.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[xbrowser][browser_stub_notification_handler][2294][956]tType = 106
[dtv_app_mtk]>
[browser_base]>[xbrowser][browser_stub_notification_handler][2294][956]tType = 105
[dtv_app_mtk]>[ACFG] _acfg_init_is_4k_model:1
[dtv_app_mtk]>
{MMP} <ACFG> Return fail:acfg_video.c:5270:-8
[dtv_app_mtk]>
{MMP} <ACFG> Return fail:acfg_video.c:1224:-5
[dtv_app_mtk]>
[APP TV] 244 set acr disable.
[dtv_app_mtk]>
[APP TV] 269. 1. 0.
[dtv_app_mtk]>
[APP TV] 277 ---Set ACR off and wait 8sec before kill---
[browser_base]>[681:1023:0101/020005.649672:5510913:ERROR:locale_util.cc(58)] Resource file for chosen locale not found: /3rd/browser_engine/opera_dir/locale/ru.pak
[browser_base]>[681:1023:0101/020005.649761:5510983:INFO:shell_content_browser_client.cc(329)] Chosen locale file: /3rd/browser_engine/opera_dir/locale/en-US.pak
[browser_base]>[681:960:0101/020005.654371:5515615:WARNING:view_preferences.cc(132)] Disabling XHR origin checking allows any document in this view to send XHRs to any domain, which has serious security implications.
[browser_base]>[681:960:0101/020005.654521:5515745:WARNING:view_preferences.cc(143)] Disabling XHR mixed content checking allows Man-in-the-middle attacks against the XHR request.
[browser_base]>[bws_app][Critical][L134]CreateWindows : prWindow->pHandle is 0x49f000
[browser_base]>
[browser_base]>[xbrowser][browser_stub_notification_handler][2294][956]tType = 111
[browser_base]>[681:960:0101/020005.684750:5545998:INFO:opera.cc(534)] Initializing autofill feature...
[browser_base]>(*)
[browser_base]>
[browser_base]> layer config size [1920 x 1080]
[browser_base]>
[browser_base]>(*)
[browser_base]>
[browser_base]> new config size [1920 x 1080]
[browser_base]>
[browser_base]>[bws_app][Critical][L155]OpenURL : before, URL is file:///3rd/html5/index.html
[browser_base]>[bws_app][Critical][L257]OpenURL : after, URL is file:///3rd/html5/index.html
[browser_base]>[bws_app][Critical][L155]OpenURL : before, URL is file:///3rd/html5/php/dash/index.html
[browser_base]>[bws_app][Critical][L257]OpenURL : after, URL is file:///3rd/html5/php/dash/index.html
[browser_base]>[bws_app][Error][L3146]FocusInputWindow : rBwsStartInfo.dfb is NULL
[browser_base]>[bws_app][Critical][L3359]am_start : am_started(NULL, browser_base)
[browser_base]>[bws_app][Default][L3685]GoForegroundFromBackground : Leave
[browser_base]>shui mq_open(/bws_brctl_mq): num=32 size=0x404 flags=0x800
[browser_base]>Pid:[681] Tid:[1110] [HbbTV][UNKNOWN LEVEL][isHbbtvWindowType][235]bool isHbbtvWindowType()
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(0), window hadnle(0x249a00), data(0x51d1e0)
[browser_base]>[bws_app][Default][L272]HandleEvt_Custom : BROWSER_EVENT_LOADING_START
[browser_base]>[bws_app][Default][L3354]get_epg_mode : read epg_launch_method file fail!
[browser_base]>
[browser_base]>[bws_app][Default][L282]HandleEvt_Custom : The Browser Window Index is 0
[dtv_app_mtk]>
{SVCTX} {SVCTX}Err: get using SCDB record failed!
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(0), window hadnle(0x4a1800), data(0x51d1d0)
tty_mngr_init
[browser_base]>
[browser_base]>[bws_app][Default][L282]HandleEvt_Custom : The Browser Window Index is 1
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(0), window hadnle(0x49f000), data(0x51d1d8)
[browser_base]>
[browser_base]>[bws_app][Default][L282]HandleEvt_Custom : The Browser Window Index is 3
[browser_base]>[1175:1175:0101/020006.252381:6114088:INFO:render_thread_impl.cc(1957)] Creating a (delegated) DirectFB backend in the renderer process.
[browser_base]>[1146:1146:0101/020006.253475:6116999:INFO:render_thread_impl.cc(1957)] Creating a (delegated) DirectFB backend in the renderer process.
[browser_base]>[1156:1156:0101/020006.268607:6130319:INFO:render_thread_impl.cc(1957)] Creating a (delegated) DirectFB backend in the renderer process.
[browser_base]>[SambaTV]SambaTV plug-in permission is allowed within local files
[browser_base]>[681:960:0101/020006.481269:6342513:INFO:CONSOLE(94)] "&&&&&&&&&&&&&&&&&&&&HeartBeatToBrowser&&&&&&&&&&&&&&&&&&", source: chrome://userjs/heart_beat.user.js (94)
[browser_base]>Pid:[681] Tid:[1110] [CBwsAdapterImpl][ERROR][OnLoadingFinished][1153]open epg_launch_method file fail!
[browser_base]>
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(1), window hadnle(0x49f000), data(0x5473e0)
[browser_base]>[bws_app][Default][L332]HandleEvt_Custom : BROWSER_EVENT_LOADING_FINISHED
[browser_base]>[TVC_JSP] [_jsp_tv_constr][7973] --> waiting dtv_svc ready.
Not first bootup
MTAUDDEC_RegCPUDECControlCbFunc have been called.
[dtv_app_mtk]>
{ACFG} <ACFG> Return fail:acfg_audio.c:1766:-3
Input: CLI
[dtv_app_mtk]>
{ACFG} <ACFG> Return fail:acfg_audio.c:858:-5
[dtv_app_mtk]>
a_cfg_update_tkgs_operating_mode to dvbs engine
[dtv_app_mtk]>
[dtv_app_mtk]>
POWER ON
[dtv_app_mtk]>
[dtv_app_mtk]>
[acfg_custom_post_init] ERROR, line[9993], ret = [-1]
[dtv_app_mtk]>
{SM-SCC} [SCC] _scc_vid.c:866 rm_get(260) fail return -16
[dtv_app_mtk]>
[a_cfg_custom_update_input_src_favorite_attr] Return ERROR, line[27923], ret = [-3]
[dtv_app_mtk]>
[FD] a_cfg_set_gui_lang s639_lang = AUS
[dtv_app_mtk]>
[dtv_app_mtk]>Set language to [AUS] by SB_KEY_TYPE_GUI_LANG
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[FD] a_cfg_set_gui_lang s639_lang = rus
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
@VER TPM186E_018.004.146.001
[dtv_app_mtk]>
[dtv_app_mtk]>
@OKOKOKOKOKOKOKOKOKOK
[dtv_app_mtk]>
[ACFG_CUST] ttgctt a_cfg_custom_cul_amApp()[TPV_CUL]fun:_nav_misc_url_dacClient_available, line:8584, cul_enable_after_dacAPP =0
[dtv_app_mtk]>
!!!ENTER a_cfg_cust_get_model_name_YT_UAString!!
[dtv_app_mtk]>
!!!ENTER a_cfg_cust_get_conn_type_YT_UAString!!
[dtv_app_mtk]>
!!!ENTER a_cfg_cust_get_brand_name_YT_UAString!!
[dtv_app_mtk]>
[NW]change lock status function is a_nw_register, line is 3798
[dtv_app_mtk]>
[NW]change lock status function is a_nw_register, line is 3836
[dtv_app_mtk]>
ACRavailability
[dtv_app_mtk]>
[acfg_custom_ihs.c][390][ACRavailability][1]
[dtv_app_mtk]>
[Roy][plf_opt.c][3015]a_cfg_custom_get_InformTouStatus for ACRavailability = 0
[dtv_app_mtk]>
[plf_opt.c][---- Inscape ACR UI Disnable ----]
[dtv_app_mtk]>
[dtv_app_mtk]>
@STARTUP_OK
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
###### x_svl_reg_list_mode_chg_notify:0xb1e9964c.
[dtv_app_mtk]>
###### x_svl_reg_ocl_scan_info_notify:0xb1e99790.
[dtv_app_mtk]>
######[a_mtktvapi_channellist_init][1490] register test nfy: ListModeChg=0xb1e9964c, i4_rc1=0, OclScanInfo=0xb1e99790, i4_rc2=0 .
[dtv_app_mtk]>
###### Line:1496, a_mtktvapi_channellist_init ret=-8.
[dtv_app_mtk]>
###### Line:1500, a_mtktvapi_favorite_list_init ret=0.
[dtv_app_mtk]>
a_mtktvapi_cec_init end. return:0.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[MWIF2-CLI][_TunerGet:364] eResult = -264
[dtv_app_mtk]>Illegal using!
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
{NAVIGATOR} <TVAP_NETWORK>Err: <tvap_proxy_common.c:1636:tvap_proxy_init> TVAP Proxy has been inited
[dtv_app_mtk]>
{unknown_agent.c} <AGENT> ERR: send message = 1 failed = -3
[dtv_app_mtk]>
c_ci_get_ciplus_cred_status called(define TZ_SUPPORT).
[dtv_app_mtk]>
x_ci_get_ciplus_cred_status TZ no perm, get file length 5124
[dtv_app_mtk]>
x_ci_get_ciplus_cred_status data1 69 data2 131
[dtv_app_mtk]>
c_ci_get_ciplus_cred_status ,*pb_exist = 1.
[dtv_app_mtk]>
[NAV_MISC]a_nav_misc CI+ key already exist in CI+ partition
[dtv_app_mtk]>
[MWIF2-VDP](_VdpXlatDispFmtCallBackMw)(4692) e_type(0) VDP_MW is disconnect!
[dtv_app_mtk]>{unknown_agent.c} <AGENT> ERR: send message = 1 failed = -3
[dtv_app_mtk]>
{SVCTX} _player_close_sess x_handle_valid(pt_player->h_sess) invalid
[dtv_app_mtk]>
[dtv_app_mtk]>
[LINUX_FAKE_API] sys_overscan_mode_sync
[dtv_app_mtk]>
[dtv_app_mtk]>kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
[dtv_app_mtk]>
[util_source][0][0]
[dtv_app_mtk]>
[BGM_OAD_DTC] _oad_detect_init
[dtv_app_mtk]>
BGM: Ambismart module init
[dtv_app_mtk]>
[BGM_OLED] _bgm_oled_init
[dtv_app_mtk]>
[CMDCVT]
[dtv_app_mtk]>
enter cmd_convert_init, 2441
[dtv_app_mtk]>
[CMDCVT]
[dtv_app_mtk]>
leave cmd_convert_init, 2544
[dtv_app_mtk]>
<MSCVT>msg_convert_custom_init
[dtv_app_mtk]>
<MSCVT> msgconvert custom: do something before init
[dtv_app_mtk]>
<MSCVT>bws state notify callback reg here
[dtv_app_mtk]>
<MSCVT>cmd_convert_parse_ap_cmd, i4_ret(103)
[dtv_app_mtk]>
<MSCVT>dtv_app_mtk receive (dtv_app_mtk) started msg
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:started=ECD
[dtv_app_mtk]>[BGM]<bgm_model.c:2019:a_bgm_is_quiet_hot_boot> Check Quiet_Hot_Boot_flag: 0
[dtv_app_mtk]>
[dtv_app_mtk]>[_acfg_custom_video_set_letter_box_detect] Set letter box detect [0]
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:paused=pippop
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[NAV_SBL_TEST] _nav_sbl_init() a_tv_sbl_open() i4_ret[0]
[dtv_app_mtk]>
[dtv_app_mtk]>
[NAV_SBL_TEST] _nav_sbl_init() c_sb_set()
[dtv_app_mtk]>
{_dfb_enable_layer}t_op.u.set_plane.i4_idx=1, b_enable=1
[dtv_app_mtk]>
{nav_custom_set_second_osd_plane_canvas_config}c_wgl_get_canvas ok!!
[dtv_app_mtk]>
{DVBS_INFO} ( 8722)( dvbs_set) Register get info notification function
[dtv_app_mtk]>
[GCC_OSRC] osrc create
[dtv_app_mtk]>
[NAV CI] _ci_init Country: RUS
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][2179]
[dtv_app_mtk]>
{CACP}{info}[ _sb_dvb_act_source.c][ 145] Get the Lower and Higher band [48000000, 859000000], and delta frequency =714000!
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][2264]
[dtv_app_mtk]>
{CICP}{info}[ ca_svl_builder.c][ 278] open_builder:[hdl:0x1013d33][tuner:tuner_ter_dig_0][svlId:5][delivery:6]
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][ 401] New state: SB_DVB_COND_MON_WAITING
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][ 423]
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][2125]
[dtv_app_mtk]>
[dtv_app_mtk]>
{CACP}{info}[ _sb_dvb_act_source.c][ 145] Get the Lower and Higher band [48000000, 859000000], and delta frequency =400000!
[dtv_app_mtk]>
[dtv_app_mtk]>
{CICP}{info}[ ca_svl_builder.c][ 278] open_builder:[hdl:0x1013d28][tuner:tuner_cab_dig_0][svlId:6][delivery:1]
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
{CACP}{info}[ _sb_dvb_act_source.c][ 145] Get the Lower and Higher band [950, 2150], and delta frequency =3!
[dtv_app_mtk]>
{CACP}{info}[ _sb_dvb_act_source.c][ 195] [Phase2][10][1000000]
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][1540] The refered broadcast satl id is [7]
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][1543] [Phase2][0x0][0]
[dtv_app_mtk]>
{CACP}{info}[ sb_dvb_cp_eng.c][1556] [Phase2][0x1013d1a][7]
[dtv_app_mtk]>
{CACP}{info}[ _sb_dvb_act_storage.c][ 523] x_satl_open[7][ret:0]
[dtv_app_mtk]>
{CACP}{info}[ _sb_dvb_act_storage.c][ 585]
[dtv_app_mtk]>
[dtv_app_mtk]>
{CICP}{info}[ ca_svl_builder.c][ 278] open_builder:[hdl:0x1013d1d][tuner:tuner_sat_dig_0][svlId:7][delivery:4]
[dtv_app_mtk]>
[Nav ci][_ci_init]---- CI_GET_TYPE_SAS_OPEN_STATE, b_ci_plus_sas_open_state: 0
[dtv_app_mtk]>
Create Direct FB Event Buffer successful
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[Vol_ctrl] _vol_ctrl_view_register_io_mngr() return
[dtv_app_mtk]>
ci reg sbtl nfy.
[dtv_app_mtk]>
ci reg sbtl nfy, i4_ret:0
[dtv_app_mtk]>
{NAVIGATOR} <NAV>Err: not init yet, cann&#39;t handle aud_lang_cfg_nfy
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
==============ringbuffer start==============
[dtv_app_mtk]>
[dtv_app_mtk]><MSCVT ERR><><>AM_BRDCST_MSG_POWER_ON g_b_is_suspend_mode=0.
[dtv_app_mtk]>
[BGM-FRC] _handle_am_msg 1551 panel type:0 frc type: 0
[dtv_app_mtk]>
[BGM] BGM_UI_MSG_AM_POWER_ON->_handle_am_msg
[dtv_app_mtk]>
[dtv_app_mtk]>
[BGM]c_pcl_set_power_state PCL_PWR_STATE_CTRL_RUNNING 0.
[dtv_app_mtk]>
a_am_get_suspend_status()=0
[dtv_app_mtk]>
<MSCVT>_b_suspend_to_netflix = 0, g_b_dial_boot = 0
[dtv_app_mtk]>
[dtv_app_mtk]>[Felix][acfg_custom.c][12842]
[dtv_app_mtk]>
[Felix][acfg_custom.c][12846]ui1_epg_mode = 0
[dtv_app_mtk]>
[acfg_custom_update_all][12912], restore wowlan configuration: 0.
[dtv_app_mtk]>
[a_cfg_custom_1st_pwr_on_EDID_update] ERROR, line[36902], ret = [-16]
[dtv_app_mtk]>
[APP_CUST][acfg_custom_update_all:13171] [Headphone parameter] (13171) ui1_curr_aud_idx[1], ui1_last_aud_idx[1], b_hp_insert[0], b_is_user_switch_audio_out[1]
[dtv_app_mtk]>
[APP_CUST][acfg_custom_update_all:13216] Not detect Headphone when boot!!
[dtv_app_mtk]>
[APP_CUST][acfg_custom_update_all:13235] [Headphone parameter] (13235) ui1_curr_aud_idx[1], ui1_last_aud_idx[1], b_hp_insert[0], b_is_user_switch_audio_out[1]
[dtv_app_mtk]>
{unknown_dt_teletext_api.c} {DT} Error [-36] RM_GET on analog tuner failed.
[dtv_app_mtk]>
PR4802 bgm_power_mgmt_handle.c-1712 unmute audio
[dtv_app_mtk]>
[APP_CUST][a_tv_set_mute_custom:4514] b_mute = 0, ui4_muted_out_port_msk = 0x8, i4_ret = 0
[dtv_app_mtk]>
[BGM_OAD_DTC] _oad_detect_handle_msg :13
[dtv_app_mtk]>
BGM: Ambismart module handle message 13
[dtv_app_mtk]>
{NAVIGATOR} <PHM> ERR: send message = 55 failed = -3
[dtv_app_mtk]>
[acfg_custom.c][_acfg_custom_ch_logo_version_check_context_switch][39797]restart channel logo db timer.
[dtv_app_mtk]>
[dtv_app_mtk]>
[!!!Return fail:nav_cec_util.c:nav_cec_util_is_amp_exist:669:0]
[dtv_app_mtk]>
[NAV CTRLER]comp[7]process[23]cost[131] ticks!!!!
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[NAV CTRLER]comp[7]process[24]cost[142] ticks!!!!
[dtv_app_mtk]>
[nav ci] message received -- NAV_UI_MSG_POWER_ON
[dtv_app_mtk]>
[MWIF2-CLI]Enter CI_SET_TYPE_POWERON!
[dtv_app_mtk]>[MISC] ttgctt NAV_UI_MSG_POWER_ONBGM: Ambismart module [_bgm_ambisamrt_xtv_power_status_icl_nfy_hdlr][191]
[dtv_app_mtk]>
[MISC] pcl wakeup reason: 6
[dtv_app_mtk]>
ttgctt func _nav_misc_url_dacClient_start_server() in nav_misc.c: g_cul_server_status=0
[dtv_app_mtk]>
[NAV_MISC][_nav_misc_check_HDCP14_key]open file return error
[dtv_app_mtk]>
[dtv_app_mtk]>
[INPUT_SRC]_nav_ipts_change_input_src, b_apply_same = 1, ui1_old_id = 0, t_next_isl_rec.ui1_id = 0, t_next_isl_rec.e_src_type = 1
[dtv_app_mtk]>
[INPUT_SRC]_nav_ipts_apply_src_selection, pt_new_src->e_src_type = 1, b_is_support = 1, pt_new_src->ui1_id = 0
[dtv_app_mtk]>
[NAV CI] DVBS_OPERATOR_NAME_T is 0
[dtv_app_mtk]>
{NAVIGATOR} <PHM> ERR: send message = 54 failed = -3
[dtv_app_mtk]>
WILLIAM_pt_ui_msg->e_id=8
[dtv_app_mtk]>
[dtv_app_mtk]>[INPUT_SRC]_nav_ipts_apply_src_selection, nav_change_av_inp_by_id, i4_ret = 0
[dtv_app_mtk]>
[INPUT_SRC]_nav_ipts_change_input_src, _nav_ipts_apply_src_selection, i4_ret = 0
[dtv_app_mtk]>
[LINUX_FAKE_API] d_custom_get_custom_mode
[dtv_app_mtk]>
[NAV_MISC] no module is using osd3, disable osd3.
[dtv_app_mtk]>
[GL][gl_dfb_plane_enable] Plane set enable 0
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[AM][ApplicationControl.cpp][setState][680][tid680]dtv_app_mtk.navigator:(0 -> 4)!
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:failed=navigator,err_code=-6
[ERROR][ApplicationControl.cpp:recvCmd]
command failed deprecated
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]><MSCVT>cmd_convert_parse_ap_cmd, i4_ret(112)
[browser_base]>[bws_app][Default][L772]recvCmd : s_ack=NULL, s_name=navigator, s_comment=ready
[browser_base]>[bws_app][Default][L879]recvCmd : Register callback function to communicate with dtv_svc, ret 0.
[browser_base]>
[browser_base]>
[browser_base]>
[browser_base]>
[browser_base]>sendCmd() set browser init status again after nav init
[dtv_app_mtk]>
<MSCVT>cmd_convert_parse_ap_cmd, i4_ret(33)
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:started=STVAPI
[dtv_app_mtk]>c_ci_get_ciplus_cred_status called(define TZ_SUPPORT).
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[a_ecd_custom_check_decry_filename]open file[PSTVK001]return error: -6
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[a_ecd_custom_check_decry_filename]open file[PSTVK004]return error: -6
[dtv_app_mtk]>
[dtv_app_mtk]>
[a_ecd_custom_check_decry_filename]open file[idfile]return error: -6
[dtv_app_mtk]>
[dtv_app_mtk]>
[a_ecd_custom_check_decry_filename]open file[PSTVK003/bgroupcert.dat]return error: -6
[dtv_app_mtk]>
[dtv_app_mtk]>
[a_ecd_custom_check_decry_filename]open file[PSTVK015/bgroupcert.dat]return error: -6
[dtv_app_mtk]>
[dtv_app_mtk]>
[a_ecd_custom_check_decry_filename]open file[PSTVK010]return error: -6
[dtv_app_mtk]>
[_nav_pwr_view_reset_off_timer]ui4_timer_type[1],b_is_vga[0]
[dtv_app_mtk]>
b_with_signal[0], i4_auto_switch_off[240]
[dtv_app_mtk]>
[_nav_pwr_view_reset_off_timer]offtime[540000]
[dtv_app_mtk]>
[NAV CI] NAV UI MSG SIGNAL or NO SIGNAL recv: 1
[dtv_app_mtk]>
[Nav ci][_nav_ci_update_sas_event]---- CI_GET_TYPE_SAS_CONNECT_STATE, b_ci_plus_connect: 0
[dtv_app_mtk]>
[NAV CI]b_tune_wait_result =0, b_brdcst_tune_wait_result=d,
[dtv_app_mtk]>
[GCC_OSRC] osrc hide
[dtv_app_mtk]>
### osd show ###
[dtv_app_mtk]>
ACRavailability
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
{CI_glue}- PHYS_set_app_ready(TRUE)
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[FD]_phm_app_init_fct:974 Cobalt SSL notify reg icl success!!!
[dtv_app_mtk]>
_phm_sqlite3_init ending _phm_sqlite3_init,562
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:started=mmp
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:started=factory
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:started=tvstatus_app
[dtv_app_mtk]>[FM-Linux]Mount /dev/mmcblk0p7 to /perm successfully.
[dtv_app_mtk]> [NETTV:19:21:36]!=!=!=!=========== start thread id(1895822416): detached(1),name:Ntv0
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[InputEventListener.cpp][559], InputEventListener() Create Direct FB Event Buffer successful
[dtv_app_mtk]> [NETTV:19:21:36]!=!=!=!=========== start thread id(1887433808): detached(1),name:Ntv1
[dtv_app_mtk]> I imnettv.c[2188] IMnettvP_GetNetTVReleaseVersion entry. version=0xb635d21c
[dtv_app_mtk]> I imnettv.c[2194] IMnettvP_GetNetTVReleaseVersion Zeasn 1.19.3
[dtv_app_mtk]>
[dtv_app_mtk]>[_nav_cec_sys_info_mw_opcode_hdlr]Return ERROR, line[600], ret = [1]
[dtv_app_mtk]>
[dtv_app_mtk]>
[FM](/dev/mmcblk0p7) is mounted to (/perm) successfully(0)
[dtv_app_mtk]>
[pg_dbg][sys_start.c, 4363], ui1_bank_idx=1[FM](/dev/mmcblk0p12) is mounted to (/3rd) unsuccessfully(-3)
[dtv_app_mtk]>
[FM-Linux]Mount /dev/mmcblk0p13 to /3rd_rw successfully.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[CNettvLibGlue.cpp][1102], initWarm() IMnettvP_InitWarm() option: 0xc18b !!
[dtv_app_mtk]> I imnettv.c[0272] IMnettvP_InitWarm warm option : 0000c18b
[dtv_app_mtk]> I nettvapp_security.c[0079] _nettvapp_get_component_version Read the file from config.dat successfully
[dtv_app_mtk]> I nettvapp_security.c[0299] _nettvapp_decrypt_cert_files decrypt client certificate keybag &#39;/mnt/browser/ClientCert.bag&#39;
[dtv_app_mtk]>
[dtv_app_mtk]> I nettvapp_security.c[0251] _nettvapp_verify_opera_home_folder OPERA_HOME folder exits.
[dtv_app_mtk]> I nettvapp_security.c[0299] _nettvapp_decrypt_cert_files decrypt client certificate keybag &#39;/mnt/browser/RootCert.bag&#39;
[dtv_app_mtk]>
[dtv_app_mtk]> I nettvapp_security.c[0379] _nettvapp_verify_nssdb NSS database is ready.
[dtv_app_mtk]> I nettvapp_security.c[0425] _nettvapp_nssdb_import_root_cert There has no update of root certificates file.
[dtv_app_mtk]> I nettvapp_security.c[0457] _nettvapp_nssdb_import_client_cert There has no update of client certificate file.
[dtv_app_mtk]> I nettvapp_security.c[0112] _nettvapp_update_version_inConfig write the change to config succ
[dtv_app_mtk]> I browser_proxy.c[1040] brpxy_init p_brpxy_shm->ui4_brctl_dbg_lvl = 0
[dtv_app_mtk]> I browser_proxy.c[0768] _brpxy_spawn_browser start thread _brpxy_thread_spawn_browser
[dtv_app_mtk]> E browser_proxy.c[0773] _brpxy_spawn_browser faile to create _brpxy_thread_spawn_browser
[dtv_app_mtk]> W browser_proxy.c[0867] _brpxy_htv_init Don&#39;t support HTV
[dtv_app_mtk]> I browser_proxy.c[0794] _brpxy_thread_spawn_browser enter browser.out process
[dtv_app_mtk]> I browser_proxy.c[0803] _brpxy_thread_spawn_browser will execute /usr/opera/run_opera.sh
[dtv_app_mtk]>
[dtv_app_mtk]> opera-env OPERA_EXTRA_DFB_ARGS =
[dtv_app_mtk]>
[dtv_app_mtk]> opera-env UVA_BACKEND = libuvabackend-tpvision.so
[dtv_app_mtk]>
[dtv_app_mtk]> opera-env UVA_DRM_LIB = /usr/opera/opera_dir/uva_drm_backends/libuvadrmbackendloader.so
[dtv_app_mtk]>
[dtv_app_mtk]> opera-env UVA_DRM_LIB_DIR = /usr/opera/opera_dir/uva_drm_backends
[dtv_app_mtk]>{SVCTX} _player_close_sess x_handle_valid(pt_player->h_sess) invalid
[dtv_app_mtk]> I dppal.c[0192] dpPAL_cfg_init read version from config.dat
[dtv_app_mtk]> I dpservice.c[1756] clientService_GetWhitelistUrl File size is 1226
[dtv_app_mtk]> I dpservice.c[1781] clientService_GetWhitelistUrl read in whitelist : whbuffer[lsize-2] is t whbuffer[lsize-1] is v whbuffer[lsize] is I dpservice.c[1822] _dpParseWhiteList olsApp: Whitelist version 40
[dtv_app_mtk]> I dpservice.c[1845] _dpParseWhiteList olsApp :TotalWhiteListelements 41
[dtv_app_mtk]> I dpservice.c[1967] _dpParseWhiteList end of file
[dtv_app_mtk]> I dpservice.c[0134] clientService_init b24HoursSigned = 0
[dtv_app_mtk]>
[FM](/dev/mmcblk0p13) is mounted to (/3rd_rw) successfully(0)
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
{MHEG5-MW} MHEG5 TPS setup OK
[dtv_app_mtk]>
# mount ro_data
[dtv_app_mtk]>[FM-Linux]Mount /dev/mmcblk0p14 to /ro_data successfully.
[dtv_app_mtk]> I nettvapp_ipepg.c[0087] nettvapp_ipepg_init ipepgapp.ipepg_app_status =IPEPGAPP_STS_INACTIVE
[dtv_app_mtk]>
[dtv_app_mtk]> I imnettv.c[3719] nettvapp_inrfR_SetBrowserCertificates clientCert: /tmp/clientcert.p12
[dtv_app_mtk]> I imnettv.c[3720] nettvapp_inrfR_SetBrowserCertificates rootCert : /tmp/opcacrt6.p12
[dtv_app_mtk]> I imnettv.c[3722] nettvapp_inrfR_SetBrowserCertificates password :
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][CertificateManagerImpl][110]Enter
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][CertificateManagerImpl][119]Using default NSS database derrived from OPERA_HOME: /3rd_rw/internet_browser/opera_home/.pki/nssdb/
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][init_database][93]Initializing NSS database "sql:/3rd_rw/internet_browser/opera_home/.pki/nssdb/" succeeded
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][AddCACert][312]Enter
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][AddCACert][314]Adding CA certificate/s from file "/tmp/opcacrt6.p12"
[dtv_app_mtk]> I browser_controller.cc[4751] brctl_init_system [system init] browser_dfb_window = 0
[dtv_app_mtk]>
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][ReadCACertFile][757]No certificates with CA header/footer found in file: /tmp/opcacrt6.p12, trying to import whole content
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][ERROR][insert_cert_in_db][259]Failed to decode Cert from package
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][ERROR][AddCACert][382]Failed to import CA certificate "" from file /tmp/opcacrt6.p12
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][AddClientCert][439]Enter
[dtv_app_mtk]> I browser_controller.cc[7985] main browser_dfb_window=0
[dtv_app__tk]>m
[dtv_app_mtk]> I browser_controller.cc[8041] brctl_setup_runtime_env set MEMORY_LIMIT is : 419430400 Bytes
[dtv_app_mtk]> I browser_controller.cc[4653] brctl_init_opera Before calling opera_init() browser directFB window = 0
[dtv_app_mtk]> I opera_agent.cc[0049] opera_agent Opera agent instance created.
[dtv_app_mtk]> I opera_agent.cc[0083] initialize Dev build
[dtv_app_mtk]> I opera_agent.cc[0106] initialize directFB window id = 0
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>(*) MediaTek/Driver: Mapped shared command queue control structure to 0xb146e000
[dtv_app_mtk]>(*) MediaTek/Driver: Mapped DMA region to 0xb142e000
[dtv_app_mtk]>(*) MediaTek/Driver: GFX_CmdQueInit( 0xb146e000, 0x191cc8 )
[AM][ProcessControl.cpp][setState][2962][tid642]dtv_app_mtk:(2 -> 2 )
[dtv_app_mtk]>[0328/132616:INFO:directfb_instance.cc(103)] TPV will use DFSCL_NORMAL as the directFB cooperative level setting
[dtv_app_mtk]>
<MSCVT>cmd_convert_parse_ap_cmd, i4_ret(102)
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[NetTVAMClient.cpp][586], a_nettv_set_window_id()
[dtv_app_mtk]>[0328/132616:INFO:directfb_display.cc(152)] DFB Surface width=1280, height=720
[dtv_app_mtk]>(*) Direct/Interface: Using &#39;PNG&#39; implementation of &#39;IDirectFBImageProvider&#39;.
[dtv_app_mtk]> [NETTV:19:21:36]!=!=!=!=========== MSSPlayer::SetSslCfg </tmp/opcacrt6.pem>
[dtv_app_mtk]> I opera_agent.cc[0136] initialize directFB window id 3
[dtv_app_mtk]>
[dtv_app_mtk]>
[FM](/dev/mmcblk0p14) is mounted to (/ro_data) successfully(0)
[browser_base]>Pid:[681] Tid:[957] [CBWSCertificateManagerImpl][UNKNOWN LEVEL][AddClientCert][584]Client certificate with ID "Philips Net TV TV 2k16 - Koninklijke Philips Electronics N.V." imported successfully
[dtv_app_mtk]>
Wifi modules already inserted
[dtv_app_mtk]> I drm_service.cpp[0038] drm_service DRM service instance created.
[dtv_app_mtk]> I nettvapp.c[0836] nettvapp_process_msg Sending nettvapp msg 11
[dtv_app_mtk]> I nettvapp.c[1567] _nettvapp_resume op state 0, app state 1, mode 0, ping 2, pseudo_deactivate 0
[dtv_app_mtk]> I imnettv.c[0363] IMnettvP_InitWarm finish. Mnettv_Status=0
[dtv_app_mtk]> I nettvapp.c[1569] _nettvapp_resume nettvapp.b_start_ipepg_app= 0 ,nettvapp.e_op_ipepg_status = 0
[dtv_app_mtk]> I imnettv.c[0955] IMnettvP_UserChangedLanguage entry.
[dtv_app_mtk]> I imnettv.c[0964] IMnettvP_UserChangedLanguage max=45, languageId=15, ru
[dtv_app_mtk]> I imnettv.c[1022] IMnettvP_UserChangedLanguage exit.
[dtv_app_mtk]> I imnettv.c[1278] IMnettvP_UserChangedCountry entry. country_Id=RU
[dtv_app_mtk]> I nettvapp.c[0796] nettvapp_process_msg Sending nettvapp msg 10
[dtv_app_mtk]> I imnettv.c[1295] IMnettvP_UserChangedCountry exit.
[dtv_app_mtk]> I imnettv.c[1855] IMnettvP_Ipepg_SetConnectionType Connection Type = 5
[dtv_app_mtk]> I imnettv.c[2707] nettvapp_intfR_is_network_ok Calling IMnettvR_CheckIPStatus = [0]
[dtv_app_mtk]> E nettvapp.c[1573] _nettvapp_resume network is not ready, return error
[dtv_app_mtk]>Initializing Opera 4.8.0.129.Driver5.19 (81b91be3fbda64c09f6479d521859eaf2ab46dad) [ pid = 1674 ] ...
[dtv_app_mtk]>Device Model Name = Philips-MTK5802
[dtv_app_mtk]>_dm_get_attr_product_id filename = /sys/module/idProduct .
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/module/idVendor .
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_product_id filename = /sys/bus/usb/drivers/idProduct .
[dtv_app_mtk]>
[dtv_app_mtk]>
_dm_get_attr_vendor_id filename = /sys/bus/usb/drivers/idVendor .
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]> I dpservice.c[0276] clientService_set_product_connectiontype connecttype [5]
[dtv_app_mtk]> I dpservice.c[0285] clientService_set_product_connectiontype connecttype [13]
[dtv_app_mtk]> I imnettv.c[1831] IMnettvP_Ipepg_SetRegion Region = 3
[dtv_app_mtk]> I imnettv.c[2203] IMnettvP_DB_InformEpgType epg type = 0
[dtv_app_mtk]> I imnettv.c[2209] IMnettvP_DB_InformBcNetworkOperator entry. bcOperator=0x70ffec24
[dtv_app_mtk]>
size of . = 4096
[dtv_app_mtk]>
size of .. = 4096
[dtv_app_mtk]>
size of appListReset = 2
[dtv_app_mtk]>
size of appsInstalled.txt = 6135
[dtv_app_mtk]>
size of 4103_20006452.png = 6748
[dtv_app_mtk]>
size of 4103_20006452AppPic.png = 103259
[dtv_app_mtk]>
size of 4546_20006491.png = 3420
[dtv_app_mtk]>
size of 4546_20006491AppPic.png = 63313
[dtv_app_mtk]>
size of 4547_20006493.png = 7677
[dtv_app_mtk]>
size of 4547_20006493AppPic.png = 58929
[dtv_app_mtk]>
size of 3059_20006117.png = 19059
[dtv_app_mtk]>
size of 3059_20006117AppPic.png = 12720
[dtv_app_mtk]>
size of 4823_52870.png = 3999
[dtv_app_mtk]>
size of 4823_52870AppPic.png = 68621
[dtv_app_mtk]>
size of 5048_52845.png = 25114
[dtv_app_mtk]>
size of 5048_52845AppPic.png = 85374
[dtv_app_mtk]>
size of 20004317_20004875.png = 21750
[dtv_app_mtk]>
size of 20004317_20004875AppPic.png = 44129
[dtv_app_mtk]>
size of 20004333_20004921.png = 25466
[dtv_app_mtk]>
size of 20004333_20004921AppPic.png = 85132
[dtv_app_mtk]>
size of 20004318_20004876.png = 18164
[dtv_app_mtk]>
size of 20004318_20004876AppPic.png = 83906
[dtv_app_mtk]>
size of 5443_52874.png = 18322
[dtv_app_mtk]>
size of 5443_52874AppPic.png = 53695
[dtv_app_mtk]>
size of 4547_20006632.png = 7677
[dtv_app_mtk]>
size of 4547_20006632AppPic.png = 58929
[dtv_app_mtk]>
size of 4103_20006788.png = 6748
[dtv_app_mtk]>
size of 4103_20006788AppPic.png = 103259
[dtv_app_mtk]>
size of 4546_20006806.png = 3420
[dtv_app_mtk]>
size of 4546_20006806AppPic.png = 63313
[dtv_app_mtk]>
size of 4547_20006833.png = 7677
[dtv_app_mtk]>
size of 4547_20006833AppPic.png = 58929
[dtv_app_mtk]>
size of 3059_20006684.png = 19059
[dtv_app_mtk]>
size of 3059_20006684AppPic.png = 12720
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[CNettvLibGlueImpl.cpp][1251], setAppInfo() freesize = 60393, totalSize = 62464, App: 4823_52870=1&5048_52845=1&20004317_20004875=1&4103_20007291=36&4546_20009314=44&4547_20010030=42&3059_20009176=27&20004333_20009184=4&20004318_20004876=1&5443_52874=1
[dtv_app_mtk]>
size of 20004333_20007121.png = 25466
[dtv_app_mtk]>
size of 20004333_20007121AppPic.png = 85132
[dtv_app_mtk]>
size of 4103_20007291.png = 6748
[dtv_app_mtk]>
size of 4103_20007291AppPic.png = 103259
[dtv_app_mtk]>
size of 4546_20007307.png = 3420
[dtv_app_mtk]>
size of 4546_20007307AppPic.png = 63313
[dtv_app_mtk]> I imnettv.c[2680] IMnettvP_SetAppInfo freeSize:60393, totalSize:62464, AppInstalled len:166, AppInstalled:4823_52870=1&5048_52845=1&20004317_20004875=1&4103_20007291=36&4546_20009314=44&4547_20010030=42&3059_20009176=27&20004333_20009184=4&20004318_20004876=1&5443_52874=1
[dtv_app_mtk]>
size of 4547_20007308.png = 7677
[dtv_app_mtk]>
size of 4547_20007308AppPic.png = 58929
[dtv_app_mtk]>
size of 4546_20008341.png = 9889
[dtv_app_mtk]>
size of 4546_20008341AppPic.png = 63313
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[CNettvLibGlueImpl.cpp][1503], channelinterate_thread() channelinterate_thread, reason=0
[dtv_app_mtk]>
size of 3059_20008485.png = 18159
[dtv_app_mtk]>
size of 3059_20008485AppPic.png = 12720
[dtv_app_mtk]>
size of 20004333_20008489.png = 22471
[dtv_app_mtk]> [NETTV:19:21:36]!=!=!=!=========== start thread id(1778381904): detached(1),name:Ntv2
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[CNettvLibGlueImpl.cpp][1771], set_reason() 0
[dtv_app_mtk]>
size of 20004333_20008489AppPic.png = 85132
[dtv_app_mtk]>
size of 4546_20009147.png = 7928
[dtv_app_mtk]>
size of 4546_20009147AppPic.png = 63313
[dtv_app_mtk]>
size of 3059_20009176.png = 18159
[dtv_app_mtk]>
size of 3059_20009176AppPic.png = 12720
[dtv_app_mtk]>
size of 20004333_20009184.png = 22471
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[CNettvLibGlueImpl.cpp][1524], channelinterate_thread() channelinterate_thread, force to update when init (quited as network not ready)
[dtv_app_mtk]>
size of 20004333_20009184AppPic.png = 85132
[dtv_app_mtk]>
size of 4546_20009314.png = 7928
[dtv_app_mtk]>
size of 4546_20009314AppPic.png = 63313
[dtv_app_mtk]>
size of 4547_20009862.png = 54670
[dtv_app_mtk]>
size of 4547_20010030.png = 54670
[dtv_app_mtk]>
free size = 60393 KB
[dtv_app_mtk]>
total size = 62464 KB
[dtv_app_mtk]>
file size = 6135 bytes
[dtv_app_mtk]>
read string = {
[dtv_app_mtk]>mount: none already mounted or /sys/kernel/debug busy
[dtv_app_mtk]>
"numberOfAppsInstalled":12,
[dtv_app_mtk]>
"applicationInstalled":[{
[dtv_app_mtk]>
"applicationName":"YouTube",
[dtv_app_mtk]> I imnettv.c[1129] IMnettvP_SetConnectionState entry. states=1
[dtv_app_mtk]>
"applicationIconURI":"/3rd_rw/html5/dash/HomeMenu/current/app/4823_52870.png",
[dtv_app_mtk]>
"applicationId":"4823_52870",
[dialserver]>[DIAL][mtk_ntv_client_register_listener][multi_screen_client.c][222][685] Leave
[dtv_app_mtk]>
"appVersion":"1",
[dtv_app_mtk]> I imnettv.c[1133] IMnettvP_SetConnectionState Connection state: 1
[dialserver]>[DIAL][mtk_ntv_client_register_listener][multi_(!) IComaComponent::Listen( &#39;MTK_TV_BRDCST_NFY&#39; ) failed!
[dtv_app_mtk]>mount: according to mtab, none is already mounted on /sys/kernel/debug
[dialserver]> --> Attempted to exceed limit, i.e. any kind of maximum size, count etc
[dtv_app_mtk]> I imnettv.c[1183] IMnettvP_SetConnectionState exit.
[dialserver]>screen_client.c][199][685] Enter, ntvcoma_client = 0x38c58
[dtv_app_mtk]>
"applicationInfo":"Наслаждайтесь любимыми видео и музыкой, загружайте оригинальный контент и делитесь ими с друзьями, семьей и миром на YouTube.",
[dtv_app_mtk]>
"appGArray size = 10
[dialserver]>[DIAL][MS_CLIENT_init][multi_screen_client.c][380][685] Leave
[dtv_app_mtk]>[1674:1783:0328/132617:19824322:ERROR:browser_main_loop.cc(217)] Running without the SUID sandbox.
[dialserver]>DTV_MS_CLIENT_init is starting
[dialserver]>[DIAL][DTV_MS_CLIENT_init][dtv_multi_screen_client.c][420][685] Enter
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event24, line:7204, waiting for dacAPP start.
[dialserver]>[DIAL][mtk_dtv_client_init][dtv_multi_screen_client.c][136][685]Etner
[dialserver]>[DIAL][mtk_dtv_client_register_listener][dtv_multi_screen_client.c][199][685]Enter, dtvcoma_client = 0x38e48
[dtv_app_mtk]>
[dtv_app_mtk]>insmod: error inserting &#39;/basic/modules/snd-mtk.ko&#39;: -1 Unknown symbol in module
[dtv_app_mtk]>(!) DirectFB/Config: *********** In config file `/etc/directfbrc.jsapp&#39;: Invalid option `player-name&#39;! ***********
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>(!) DirectFB/Config: *********** In config file `/etc/directfbrc.jsapp&#39;: Invalid option `player-vendor&#39;! ***********
[dtv_app_mtk]>
[dtv_app_mtk]>(!) DirectFB/Config: *********** In config file `/etc/directfbrc.jsapp&#39;: Invalid option `player-model&#39;! ***********
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>(!) DirectFB/Config: *********** In config file `/etc/directfbrc.jsapp&#39;: Invalid option `proxy-memory-max&#39;! ***********
[dtv_app_mtk]>
[dtv_app_mtk]>(!) DirectFB/Config: *********** In config file `/etc/directfbrc.jsapp&#39;: Invalid option `proxy-surface-max&#39;! ***********
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>(!) DirectFB/Config: *********** In config file `/etc/directfbrc.jsapp&#39;: Invalid option `proxy-layer-mask&#39;! ***********
[dtv_app_mtk]>(!) DirectFB/Config: *********** In config file `/etc/directfbrc.jsapp&#39;: Invalid option `proxy-stacking-mask&#39;! ***********
[browser_base]>[TVC_MAIN]:Return fail:tv_ctrl_init:1400:-1
[dtv_app_mtk]>
[dtv_app_mtk]>
Actual AppInstalled = 4823_52870=1&5048_52845=1&20004317_20004875=1&4103_20007291=36&4546_20009314=44&4547_20010030=42&3059_20009176=27&20004333_20009184=4&20004318_20004876=1&5443_52874=1
[dtv_app_mtk]>
mali already inserted
[dtv_app_mtk]>mali memory_usage_confugured
[dtv_app_mtk]> ~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.5.3 |~~~~~~~~~~~~~~~~~~~~~~~~~~
[dtv_app_mtk]> (c) 2001-2010 The world wide DirectFB Open Source Community
[dtv_app_mtk]>[_nav_cec_sys_info_dev_discovery]ERROR, line[212], ret = [-3]
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]> (c) 2000-2004 Convergence (integrated media) GmbH
[dtv_app_mtk]> ----------------------------------------------------------------
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>dtv_svc post init start gen_radt().
[dtv_app_mtk]>
# mount demo
[dtv_app_mtk]>[FM-Linux]Mount /dev/mmcblk0p15 to /demo successfully.
[dtv_app_mtk]>(*) DirectFB/Core: Multi Application Core. (Thu Mar 28 19:17:53 CST 2019)
[browser_base]>[AM_CLIENT]parse cmd ready
[dtv_app_mtk]>(*) Direct/Memcpy: Using libc memcpy()
[dtv_app_mtk]>
[Mxtv]> (main:435)
[dtv_app_mtk]>TPV IP SW - MXTV (18.01.00.44) start running
[dtv_app_mtk]>(*) Fusion/SHM: Using MADV_REMOVE (3.18.25.0 >= 2.6.19.2)
[AM][ProcessControl.cpp][setState][2962][tid680]dtv_app_mtk:(2 -> 2 )
[dtv_app_mtk]>(*) Direct/Thread: Started &#39;Fusion Dispatch&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[dtv_app_mtk]>[Mxtv]> (main:518)xtv fusiondale server is started!![Mxtv]> (main:522)IMxtvR_Env_Init() is called
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/module/ntfs <<<<<
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/module/ntfs
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/module/ntfs
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/kernel/slab/:at-0000200 <<<<<
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/kernel/slab/ntfs_big_inode_cache <<<<<
[dtv_app_mtk]>[Mxtv]> (channels_GetActiveChnList:1273)activeChannelList: 4_
[dtv_app_mtk]>(*) Direct/Thread: Started &#39;Fusion Deferred&#39; (-1) [MESSAGING OTHER/OTHER 0/0] <8388608>...
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/kernel/slab/ntfs_big_inode_cache
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/kernel/slab/ntfs_big_inode_cache
[dtv_app_mtk]>[Mxtv]> (ambilight_hue_Init:5374)IMxtvR_System_GetModel: 1_43PUS6503/60
[browser_base]>[TVC_MAIN] LINE: 549 PAGE INFO: {"PageID":"HTML5_UI_PAGE_SYS_INDEX","Status":"Show","Resolution":"720P"}!
[dtv_app_mtk]>[Mxtv]> (main:551)
[dtv_app_mtk]>TPV IP SW - MXTV (18.01.00.44) initialization - Successful
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/module/usbhid <<<<<
[dtv_app_mtk]>(*) DirectFB/MT53: DFB[vir=0x8a569000,phy=0x8a569000,size=0x48a9000]
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/module/usbhid
[dtv_app_mtk]>(*) DirectFB/MT53: t_crsr[vir=0x8a55f000,phy=0x8a55f000,size=0xa000]
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(26), window hadnle((nil)), data(0x598ed0)
[dtv_app_mtk]>(!) DirectFB/MT53: FBIO_CRSR_INFO failed!
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/module/usbhid
[dtv_app_mtk]>[Mxtv]> (notifychangeHdlr:1413)notifychangeHdlr starts working
[dtv_app_mtk]>[FM](/dev/mmcblk0p15) is mounted to (/demo) successfully(0)
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/bus/usb/drivers/usbhid <<<<<
[dtv_app_mtk]>
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/bus/usb/drivers/usbhid
[dtv_app_mtk]> --> Invalid argument
[dtv_app_mtk]>(*) MediaTek/Driver: Mapped shared command queue control structure to 0xb4cda000
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/bus/usb/drivers/usbhid
[dtv_app_mtk]>
{sys start downloadable }. start mount downloable .
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/module/mtk_mmap <<<<<
[dtv_app_mtk]>
[FM-Linux]Mount /dev/mmcblk0p31 to /downloadable successfully.
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/module/mtk_mmap
[dtv_app_mtk]>(*) MediaTek/Driver: Mapped DMA region to 0xb4c9a000
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/module/mtk_mmap
[dtv_app_mtk]>(*) MediaTek/Driver: GFX_CmdQueInit( 0xb4cda000, 0xc4e08 )
[dtv_app_mtk]>
[FM](/dev/mmcblk0p31) is mounted to (/downloadable) successfully(0)
[browser_base]>[udetect] _get_attr_product_id.796: open idProduct fail, errno = No such file or directory
[dtv_app_mtk]>(*) DirectFB/Graphics: MediaTek 53xx 0.3 (Denis Oliver Kropp)
[browser_base]>[udetect] _get_attr_vendor_id.841: open idVendor fail, errno = No such file or directory
[dtv_app_mtk]>dfb_set_cursor_border [0,0-1920,0-1080]
[dtv_app_mtk]>(*) SaWMan/Config: Parsing config file &#39;/etc/sawmanrc&#39;.
[browser_base]>[udetect] _mtp_get_dev_pvid.762: i4_product_id = 0, i4_vendor_id = 0
[dtv_app_mtk]>
[browser_base]>[udetect] is_mtp_device_be_handled.619: Parse device PVID fail, ret = -1
[dtv_app_mtk]>
[TVAPI] <mtktvapi_network.c: 844:a_mtktvapi_nw_register> network_nfy_id: 2.
[dtv_app_mtk]>
_hndlr_a_mtktvapi_nw_register 0
[dialserver]>[DIAL][mtk_dtv_client_register_listener][dtv_multi_screen_client.c][222][685]Leave
[browser_base]>page_info = {"PARAMETER":{"VALUE":"{\"PageID\":\"HTML5_UI_PAGE_SYS_INDEX\",\"Status\":\"Show\",\"Resolution\":\"720P\"}","REQUEST":"MODIFY"}}, 129
[browser_base]>[681:960:0328/132618.667503:21156678:INFO:CONSOLE(301)] "got page id: HTML5_UI_PAGE_SYS_INDEX", source: file:///3rd/html5/libs/mtvui/base.js (301)
[dialserver]>[DIAL][DTV_MS_CLIENT_init][dtv_multi_screen_client.c][481][685]Leave
[dialserver]>[DIAL][runDial][main.c][259][685]Enter
[browser_base]>
[dialserver]>[DIAL][runDial][main.c][263][685]DIAL_register_app netflix
[dialserver]>[DIAL][runDial][main.c][273][685]DIAL_register_app YouTube
[dialserver]>[DIAL][runDial][main.c][283][685]DIAL_register_app BBC
[dialserver]>[DIAL][runDial][main.c][298][685]DIAL_register_app NETTV
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(1), window hadnle(0x249a00), data(0x51d540)
[dialserver]>[DIAL][runDial][main.c][307][685]DIAL_register_app Amazon
[dialserver]>[DIAL][runDial][main.c][316][685]DIAL_start
[dialserver]>launcher listening on gDialPort 56789
[dialserver]>[DIAL][runDial][main.c][320][685]run_ssdp
[dialserver]>[DIAL][run_ssdp][quick_ssdp.c][486][685]begin
[browser_base]>[bws_app][Default][L495]HandleEvt_Custom : open epg_launch_method file fail!
[dtv_app_mtk]>
[browser_base]>
[browser_base]>[JSP_CONSOLE][LVL = 0] 000001000000000010000110,
[browser_base]>[TVC_MAIN] i18n dynamic lib path: [/3rd/i18n/RUS.so].
[dtv_app_mtk]>
[browser_base]>a_mtktvapi_pus_init:309
[dtv_app_mtk]>
ui1_num: 0
[browser_base]>[TVC_MAIN]:Return fail:tv_ctrl_pus_init:213:-3
[dtv_app_mtk]>
[browser_base]>[TVC_JSP] [_jsp_tvapi_advMsg][3125] --> p_jspv_argv[0]=smallAdv
[browser_base]>[TVC_MAIN]:Return fail:tv_ctrl_init:1423:-1
[dtv_app_mtk]>
=========getConfigValueStruct, 6551, get string: 43PUS6503/60
[browser_base]>[x_dlna_dmr_start][371]:Come in
[dtv_app_mtk]>
[GCC] -2, on line 139 in _optl_get_attach_data()
[browser_base]>[DMR]path is /3rd_rw/dlna/xml/dmr.xml
[dtv_app_mtk]>
[GCC] -1, on line 4738 in a_optl_set_option_items()
[browser_base]>netif patch is enabled
[dtv_app_mtk]> I window_manager.cc[0101] window_manager Opera window manager created.
[browser_base]>[TVC_JSP] [_jsp_tvapi_advMsg][3125] --> p_jspv_argv[1]=OPEN_WIN BOUNDS= x=20 y=617 w=300 h=250 URL=file:///3rd/html5/php/dash/adv/adv.html
[dtv_app_mtk]>
{NAVIGATOR} [NAV] Return fail:option_list_view_list.c:1120:-1
[dtv_app_mtk]>
[dtv_app_mtk]> I browser_controller.cc[4655] brctl_init_opera After calling opera_init() drowser directFB window = 3
[dtv_app_mtk]>
[dtv_app_mtk]>
[GCC] -1, on line 5064 in a_optl_set_hlt_index()
[dtv_app_mtk]>
{NAVIGATOR} [NAV] Return fail:option_list_view_list.c:1125:-1
[dtv_app_mtk]> I browser_controller.cc[0609] update_user_agent TV brand is 0
[dtv_app_mtk]>
[GCC] -2, on line 181 in _ckb_get_attach_data()
[dtv_app_mtk]>
[GCC] -1, on line 751 in a_ckb_set_visibility()
[dtv_app_mtk]>
[GCC] -2, on line 818 in a_ckb_repaint()
[dtv_app_mtk]> I window_manager.cc[0125] create_window Creating window id 0
[dtv_app_mtk]>
[dtv_app_mtk]>
[GCC] -1, on line 5411 in a_optl_show()
[dtv_app_mtk]> I window_manager.cc[0157] create_window Added window 0, handle 64
[dtv_app_mtk]>
{NAVIGATOR} [NAV] Return fail:option_list_view_list.c:1183:-1
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]> I window_manager.cc[1237] load_url Loading url in window 64
[browser_base]>DMR start!
[dtv_app_mtk]> I window_manager.cc[0125] create_window Creating window id 1
[browser_base]>[ZJ][x_dlna_dmr_start][406]i4_ret is 0
[browser_base]>[DMR]extended log is off
[dtv_app_mtk]>
[browser_base]>[x_dlna_dmr_start][447]:Leave
[dtv_app_mtk]>
[NAV_CEC_SAC] Enable TV spk
[dtv_app_mtk]>
[NAV_CEC_ARC][_nav_cec_arc_is_ignore_arc_func]ui2_cecm_pa = 0xdead, b_ignore = 1
[dtv_app_mtk]> I window_manager.cc[0157] create_window Added window 1, handle 128
[dtv_app_mtk]>
{NEW NETTV_RPC}Fun:_hndlr_a_get_tou_status, Ln:104
[dtv_app_mtk]>
{NETTVAPI}Fun:a_get_tou_status, Ln:2305
[browser_base]>x_dlna_dmr_getname: status is ON
[dtv_app_mtk]>
NetTVToU
[browser_base]>[TVC_JSP] [_jsp_tvapi_advMsg][3125] --> p_jspv_argv[1]=HIDE_WIN
[dtv_app_mtk]> I window_manager.cc[1237] load_url Loading url in window 128
[browser_base]>[bws_app][Critical][L987]bws_brctl_handle_ext_message : Nicolas: message from HOME UI, cmd=1 OPEN_WIN BOUNDS= x=20 y=617 w=300 h=250 URL=file:///3rd/html5/php/dash/adv/adv.html
[dtv_app_mtk]>
[acfg_custom_ihs.c][390][NetTVToU][1]
[browser_base]>
[dtv_app_mtk]>
a_get_tou_status = NetTVToU
[dtv_app_mtk]>
TouStatus = 1
[browser_base]>[bws_app][Critical][L172]get_ADS_url : !!! Not found /tmp/DAUs.txt, Please Signon at first!
[dtv_app_mtk]> I window_manager.cc[0125] create_window Creating window id 4
[browser_base]>
[dtv_app_mtk]> I window_manager.cc[0157] create_window Added window 4, handle 192
[browser_base]>[bws_app][Critical][L987]bws_brctl_handle_ext_message : Nicolas: message from HOME UI, cmd=1 HIDE_WIN
[browser_base]>
[dtv_app_mtk]> I window_manager.cc[1237] load_url Loading url in window 192
[browser_base]>[bws_app][Default][L741]handle_small_adv_message : rcv HIDE_WIN msg =HIDE_WIN
[dtv_app_mtk]> I window_manager.cc[0125] create_window Creating window id 9
[browser_base]>
[browser_base]>[bws_app][Default][L749]handle_small_adv_message : HIDE_WIN finished!
[dtv_app_mtk]> I window_manager.cc[0157] create_window Added window 9, handle 256
[browser_base]>
[dtv_app_mtk]> I window_manager.cc[1237] load_url Loading url file:///usr/opera/opera_dir/pages/options_menu/page.html in window 256
[browser_base]>
[dtv_app_mtk]> I window_manager.cc[0125] create_window Creating window id 26
[dtv_app_mtk]> I window_manager.cc[0157] create_window Added window 26, handle 320
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(1), window hadnle(0x4a1800), data(0x4af030)
[dtv_app_mtk]> I window_manager.cc[1237] load_url Loading url file:///usr/opera/opera_dir/pages/edfu/data.html?diver=43PUS650360?device=0?lang=ru-RU in window 320
[dtv_app_mtk]> I imnettv.c[2730] nettvapp_intfR_SendMessage entry.
[dtv_app_mtk]> I imnettv.c[2755] nettvapp_intfR_SendMessage exit.
[dtv_app_mtk]> I browser_proxy.c[0695] _brpxy_thread BRPXY_NTF_BROWSER_INITED
[dtv_app_mtk]> I browser_proxy.c[2094] brpxy_set_localtime TimeZone [0] DayTimeSaving [0]
[dtv_app_mtk]> I browser_controller.cc[4058] brctl_command_thread brctl_command_thread~~~~~~~~~~~~~~~~11-10 22:04
[dtv_app_mtk]> W window_manager.cc[0873] window_exists window with id 7 does not exists.
[dtv_app_mtk]> E opera_agent.cc[0644] execute_javascript Javascript cannot be executed in window 7.
[dtv_app_mtk]> W window_manager.cc[0873] window_exists window with id 13 does not exists.
[dtv_app_mtk]> E opera_agent.cc[0644] execute_javascript Javascript cannot be executed in window 13.
[dtv_app_mtk]> W window_manager.cc[0873] window_exists window with id 14 does not exists.
[dtv_app_mtk]> E opera_agent.cc[0644] execute_javascript Javascript cannot be executed in window 14.
[dtv_app_mtk]> E opera_agent.cc[0644] execute_javascript Javascript cannot be executed in window 22.
[dtv_app_mtk]> E opera_agent.cc[0644] execute_javascript Javascript cannot be executed in window 24.
[dtv_app_mtk]> W window_manager.cc[0873] window_exists window with id 25 does not exists.
[dtv_app_mtk]> E opera_agent.cc[0644] execute_javascript Javascript cannot be executed in window 25.
[dtv_app_mtk]> W window_manager.cc[0873] window_exists window with id 27 does not exists.
[dtv_app_mtk]> E opera_agent.cc[0644] execute_javascript Javascript cannot be executed in window 27.
[browser_base]>sendUIHtml5Message: ENTER i4_callback_type=0 key_SYM=0x326 keyType=0x0
[browser_base]>sendUIHtml5Message: LEAVE
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>sendUIHtml5Message: ENTER i4_callback_type=0 key_SYM=0x1B0 keyType=0x0
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[_nav_pwr_view_reset_off_timer]ui4_timer_type[1],b_is_vga[0]
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
<MSCVT>recv key bf10c status 259 ,0
[dtv_app_mtk]>
<MSCVT>recv key bf10c status 260 ,0
[dtv_app_mtk]> I RecordingSchedule.cpp[0032] RecordingSchedule *** Create RecordingSchedule object.
[dtv_app_mtk]> I browser_controller.cc[6519] _handle_loading_started_event Window = 256 (opw = 9) Loading of URL &#39;file:///usr/opera/opera_dir/pages/options_menu/page.html&#39; started
[dtv_app_mtk]> I browser_controller.cc[6573] _handle_loading_finished_event handle opera event -> LoadingFinished::TYPE Window = 256(opw=9) Loading of URL &#39;file:///usr/opera/opera_dir/pages/options_menu/page.html&#39; finished
[dtv_app_mtk]> E browser_controller.cc[6629] _handle_loading_finished_event error_code -3, message net::ERR_ABORTED, HTTP status code 0
[dtv_app_mtk]> I browser_controller.cc[6519] _handle_loading_started_event Window = 320 (opw = 26) Loading of URL &#39;file:///usr/opera/opera_dir/pages/edfu/data.html?diver=43PUS650360?device=0?lang=ru-RU&#39; started
[dtv_app_mtk]> I browser_controller.cc[6573] _handle_loading_finished_event handle opera event -> LoadingFinished::TYPE Window = 320(opw=26) Loading of URL &#39;file:///usr/opera/opera_dir/pages/edfu/data.html?diver=43PUS650360?device=0?lang=ru-RU&#39; finished
[browser_base]>[bws_app][Default][L1369]HandleHtml5AgentKey : rBwsStartInfo.i4CurWinIndex = 0
[dtv_app_mtk]>
[browser_base]>CBwsWindowList::SendKeyDirect m_i4CurrentIndex = 0
[dtv_app_mtk]>
[phm_ch_sat_dump_lol] get locators number = 0
[browser_base]>[bws_app][Default][L1413]HandleHtml5AgentKey : keyEvent = 0, keyCode = 806
[dtv_app_mtk]>
[browser_base]>
[browser_base]>[JSP_CONSOLE][LVL = 0] file:///3rd/html5/libs/jquery/dist/jquery.min.js:3:6466 sys_index key = 806,
[dtv_app_mtk]>
[OCL_TEST] a_cfg_get_crnt_channel_id_by_bs_type() ui1_bs_type[2],ui4_channel_id[786561], ui1_elem_idx[0]
[dtv_app_mtk]> I imnettv.c[3511] nettvapp_intfR_pvr_GetRecordingSchedule Calling IMnettvR_pvr_GetScheduledList[0][0x752ee0e0]
[dtv_app_mtk]> E cul_tou.cpp[0098] RestoreTouStatus /mnt/browser/tou/tou_acceptance.txt is not exist!
[browser_base]>[bws_app][Default][L1413]HandleHtml5AgentKey : keyEvent = 0, keyCode = 432
[browser_base]>
[browser_base]>[JSP_CONSOLE][LVL = 0] file:///3rd/html5/libs/jquery/dist/jquery.min.js:3:6466 sys_index key = 432,
[browser_base]>[TVC_MAIN] LINE: 549 PAGE INFO: {"PageID":"HTML5_UI_PAGE_CHANNEL_ZAPPER","Status":"Show","Resolution":"720P"}!
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(26), window hadnle((nil)), data(0x598ef0)
[dtv_app_mtk]> I imnettv.c[2031] IMnettvP_ipepg_SendChannelList IMnettvP_ipepg_SendChannelList: 0
[browser_base]>page_info = {"PARAMETER":{"VALUE":"{\"PageID\":\"HTML5_UI_PAGE_CHANNEL_ZAPPER\",\"Status\":\"Show\",\"Resolution\":\"720P\"}","REQUEST":"MODIFY"}}, 134
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[CNettvLibGlueImpl.cpp][1771], set_reason() 5
[dtv_app_mtk]>[NETTV][M]>>>>>>>>>>[CNettvLibGlueImpl.cpp][1503], channelinterate_thread() channelinterate_thread, reason=5
[dtv_app_mtk]>
[NW]Received NET_COND_T -> 0
[dtv_app_mtk]>
[NW]Start to init the network
[dtv_app_mtk]>[WIFI_MW][Enter]c_net_wlan_wpa_reg_cbk :
[dtv_app_mtk]>[WIFI_MW] x_net_wlan_wpa_reg_cbk pfNotify b1ef4eac!
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]c_net_wlan_task_create :
[dtv_app_mtk]>
[NW]Received ni notify -> 2
[dtv_app_mtk]>
[NW]Received ni wifi notify -> 1
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[/sbin/ifconfig.script] args 6: ip_mask eth0 0.0.0.0 0.0.0.255 gw 0.0.0.0
[dtv_app_mtk]>[/sbin/ifconfig.script] ifconfig eth0 0.0.0.0
[dtv_app_mtk]>[WIFI_MW][Enter]c_net_wlan_start_driver :
[dtv_app_mtk]>[WIFI_MW] x_net_wlan_start_driver isP2p 0
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] sema_create h_startdriversema success
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> isP2p 0 lock here
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] _start_wlan_driver. 799767f4, 0
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] _start_wlan_driver. notify function b1ef2464
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>> _start_wlan_driver return ok unlock!
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] [WIFI_MW] >>>>>>> _start_wlan_supplicant_thread,pvArg 0x 0,isp2p 0
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wifi0_check, ra0, 748,
[dtv_app_mtk]>
[dtv_app_mtk]> Return fail:c_net_wlan_api.c:84:-10
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wifi0_check, ath0, 748,
[dtv_app_mtk]>
[dtv_app_mtk]>[NW]End to init the network
[dtv_app_mtk]>
[NW]Handle the ni notify -> 2
[dtv_app_mtk]>
[NW]change lock status function is _nw_ip_ni_notify_hdlr, line is 938
[dtv_app_mtk]>
[NW_NOTIFY]NI_DRV_EV_ETHERNET_UNPLUG
[dtv_app_mtk]>
[NW_NOTIFY]NI_DRV_EV_ETHERNET_UNPLUG33
[dtv_app_mtk]>
[NW]change lock status function is _nw_ip_ni_notify_hdlr, line is 1018
[dtv_app_mtk]>
[dtv_app_mtk]>
[NW]Handle the ni wifi notify -> 1
[dtv_app_mtk]>
[NW]change lock status function is _nw_ip_ni_wlan_notify_hdlr, line is 3235
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[NW_NOTIFY]NI_DRV_EV_WLAN_ASSOC
[dtv_app_mtk]> I imnettv.c[0852] IMnettvP_SetCommand entry. eventID: 5
[dtv_app_mtk]> I imnettv.c[0869] IMnettvP_SetCommand exit.
[dtv_app_mtk]>
<PHM_NWZD> [_phm_nwzd_model_resume_network_wzd_by_3rd_app][9600] Resume network wizard.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>:dtv_app_mtk,am,:stop=dmr
[dtv_app_mtk]>
[dtv_app_mtk]><PHM_NWZD> [_phm_nwzd_model_resume_network_wzd_by_3rd_app][9617] network interface is not eth0.
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wifi0_check, rea0, 748,
[dtv_app_mtk]>
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event17, line:4623, waiting for dacAPP start.
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wifi0_check, wlan0, 748,
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> _start_wlan_supplicant_thread,829,find interface wlan0
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> _start_wlan_supplicant_thread,844,cmd_path /3rd/bin/wpa_supplicant/common/wpa_supplicant
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> _start_wlan_supplicant_thread,845,cmd interface -iwlan0
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>_strart_wlan_driver_thread;p2p_name p2p0!
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] [WIFI_MW] >>>>>>> wifi0_check, p2p0, 748,
[dtv_app_mtk]>
[dtv_app_mtk]>>>>>>_strart_wlan_driver_thread;wifi0_check(p2p_name) 0!
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> _start_process,725,in
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> _start_process,733,in father child pid 2114
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> _start_process,728,in child child
[dtv_app_mtk]>
[dtv_app_mtk]>
>>>> this script is used check whether supplicant is ready
[dtv_app_mtk]>check whether wpa_supplicnat is started ...
[dtv_app_mtk]>Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
[dtv_app_mtk]>Waiting supplicant to be ready...
[browser_base]>[TVC_MAIN]:Return fail:_tv_ctrl_config_get_value_number:327:-3
[browser_base]>
[browser_base]> new now.
[browser_base]>
[browser_base]> not new.
[browser_base]>[x_dlna_dmp_start][1703]:ZJV1 Come in
[browser_base]>Startup DMP thread
[browser_base]>[ZJ][dmp_start][41]: dmp start
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0 <<<<<
[browser_base]>
[browser_base]> <dmsdetect>: dmsdetect/DmsRecordQueue.cpp | 272 | Warning | Get not support dlna device type 4
[browser_base]>.
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0/queues/rx-0 <<<<<
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0/queues/rx-0
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0/queues/rx-0
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0/queues/tx-0 <<<<<
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0/queues/tx-0
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/p2p0/queues/tx-0
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0 <<<<<
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0/queues/rx-0 <<<<<
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0/queues/rx-0
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0/queues/rx-0
[browser_base]>[udetect] _usb_mon.976: >>>>> >>>>> add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0/queues/tx-0 <<<<<
[browser_base]>[udetect] add_mtp_dev.548: enter the add_mtp_dev msg = add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0/queues/tx-0
[browser_base]>[udetect] add_mtp_dev.577: ADD MTP DEV to list add@/devices/platform/MtkUsbHcd.1/usb4/4-1/net/uap0/queues/tx-0
[browser_base]>[DLNA]Enter a new dlna device!
[browser_base]>[DMP][dlna_dmp_device_callback][856]Find DMS, id : 0x563cf0, name : Local Renderer
[browser_base]>dmp version Ver1.5 Rel6.0 starts
[browser_base]>[x_dlna_dmp_start][1729]:ZJV1 Leave
[browser_base]>
[browser_base]>[CB] a_mtktvapi_dmr_file_destroy().
[browser_base]>[x_dlna_dmr_stop][464]:Come in
[browser_base]>[x_dlna_dmr_stop][480]:Leave
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] Return fail:c_net_wlan_api.c:84:-10
[dtv_app_mtk]>
[NW]change lock status function is _nw_ip_ni_wlan_notify_hdlr, line is 3266
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[INFO] START FUNC: _tvap_update_nw_status, LINE: 271.
[dtv_app_mtk]> I imnettv.c[1129] IMnettvP_SetConnectionState entry. states=3
[dtv_app_mtk]>
[INFO] FUNC: _tvap_update_nw_status, LINE: 296.
[dtv_app_mtk]> I imnettv.c[1133] IMnettvP_SetConnectionState Connection state: 3
[dtv_app_mtk]>
[NW]Get current DHCP status.
[dtv_app_mtk]>
[NW]change lock status function is a_nw_get_dhcp_status, line is 4617
[dtv_app_mtk]>
[NW]change lock status function is a_nw_get_dhcp_status, line is 4621
[dtv_app_mtk]>
[NW]Get current wlan status.
[dtv_app_mtk]>
[NW]change lock status function is a_nw_wlan_status, line is 6550
[dtv_app_mtk]>
[NW]change lock status function is a_nw_wlan_status, line is 6582
[dtv_app_mtk]>
supplicant is ready.
[dtv_app_mtk]>[WIFI_MW] >>>>>check_supplicant_ready_sh ret 0 errno No such device!
[dtv_app_mtk]>
[dtv_app_mtk]>[NW]WLAN CallbackId = 18.
[dtv_app_mtk]>[WIFI_MW] >>>>>>> notify wlan supp start ok pid is 2114
[dtv_app_mtk]>
[dtv_app_mtk]>
[NW]Handle the wlan msg ->[NW]change lock status function is _nw_wlan_notify_hdlr, line is 2651
[dtv_app_mtk]>
[NW_NOTIFY]WLAN_NOTIFY_DRIVER_START_IND
[dtv_app_mtk]>[WIFI_MW][Enter]c_net_wlan_open_connection : ifname = (null)
[dtv_app_mtk]>[WIFI_MW] wifi_sema_init h_wlan_socket_sema success
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] [WPA_CTRL] Enter wpa_ctrl_open ctrl_path = /var/run/wpa_supplicant/wlan0.
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] {unlink} wpa_ctrl_open.bind() ctrl->s 78, ctrl->local.sun_path : /var/run/wlan_ctl
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] wpa_ctrl_open.bind() i4bind 0.
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] wpa_ctrl_open.connect() ctrl->s 78, ctrl->dest.sun_path : /var/run/wpa_supplicant/wlan0
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] [WPA_CTRL] Leave wpa_ctrl_open(),conn = 0.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] {unlink} wpa_ctrl_open.bind() ctrl->s 79, ctrl->local.sun_path : /var/run/wlan_nfy
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] wpa_ctrl_open.connect() ctrl->s 79, ctrl->dest.sun_path : /var/run/wpa_supplicant/wlan0
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] [WPA_CTRL] Enter wpa_ctrl_attach.
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] [WPA_CTRL] Enter wpa_ctrl_attach_helper.
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] wifi_open_connection -> success!
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] c_net_wlan_thread_init. in this func
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] c_net_wlan_thread_init.start creat thread
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] [WIFI_MW][Enter]c_net_wlan_get_mac_addr :
[dtv_app_mtk]>_wlan_msg_proc_thread START.
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] pMacAddr = 50:5B:C2:01:91:C5
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] WPS PIN = [41009505]
[dtv_app_mtk]>
[dtv_app_mtk]>
[NW]change lock status function is _nw_wlan_notify_hdlr, line is 2817
[dtv_app_mtk]>
[NW]_nw_wlan_notify_hdlr end.
[dtv_app_mtk]>
[dtv_app_mtk]>
[NW_NOTIFY]WLAN_NOTIFY_START_IND
[dtv_app_mtk]>[WIFI_MW][Enter]c_net_wlan_associate :
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] wlan_associate ssid[Artem] auth[11]cipher[16]
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_associate : Ssid=Artem,len=5,e_AssocCase=0, Cipher=16, Mode=11, b_IsAscii=1, pass_phrase=bf012280, bssid=e0:3f:49:d0:e4:08, prio=0.
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> doBooleanCommand,239,REPLY IS= OK
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_set_remove_network :
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_set_add_network :
[dtv_app_mtk]>[WIFI_MW] >>>>>>> doBooleanCommand,239,REPLY IS= 0
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 auth_alg OPEN
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_set_auth_mode_wpa2_psk :
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 key_mgmt WPA-PSK
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 proto RSN
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[NW]change lock status function is _nw_wlan_notify_hdlr, line is 2817
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] psk=bf012280, lenth=8.
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 psk "bf012280"
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 pairwise CCMP TKIP
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 group CCMP TKIP
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_set_scan_ssid_network :
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 scan_ssid 1
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_set_ssid_network :
[dtv_app_mtk]>[WIFI_MW] >>>>>>> wlan_set_network,654, cmd = SET_NETWORK 0 ssid "Artem"
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] ssid = "Artem",ssid_len = 5
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_set_enable_network :
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW][Enter]wlan_set_reconnect_network :
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] Received event: <3>CTRL-EVENT-SCAN-STARTED
[dtv_app_mtk]>
[browser_base]>[TVC_MAIN] LINE: 549 PAGE INFO: {"PageID":"HTML5_UI_PAGE_SYS_INDEX","Status":"Show","PageSubStatus":"","Resolution":"720P"}!
[browser_base]>[bws_app][Default][L264]HandleEvt_Custom : Enter, event(26), window hadnle((nil)), data(0x558f30)
[browser_base]>page_info = {"PARAMETER":{"VALUE":"{\"PageID\":\"HTML5_UI_PAGE_SYS_INDEX\",\"Status\":\"Show\",\"PageSubStatus\":\"\",\"Resolution\":\"720P\"}","REQUEST":"MODIFY"}}, 152
[dtv_app_mtk]>
[dtv_app_mtk]>
Network_GetNetworkInfoByIdx Get ip info failed -4.
[dtv_app_mtk]>[OUT]Cannot get WIFI info: 1.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[OUT]Cannot get wired network info 1.
[dtv_app_mtk]>
[Mxtv]> (network_SortNetworkDevice:346)active devices is 0 - >
[dtv_app_mtk]>[Mxtv]> (network_Init:425)tv_mac_0: tv_mac_1:
[dtv_app_mtk]>[Mxtv]> (network_Init:436)network initialization fail
[dtv_app_mtk]>[acfg_custom.c][_acfg_custom_ch_logo_version_check_context_switch][39791]update channel logo id.
[dtv_app_mtk]>
[NETLINK]NEWADDR ADDRESS=fe80::505b:c2ff:fe01:91c5/64 INTERFACE=p2p0 FLAGS=128 SCOPE=253
[dtv_app_mtk]><bipc_get_edfu_datareadystate:884>BRCTL_NJSE_EDFUDATAREADY_STATE
[dtv_app_mtk]>[WIFI_MW] Received event: <3>CTRL-EVENT-SCAN-RESULTS
[dtv_app_mtk]>
[dtv_app_mtk]>
[NW]WLAN CallbackId = 4.
[dtv_app_mtk]>[WIFI_MW] C2H: notify-app: WLAN_NOTIFY_SCAN:WLAN_NFY_MSG_OK
[dtv_app_mtk]>
[dtv_app_mtk]>[WIFI_MW] Received event: <3>WPS-AP-AVAILABLE
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[NW_NOTIFY]WLAN_NOTIFY_SCAN
[dtv_app_mtk]>
[NW_NOTIFY]WLAN_NOTIFY_SCAN ok, stop timer
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[NW]WLAN CallbackId = 4.
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>Warning: bad ps syntax, perhaps a bogus &#39;-&#39;? See http://procps.sf.net/faq.html
[dtv_app_mtk]>errApp version #0x8810829
[dtv_app_mtk]>Build date: Fri 2018-06-29 03:50:01 EET
[dtv_app_mtk]>Options summary:
[dtv_app_mtk]>verbose : 0
[dtv_app_mtk]>Debug dump path: /3rd_rw/mcul/log
[dtv_app_mtk]>MaxCount : 25 files
[dtv_app_mtk]>MaxSize : 5242880 bytes
[dtv_app_mtk]>LogSize : 262144 bytes
[dtv_app_mtk]>Summaries : /3rd_rw/mcul/log/Summaries.txt
[dtv_app_mtk]>Summaries Size : 102400
[dtv_app_mtk]>Tv Sys Version : TPM186E_018.004.146.001
[dtv_app_mtk]>Boot-cycle : 60
[dtv_app_mtk]>Standby-cycle : 1
[dtv_app_mtk]>[CUL_amApp]u1Val = 1.
[dtv_app_mtk]>[CUL_amApp]bootcount -c -f /3rd_rw/mcul/bootinfo.txt successed.
[dtv_app_mtk]>[CUL_amApp]release_version buffer = TPM186E_018.004.146.001, artcount=24
[dtv_app_mtk]>[CUL_amApp]start errApp successed.
[dtv_app_mtk]>[CUL_amApp]Update Globalinfo.txt device ID successed.
[dtv_app_mtk]>[CUL_amApp]am_tv_lang buffer = rus, artcount=3
[dtv_app_mtk]>[CUL_amApp]Update Globalinfo.txt menu_language successed.
[dtv_app_mtk]>[CUL_amApp]production infrastructure of AWS.
[dtv_app_mtk]>[CUL_amApp]start dacApp successed.
[dtv_app_mtk]>[CUL_amApp]start gelApp successed.
[dtv_app_mtk]>CGelApp: Build date: Fri 2018-06-29 03:58:15 EET
[dtv_app_mtk]>CGelApp: Options summary:
[dtv_app_mtk]>CGelApp: verbose : 0
[dtv_app_mtk]>dacclientlib: mq_open failed: No such file or directory
[dtv_app_mtk]>dacclientlib:Log event failed: gel.start: {} URL=No URL
[dtv_app_mtk]>dacApp version: #0x06af56b
[dtv_app_mtk]>Build date: Fri 2018-06-29 03:39:30 EET
[dtv_app_mtk]>[36524](2893,2893) CDacApp: Options summary:
[dtv_app_mtk]>[36525](2893,2893) CDacApp: verbose : 0
[dtv_app_mtk]>[36525](2893,2893) CDacApp: Config file path : /3rd_rw/mcul/Config
[dtv_app_mtk]>[36525](2893,2893) CDacApp: DB file path : /3rd_rw/mcul/Db
[dtv_app_mtk]>[36525](2893,2893) CDacApp: Boot-cycle : 60
[dtv_app_mtk]>[36525](2893,2893) CDacApp: Standby-cycle : 1
[dtv_app_mtk]>[36525](2893,2893) CDacApp: SWVersion : TPM186E_018.004.146.001
[dtv_app_mtk]>[36525](2893,2893) CDacApp: DeviceId : 1008069313
[dtv_app_mtk]>[36525](2893,2893) CDacApp: TOU accepted in TV : true
[dtv_app_mtk]>[36525](2893,2893) CDacApp: TOU version in TV : 1
[dtv_app_mtk]>[36525](2893,2893) CDacApp: Config EventAgeThreshold : 3600
[dtv_app_mtk]>[36525](2893,2893) CDacApp: Config GetExpiryPeriod : 90000
[dtv_app_mtk]>ping: unknown host http://www.google.com
[dtv_app_mtk]>[36788](2893,2917) dacNetwork: Request Server URL https://dac-api-prod.tpv-analytics.com/prod/v1/time/ took 2ms
[dtv_app_mtk]>ping: unknown host dac-api-prod.tpv-analytics.com
[dtv_app_mtk]>[36800](2893,2917) dacwebtime: Time could not be retrieved from server
[dtv_app_mtk]>[36814](2893,2917) dacNetwork: Request Server URL https://dac-api-prod.tpv-analytics.com/ ... 1008069313 took 13ms
[dtv_app_mtk]>[36826](2893,2917) dacconfig: Config count not be retrieved from server
[dtv_app_mtk]> I browser_proxy.c[0750] _brpxy_watchdog send BRPXY_NTF_WATCHDOG
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[TPV_CUL]fun:_nav_misc_url_dacClient_available, line:8584, cul_enable_after_dacAPP =1
[dtv_app_mtk]>
[CFG_PWR_MGR][TPV_CUL] a_cfg_custom_get_rtc_wakeup_type_for_cul, ui_rtc_wakeup_type_for_cul=11
[dtv_app_mtk]>
[MISC] ttgctt _nav_misc_url_dacClient_Log_event1 wakeup reason: 6 , ui_rtc_wakeup_reason: 11, semi=0
[dtv_app_mtk]>
[TPV_CUL]linux version=3.18.25
[dtv_app_mtk]>
[TPV_CUL]jasonC_dumpAsString jason string: data={"Version ID of CUL": "0.0.3.2", "Android_version": "0.0.0", "Linux": "3.18.25"}
[dtv_app_mtk]>
[TPV_CUL]SAM_Mode_errors_str = 000 000 000 000 000.
[dtv_app_mtk]>
[NAV_MISC]jasonC_dumpAsString jason string: data={"service_18AC_SSB": "705TXISC43002100SX", "service_18AC_display": "750TBV430V3BH8N000", "service_18AC_PSU": "PLTVHQ281XAA1", "sam_mode_errors": "000 000 000 000 000", "platformIdentifier": "43PUS6503/60", "temp_sensor_details": 0}
[dtv_app_mtk]>
[NAV_MISC]jasonC_dumpAsString jason string: data={"free": "0M", "size": "319M", "filesystem": "/3rd", "iused": 39604, "inode": 39604, "blkSize": 131072, "used": "319M"}
[dtv_app_mtk]>
[NAV_MISC]jasonC_dumpAsString jason string: data={"free": "744M", "size": "885M", "filesystem": "/3rd_rw", "iused": 7752, "inode": 58496, "blkSize": 4096, "used": "140M"}
[dtv_app_mtk]>
[NAV_MISC]jasonC_dumpAsString jason string: data={"free": "0M", "size": "114M", "filesystem": "/basic", "iused": 2005, "inode": 2005, "blkSize": 131072, "used": "114M"}
[dtv_app_mtk]>
[NAV_MISC]length = 53 buffer = 0xe39e2b01 | 19840.565 ms - [JJ] c_svctx_select_svc
[dtv_app_mtk]>
[dtv_app_mtk]>
[NAV_MISC]buf = 19840.565 boottime_str = 19840.565
[dtv_app_mtk]>
[NAV_MISC]power_boottime = 19840
[dtv_app_mtk]>
[NAV_MISC]jasonC_dumpAsString jason string: data={"BootTime": 19840}
[dtv_app_mtk]>
[NAV_MISC]ac_model_code_tuner = 43PUS6503/60 ac_model_code_tuner[4] = S
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event53, line:7965,jasonC_dumpAsString jason string: data={"Tuner_Mode": 3, "No_Of_Tuners": 2, "Tuner_Name": "Unknown"}
[dtv_app_mtk]>
[NAV_MISC]pt_package_name = dtv_svc,pt_package_id = no package id
[dtv_app_mtk]>
[NAV_MISC]open file success, file len =6135.
[dtv_app_mtk]>
[NAV_MISC]mcJSON_GetArraySize: size=10
[dtv_app_mtk]>
[NAV_MISC]applicationName=dtv_svc,applicationId=0,appVersion=0.0.0
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event25, line:3851,jasonC_dumpAsString jason string: data={"package_name": "dtv_svc", "timestamp": 1553772397, "action_type": 1, "package_version": "0.0.0"}
[dtv_app_mtk]>
[TPV_CUL]_nav_misc_url_dacClient_Log_event57 flag_57 = 0 connect_57 = 0.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_Creat_event57, line:7570,jasonC_dumpAsString jason string: data={"connector": 2, "state": 1, "product_type": "OTHER_PERIPHERAL", "given_name": ""}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_Creat_event57, line:7570,jasonC_dumpAsString jason string: data={"connector": 3, "state": 1, "product_type": "OTHER_PERIPHERAL", "given_name": ""}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_Creat_event57, line:7570,jasonC_dumpAsString jason string: data={"connector": 4, "state": 1, "product_type": "USB_MEMORY_DEVICE", "given_name": ""}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_Creat_event57, line:7570,jasonC_dumpAsString jason string: data={"connector": 8, "state": 1, "product_type": "OTHER_PERIPHERAL", "given_name": ""}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_Creat_event57, line:7570,jasonC_dumpAsString jason string: data={"connector": 9, "state": 1, "product_type": "OTHER_PERIPHERAL", "given_name": ""}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_Creat_event57, line:7570,jasonC_dumpAsString jason string: data={"connector": 10, "state": 1, "product_type": "OTHER_PERIPHERAL", "given_name": ""}
[dtv_app_mtk]>
[TPV_CUL]_nav_misc_url_dacClient_Log_event27 channel_id = 11.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event27, line:3915,jasonC_dumpAsString jason string: data={"channel_id": 11, "zap_method": 8}
[dtv_app_mtk]>
[TPV_CUL]ui2_num = 26 i4_ret = 0.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event18, line:4902,jasonC_dumpAsString jason string: data={"delivery_system": 0, "operator": "None", "amt_channels": 26}
[dtv_app_mtk]>
[NAV_MISC]i4_fav_ch_num = 0.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_Creat_event19, line:4985,jasonC_dumpAsString jason string: data={"amt_channels": 0}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_PICTURE_STYLE", "value": "MAIN_VIVID"}
[dtv_app_mtk]>
tmp_value = 75.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_COLOUR", "value": 75}
[dtv_app_mtk]>
tmp_value = 100.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_CONTRAST", "value": 100}
[dtv_app_mtk]>
tmp_value = 7.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_SHARPNESS", "value": 7}
[dtv_app_mtk]>
tmp_value = 50.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_BRIGHTNESS", "value": 50}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_COLOUR_ENHANCEMENT", "value": "MAIN_MAXIMUM"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_COLOUR_TEMPERATURE", "value": "MAIN_COOL"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_CONTRAST_MODE", "value": "MAIN_OPTIMIZED_FOR_PICTURE"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_DYNAMIC_CONTRAST", "value": "MAIN_MEDIUM"}
[dtv_app_mtk]>
tmp_value = 100.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_VIDEO_CONTRAST", "value": 100}
[dtv_app_mtk]>
tmp_value = 0.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_GAMMA", "value": 0}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_ULTRA_RESOLUTION", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_NOISE_REDUCTION", "value": "MAIN_MEDIUM"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_MPEG_ARTIFACT_REDUCTION", "value": "MAIN_MINIMUM"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_MOTION_STYLES", "value": "MAIN_SMOOTH"}
[dtv_app_mtk]>
[TPV_CUL]picture_format_index = 0.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_PICTURE_FORMAT", "value": "MAIN_WIDE_SCREEN"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_SOUND_STYLE", "value": "MAIN_ORIGINAL"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_TV_PLACEMENT", "value": "MAIN_ON_THE_STAND"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_AUTO_VOLUME", "value": "MAIN_OFF"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_AUDIO_OUT", "value": "MAIN_HDMI_SOUND_SYSTEM"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_DIGITAL_OUT_FORMAT", "value": "MAIN_STEREO"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_DIGITAL_OUT_LEVELING", "value": "MAIN_MORE"}
[dtv_app_mtk]>[40831](2893,2917) dacwebtime: Time could not be retrieved from server
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_DIGITAL_OUT_DELAY", "value": "MAIN_OFF"}
[dtv_app_mtk]>[40845](2893,2917) dacconfig: Config count not be retrieved from server
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_NETWORK_CONFIGURATION", "value": "MAIN_DHCP"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_SWITCH_ON_WITH_WIFI", "value": "MAIN_OFF"}
[dtv_app_mtk]>
[TPV_CUL]s_tv_name = 43PUS6503/60.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_TV_NETWORK_NAME", "value": "43PUS6503/60"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_DIGITAL_MEDIA_RENDERER", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_WIFI_ON_OFF", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_CHANNEL_UPDATE_MESSAGE", "value": "MAIN_ON"}
[dtv_app_mtk]>
{SVL} {SVL} get_rec_by_brdcst_type [h_svl:0x101395c][type:1][nw_mask:0x1][idx:0]=-9 failed.
[dtv_app_mtk]>
[dtv_app_mtk]>
[PHM][phm_ch_anlg_get_temp_recs] ERR: file = phm_ch_api.c, line = 5688, ret: -9
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_CHANNEL_ANALOGUE_MANUAL_INSTALLATION_SYSTEM", "value": "MAIN_WEST_EUROPE"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_SATELLITE_CHANNEL_LIST", "value": "MAIN_FROM_A_SORTED_PACKAGE"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_SATELLITE_CHANNEL_UPDATE_MESSAGE", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_TV_GUIDE", "value": "MAIN_FROM_THE_BROADCASTER"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_CHANNEL_LOGOS", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_HBBTV", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_HBBTV_TRACKING", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_HBBTV_COOKIES", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_CAM_OPERATOR_PROFILE", "value": "MAIN_ENABLE"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_ENERGY_SAVING", "value": "MAIN_OFF"}
[dtv_app_mtk]>
tmp_value = 240.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_SWITCH_OFF_TIMER", "value": 240}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_EASYLINK_SWITCH", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_EASYLINK_REMOTE_CONTROL", "value": "MAIN_ON"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_LOCATION", "value": "MAIN_HOME"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_HDMI_UHD_2", "value": "MAIN_STANDARD"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_HDMI_UHD_3", "value": "MAIN_STANDARD"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_UNIVERSAL_ACCESS_SWITCH", "value": "MAIN_OFF"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_PARENTAL_RATING", "value": "MAIN_NONE"}
[dtv_app_mtk]>
[TPV_CUL]s639_lang = rus.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_MENU_LANGUAGE", "value": "rus"}
[dtv_app_mtk]>
[TPV_CUL]s639_lang_primary = rus.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_PRIMARY_AUDIO", "value": "rus"}
[dtv_app_mtk]>
[TPV_CUL]s639_lang_secondary = eng.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_SECONDARY_AUDIO", "value": "eng"}
[dtv_app_mtk]>
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_PRIMARY_SUBTITLE", "value": "rus"}
[dtv_app_mtk]>
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_SECONDARY_SUBTITLE", "value": "eng"}
[dtv_app_mtk]>
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_PRIMARY_TEXT", "value": "rus"}
[dtv_app_mtk]>
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_SECONDARY_TEXT", "value": "eng"}
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_AUTO_CLOCK_MODE", "value": "MAIN_AUTOMATIC"}
[dtv_app_mtk]>
[TPV_CUL]s3166_country = RUS.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_string, line:5030,jasonC_dumpAsString jason string: data={"setting": "MAIN_TIME_ZONE", "value": "MAIN_CONTINENTAL_SPAIN_AND_BALEARIC_ISLANDS"}
[dtv_app_mtk]>
tmp_value = 0.
[dtv_app_mtk]>
[TPV_CUL]fun:_nav_misc_url_dacClient_Log_event20_int, line:5075,jasonC_dumpAsString jason string: data={"setting": "MAIN_SLEEP_TIMER", "value": 0}
[dtv_app_mtk]>
[40818](2893,2917) dacNetwork: Request Server URL https://dac-api-prod.tpv-analytics.com/prod/v1/time/ took 1ms
[dtv_app_mtk]>[40833](2893,2917) dacNetwork: Request Server URL https://dac-api-prod.tpv-analytics.com/ ... 1008069313 took 1ms
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[46625](2893,2917) dacNetwork: Request Server URL https://dac-api-prod.tpv-analytics.com/prod/v1/time/ took 1ms
[dtv_app_mtk]>[46638](2893,2917) dacwebtime: Time could not be retrieved from server
[dtv_app_mtk]>[46640](2893,2917) dacNetwork: Request Server URL https://dac-api-prod.tpv-analytics.com/ ... 1008069313 took 1ms
[dtv_app_mtk]>[46652](2893,2917) dacconfig: Config count not be retrieved from server
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Default][L160]watchdogTimerHandler : i4AllocatedSz:38962096, g_memoryLeak_detect_counter:5, eHbbtvAPPStatus:0
[browser_base]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Default][L160]watchdogTimerHandler : i4AllocatedSz:38966192, g_memoryLeak_detect_counter:5, eHbbtvAPPStatus:0
[browser_base]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>[NAV_POWER_OUX_VIEW] _nav_pwr_check_smarttv_utube_netflix_msg_hdlr()
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Default][L160]watchdogTimerHandler : i4AllocatedSz:38974384, g_memoryLeak_detect_counter:5, eHbbtvAPPStatus:0
[browser_base]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Default][L160]watchdogTimerHandler : i4AllocatedSz:38837288, g_memoryLeak_detect_counter:5, eHbbtvAPPStatus:0
[browser_base]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[browser_base]>[bws_app][Default][L160]watchdogTimerHandler : i4AllocatedSz:38849576, g_memoryLeak_detect_counter:5, eHbbtvAPPStatus:0
[browser_base]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
[dtv_app_mtk]>
And Justice for All
 Заголовок сообщения: Re: Philips 50PVS6262/60 (TPM17.7E LA) что то не так с ОЗУ?
СообщениеДобавлено: 17 май 2020, 18:59
Всё верно. В сервис мануале у другого телика на таком же проце написано что 256мб памяти реализована на самом проце.
СообщениеДобавлено: 18 май 2020, 18:05
Какой то лог у него слишком длинный для неработающего тв
СообщениеДобавлено: 18 май 2020, 19:01
raiser
Спасибо. Тогда понятно, откуда берется 3й канал.
And Justice for All
 Заголовок сообщения: КТП КОМПЛЕКТНЫЕ ТРАНСФОРМАТОРНЫЕ ПОДСТАНЦИИ
СообщениеДобавлено: 16 июл 2021, 18:31
sviloguzov ru/ktpn-100 ктп 2х1000 ква,купить ктп 160 ква
СообщениеДобавлено: 18 июл 2021, 12:53
Подсветка есть? Да, лог довольно длинный, заставка появляется? Кстати, многие филипсы с чужим дампом без переноса ключей не запускаются. С родным дампом такой же лог?
---------- Добавлено спустя 4 минуты 35 секунд: ----------
Ещё совет, после окончания лога если нет цикличного перезапуска, нажать кнопку повер на самом тв, у филипсов прикол, что если выключен с кнопки повер на тв, то уже с пульта не включить, хотя не помню какой лог тогда, но тоже есть предзагрузка
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Philips Philips 43PFT4001-60 нет звука
в форуме LCD
4taket
14 дек 2022, 19:56
Artmax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Philips 202E (202E2) Шасси: 715G3737-M02-000-00 (Нужна прошивка)
в форуме Philips
JonBlack
22220
23 фев 2019, 11:38
JonBlack Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Шлейф awm 20861 e129545 от тв Philips.
в форуме Куплю | Buy
pro100susanin
14 авг 2019, 19:40
BlackDoc Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Philips Brilliance 190S ( Нужна прошивка !!!)
в форуме Philips
calpacioc
15 дек 2014, 16:03
calpacioc Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Philips 32", нет подсветки
в форуме LCD
megamatvey
22
9262
18 июн 2015, 09:29
megamatvey Перейти к последнему сообщению
Сейчас этот форум просматривают: belkin-dv, vic77 и гости: 17
