vova_w810i
Заголовок сообщения: Re: Dahua DH-IPC-HFW1200SP не грузится ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 01 фев 2020, 13:23 |
![Аватара пользователя](./images/avatars/gallery/DP3/avatar1779-1.jpg) |
Зарегистрирован: 16 окт 2016, 15:57 Наличности на руках: 2,138.09 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 2464 Откуда: Украина, Киев
Вот полный лог, после команд: setenv dh_keyboard 0 saveenv reset
setenv dh_keyboard 0 DHBOOT# saveenv Saving Environment to SPI Flash... SPI Erasing:100% SPI Writing:100% done DHBOOT# reset Checking DDR......OK
UBL Version: 1.43t(DM368 12/25/2012) Oscillator: 24MHZ ARM Rate: 432 MHZ DDR Rate: 340 MHZ start watchdog BootMode: SPI Starting SPI Memory Copy... DONE
U-Boot 1.3.6 (jerry) (Oct 13 2014 - 11:56:55)
DRAM: 128 MB SF: Got idcode ef 40 17 SF: Detected W25Q64 with page size 256, total 8 MB In: serial Out: serial Err: serial Ethernet PHY: GENERIC @ 0x03,id:221513 total gio 2 gio[22]=1 gio[25]=1 Loading... TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'upgrade_info_7db780a713a4.txt'. Load address: 0x80100000 Loading: *WARN: emac_send_packet: No link
Retry count exceeded; starting again Fail to get info file! Init error! TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'failed.txt'. Load address: 0x80200000 Loading: *WARN: emac_send_packet: No link
Retry count exceeded; starting again ==>use default images ## Booting kernel from Legacy Image at 80800000 ... Image Name: boot Image Type: ARM Linux Kernel Image (lzma compressed) Data Size: 1041387 Bytes = 1017 kB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
Starting kernel ...
init started: BusyBox v1.9.1 (2014-05-22 15:49:36 CST)
starting pid 129, tty '': '/etc/init.d/dnode' mount: mounting devpts on /dev/pts failed: No such file or directory mount: mounting none on /proc/bus/usb failed: No such file or directory
starting pid 148, tty '': '/etc/init.d/rcS' Fri Jan 7 10:35:25 2000 0.000000 seconds <6>MAC address is 4C:11:BF:8B:6C:7B TI DaVinci EMAC Linux version updated 4.0
32;32m[libdvr] libdvr.so Build on May 22 2014 at 14:23:12. del ip failed:No such device or address
35] bd6735.ko Build on Oct 13 2014 at 11:47:41.
[libdvr] Real fchip type is 21
2m[libdvr] Real fchip type is 21
;32m[libdvr] ...dataBuf[0] 26, dataBuf[1] 4
r] ...dataBuf[dm365_ad] dm365_ad init:dm365_ad!
[0;32;32m[sensor] SVN NUM: 4411. 1 ioremap_nocache(0x85000000, 50331648)=0xc6000000 bi = 0, heap_size = 50331648 allocated heap buffer 0xc6000000 of size 0x3000000 cmem initialized 0 pools between 0x85000000 and 0x88000000 CMEM Range Overlaps Kernel Physical - allowing overlap CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x84e00000) ioremap_nocache(0x1000, 28672)=0xc5248000 ##: total_num_buffers = 1 no remaining memory for heap, no heap created for memory block 1 cmem initialized 1 pools between 0x1000 and 0x8000 IRQK module: built on Feb 29 2012 at 17:05:47 Reference Linux version 2.6.18 File /home/hu_jianguang/irq/Trunk/src/module/irqk.c irqk initialized EDMAK module: built on Feb 29 2012 at 17:01:49 Reference Linux version 2.6.18 File /home/hu_jianguang/edma/Trunk/src/module/edmak.c getjif init @ 091230 ##: HZ = 10 register getjif driver successful ! enable
] VideoBuf Create queuefor dm365_af OK ! Archive: /mnt/data/pd/product.zip creating: product/ inflating: product/ProductTransform creating: product/IPC-HD2100C-V2/ inflating: product/IPC-HD2100C-V2/ProductDefinition inflating: product/IPC-HD2100C-V2/CustomConfig inflating: product/IPC-HD2100C-V2/DefaultAccount creating: product/IPC-HD2200C-V2/ inflating: product/IPC-HD2200C-V2/ProductDefinition inflating: product/IPC-HD2200C-V2/CustomConfig inflating: product/IPC-HD2200C-V2/DefaultAccount Archive: /mnt/data/data/2Acfg.zip creating: 2Acfg/ creating: 2Acfg/IPC-HD2200C-V2/ inflating: 2Acfg/IPC-HD2200C-V2/aew_para.bin creating: 2Acfg/IPC-HFW2100B-V2/ inflating: 2Acfg/IPC-HFW2100B-V2/aew_para.bin
starting pid 301, tty '/dev/ttyS0': '/etc/init.d/appd'
mget armboot para icrtest failed 1 0 5:42|[libInfra] warn Some [Manager] files are not commit to SVN server. It compied wtih local modified files. c] build optio[edma_ioctl] EDMA_INIT ns:ipc2.2 SUP_MJedma_init:ch:0,tcc:0 EG RV_End of getstd function. vpssDisable: Wai[vid_decoderoder]:set format params. t for H3A DRV_vEnd of vid_decoder set standard... pssDisable: CLOCEnd of set input function. K DISALBE ION: 0 Bufs 0 [0;32;32m[capture] VSERVER : Id 1, Stream bufSize 0x94800 code] maxVideoCnt = 2, maxKTNFCnt = 0, maxRotationCnt = 0,maxDeiCnt = 0, maxMemSize = 10240, KTNFEnableMask = 0 ,RotationEnableMask = 0, DeiEnableMask = 0,vicpGroupId = 1, dspType = 1, prodctId = 40 0 0 0 0 ncode] check thread 323 0 0 1000 0 0 pFrames=0,pAewCreate->fdPrev=11 ure_time=40.000000,exp_time_step=39.450001,frame rate=25.000000 ft=7,sat_limit=1023 [m2;32m[VPFE] Exit VPFE_CMD_STREAM_PAUSE pssDisable: CLOCK ENABLE 5695.
] aew_start window = (1920, 1080, 0, 2),frame =25.000000 EW] SmartIR Trigger is 1, SmartIR Duration_Clip is 96, SmartIR Period_Max is 480 EW Win Inc H = 2 35:45|[libInfra] info [*] Manager 1.1.0.191847 Built in 2014/10/13 [*] ] 33m[libdvr] WARN (../../src/misc/sys.c|getSystemInfo|430): get authcode error ! trace CFileLog::append detail = { "Flag" : 2 } , type = StartUp, device = (null) ypeTransform = { "General" : { "Default" : "IP Camera", "IPC-HD2100C-V2" : "IP Camera", "IPC-HD2105C-V2" : "IP Camera", "IPC-HD2150C-V2" : "IP Camera", "IPC-HD2155C-V2" : "IP Camera", "IPC-HD2200C-V2" : "IP Camera", "IPC-HD2205C-V2" : "IP Camera", "IPC-HD2250C-V2" : "IP Camera", "IPC-HD2255C-V2" : "IP Camera", "IPC-HDBW2100E-V2" : "IP Camera", "IPC-HDBW2105E-V2" : "IP Camera", "IPC-HDBW2150E-V2" : "IP Camera", "IPC-HDBW2155E-V2" : "IP Camera", "IPC-HDBW2200E-V2" : "IP Camera", "IPC-HDBW2205E-V2" : "IP Camera", "IPC-HDBW2250E-V2" : "IP Camera", "IPC-HDBW2255E-V2" : "IP Camera", "IPC-HDW2100C-V2" : "IP Camera", "IPC-HDW2100S-M-V2" : "IP Camera", "IPC-HDW2100S-V2" : "IP Camera", "IPC-HDW2105C-V2" : "IP Camera", "IPC-HDW2105S-M-V2" : "IP Camera", "IPC-HDW2105S-V2" : "IP Camera", "IPC-HDW2150C-V2" : "IP Camera", "IPC-HDW2150S-M-V2" : "IP Camera", "IPC-HDW2150S-V2" : "IP Camera", "IPC-HDW2155C-V2" : "IP Camera", "IPC-HDW2155S-M-V2" : "IP Camera", "IPC-HDW2155S-V2" : "IP Camera", "IPC-HDW2200C-V2" : "IP Camera", "IPC-HDW2200S-M-V2" : "IP Camera", "IPC-HDW2200S-V2" : "IP Camera", "IPC-HDW2205C-V2" : "IP Camera", "IPC-HDW2205S-M-V2" : "IP Camera", "IPC-HDW2205S-V2" : "IP Camera", "IPC-HDW2250C-V2" : "IP Camera", "IPC-HDW2250S-M-V2" : "IP Camera", "IPC-HDW2250S-V2" : "IP Camera", "IPC-HDW2255C-V2" : "IP Camera", "IPC-HDW2255S-M-V2" : "IP Camera", "IPC-HDW2255S-V2" : "IP Camera", "IPC-HDW3100S-V2" : "IP Camera", "IPC-HDW3105S-V2" : "IP Camera", "IPC-HFW2100-B-V2" : "IP Camera", "IPC-HFW2100B-V2" : "IP Camera", "IPC-HFW2100D-V2" : "IP Camera", "IPC-HFW2100S-V2" : "IP Camera", "IPC-HFW2105-B-V2" : "IP Camera", "IPC-HFW2105B-V2" : "IP Camera", "IPC-HFW2105D-V2" : "IP Camera", "IPC-HFW2105S-V2" : "IP Camera", "IPC-HFW2150B-V2" : "IP Camera", "IPC-HFW2150D-V2" : "IP Camera", "IPC-HFW2150S-V2" : "IP Camera", "IPC-HFW2155B-V2" : "IP Camera", "IPC-HFW2155D-V2" : "IP Camera", "IPC-HFW2155S-V2" : "IP Camera", "IPC-HFW2200B-V2" : "IP Camera", "IPC-HFW2200D-V2" : "IP Camera", "IPC-HFW2200S-V2" : "IP Camera", "IPC-HFW2205B-V2" : "IP Camera", "IPC-HFW2205D-V2" : "IP Camera", "IPC-HFW2205S-V2" : "IP Camera", "IPC-HFW2250B-V2" : "IP Camera", "IPC-HFW2250D-V2" : "IP Camera", "IPC-HFW2250S-V2" : "IP Camera", "IPC-HFW2255B-V2" : "IP Camera", "IPC-HFW2255D-V2" : "IP Camera", "IPC-HFW2255S-V2" : "IP Camera", "IPC-HFW3100-V2" : "IP Camera", "IPC-HFW3100D-V2" : "IP Camera", "IPC-HFW3105-V2" : "IP Camera", "IPC-HFW3105D-V2" : "IP Camera" } }
lue! r is Json::nullValue! earchIP/DeviceDiscover.cpp,36 lse, "MountDir" : "\/mnt", "Summary" : "File" }
l } ], "FileHoldTime" : 0, "Memo" : "For FTP Files", "Name" : "FTP", "OverWrite" : true, "PicturePathRule" : "%y-%M-%d\/%c\/jpg\/%h\/%m\/%s[%E][%O@%S][%R].jpg", "RecordPathRule" : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav" } ]
info VideoInput Caps : m_caps.maxWidth[1920] m_caps.maxHeight[1080] m_caps.ladenBitrate[972000] m_caps.horizontalBinning[1] m_caps.verticalBinning[1] m_caps.downScaling[1] m_caps.upScaling[0] m_caps.exposure[16] m_caps.backlight[2] m_caps.dayNightColor[1] m_caps.mirror[1] m_caps.flip[1] m_caps.whiteBalance[3] m_caps.gain[1] m_caps.gainAuto[1] m_caps.coverCount[0] m_caps.coverType[0] m_caps.titleCount[0] m_caps.iris[1] m_caps.irisAuto[0] m_caps.infraRed[0] m_caps.setcolor[1] m_caps.formatCout[1] m_caps.rotate90[0] m_caps.signalForamtMask[0] m_caps.syncChipChannels[0] m_caps.chipID[0] m_caps.multiOptions[1] m_caps.snapshotExposure[1] m_caps.limitedAutoExposure[1] m_caps.customManualExposure[1] m_caps.externalSyncInput[1] m_caps.refrenceLevel[1] m_caps.flashAdjust[1] m_caps.minExposureTime[0] m_caps.maxExposureTime[300] m_caps.wideDynamicRange[3] m_caps.glareInhibition[1] m_caps.doubleExposure[1] m_caps.utc[0] m_caps.version[0] m_caps.meteringRegionCount[5] m_caps.exposureMode[31] m_caps.afPeak[0] m_caps.gammaModeRange[0] m_caps.gammaMode[0] dard Nr ibenc] remap osd done,index=0, virtaddr_sonia=0x48002000 [libenc] remap osd done,index=1, virtaddr_sonia=0x48016000 [libenc] remap osd done,index=2, virtaddr_sonia=0x4802a000 [libenc] remap osd done,index=3, virtaddr_sonia=0x4803e000 [libenc] remap osd done,index=4, virtaddr_sonia=0x48052000 [libenc] remap osd done,index=0, virtaddr_sonia=0x48066000 [libenc] remap osd done,index=1, virtaddr_sonia=0x4807a000 [libenc] remap osd done,index=2, virtaddr_sonia=0x4808e000 [libenc] remap osd done,index=3, virtaddr_sonia=0x480a2000 [libenc] remap osd done,index=4, virtaddr_sonia=0x480b6000 [libenc] remap osd done,index=0, virtaddr_sonia=0x480ca000 [libenc] remap osd done,index=1, virtaddr_sonia=0x480de000 [libenc] remap osd done,index=2, virtaddr_sonia=0x480f2000 [libenc] remap osd done,index=3, virtaddr_sonia=0x48106000 [libenc] remap osd done,index=4, virtaddr_sonia=0x4811a000 [libenc] remap osd done,index=0, virtaddr_sonia=0x4812e000 [libenc] remap osd done,index=1, virtaddr_sonia=0x48142000 [libenc] remap osd done,index=2, virtaddr_sonia=0x48156000 [libenc] remap osd done,index=3, virtaddr_sonia=0x4816a000 [libenc] remap osd done,index=4, virtaddr_sonia=0x4817e000 nkins/jk_slave_centos6/workspace/IPC_DH3.S0506_36XV2.420/tmp_build_dir/libaudio_DM365/src/audioenc/audioenc.c, LINE -> 384 : desc->srcs=0x1,stream=0,out of range ize = [1920, 1080], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 4096 kbps, quality = 4,pack = 0, type = 3, h264profile = 3
[0;32;32m[libenc] set [1] format:width=352,height=288,bitrate=512,fps=25,gop=50,qualityType=0,quality=4,size=0,type=3 ode is: 0, rotate state is: 0 ight=288,bitrate=512,fps=25.000000,gop=50,quality=4,type=3 otal(16777216) pagesize(1024)blockCount (16384) ManagermentSize(327980) ced auto exposure 0,0 profileMode is: 2, rotate state is: 0 51|info Src/Media/DevVideoEnc.cpp:816 format is same, do nothing. edia/DevVideoEnc.cpp:816 format is same, do nothing. VideoEnc.cpp:816 format is same, do nothing. pture] [spi_setpara]=>: r_custom : 0 ## Webset change shutter:sht_min=0.000000,sht_max=40.000000
trl------ light_freq=0, exp_mode=0,ae_mode=0,gain_min=1,gain_max=818,sht_min=2,sht_max=1578
000
0:35:51|trace CDevVideoEnc::setWorkFormat m_videoTitle[1] ssensor] ar0330 set gain = [138] deoEnc::setWorkFormat m_videoTitle[0] setWorkFormat: 352, 288,stream:1 eoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:4 fo CDevVideoEnc::setWaterMark:m_encoder->setWaterMark eterMode VideoIn setMeteringMode no exist!!! 0x4aa0dca4 ++++++++++++++++++++++ orage 1.0.1.208150 Built in 2014/10/13 [*] bStorage] trace CNfsClient::onNetCheck()==================== re", "Enable" : false, "Name" : "SMB1", "Password" : "", "Port" : 445, "Protocol" : "SMB", "UserName" : "" } oint is 0,nf_ee_mode is 1 4, stack = 0x4ba0fca4 947241352 do_init: initialized context 0xfe3f00 92 prior = N64, stack = 0x4ca11ca4 et gain = [644] 2;32m[sensor] ar0330 set gain = [263] arn preSecond too large: 7, set to 5 o 5 37;40m10:35:52|trace mode:1, mask:2 ort" : { "InnerPort" : 80, "OuterPort" : 8080 }, "HttpsPort" : { "InnerPort" : 443 }, "NAS_Protocol_Mask" : 100, "TCPPort" : 37777, "WebVersion" : "3.2.1.224637", "deviceType" : "IPC-HFW1200S", "eth0" : { "is_show_OSDinfo" : 1, "is_show_Syslog" : 0, "is_show_T2UServer" : 0, "is_show_VPN_Certificate" : 0, "is_show_azimuthDisp" : 0, "is_show_duck" : 1, "is_show_help" : 0, "is_show_mousecontrolptz" : 0, "is_show_startDeviceDiscover" : 0, "is_show_upnpMode" : 1, "is_show_whiteBalanceOutdoor" : 1, "mac_plugins_version" : 3, "show_ATM_config" : 0, "show_Device_type" : 0, "show_NAS_config" : 1, "show_SNMP_config" : 1, "show_auto_register" : 1, "show_bonjour_config" : 1, "show_comm_config" : 0, "special_GOP_728WP" : 1, "use_mac_plugins" : 1, "vendor" : "General", "videodetect_default_sensitive" : 58, "videodetect_default_threshold" : 4, "win_plugins_version" : 3 }
10:35:52|debug tracepoint: Src/DVRIP/AutoSearchIP.cpp, 253. OnvifEventProducer::AttachConfigChange attach success t" : 20008, "StreamType" : "Extra1" } ] }
r.cpp 470 live channel:cam/realmonitor?channel=1&subtype=0 start init amSource/EncodeStreamSource.cpp 109 EncodeStreamSource Init!this:0x1018910 m[encode] disable streamid[0] encode nel: 0,stream: 0 th: 1920, height: 1080 m_stream:0 :m_cfgMotionEnable[channel:0]: 1
odaemon_framerate streamid=1, fps=25 _dir/libaudio_DM365/src/audioenc/audioenc.c, LINE -> 384 : desc->srcs=0x1,stream=4,out of range ome/jenkins/jk_slave_centos6/workspace/IPC_DH3.S0506_36XV2.420/tmp_build_dir/libaudio_DM365/src/audioenc/audioenc.c, LINE -> 209 : srcs=0x2,out of range,audioInCnt=0 o CDH3DevVideoEnc::start force_iframe|326): stream type :4;unsupported!!! [m= 0 stream=0 tate90 Caps failed. his:0x10345f0 ncodedaemon SET_ENCODE_IFRAME is done [32;40m10:35:54|info Src/StreamSource/EncodeStreamSource.cpp 109 EncodeStreamSource Init!this:0x10385a8 ched, encoder will be stoped!!!!!!! : streamid=1,last_seq=1,cur_seq=3 channel_id:0, stream_id:2 cpp:401 <channel:1 subtype:4> [audio_enable 0][Audio_In_getCollet 0][video_enable 1] id=4, enable=1 ind this channel.channel=0, stream=0, multi-type=2 find this channel.channel=0, stream=1, multi-type=2 V4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.4", "Port" : 40008, "StreamType" : "Extra1", "TTL" : 64 }
40m10:35:55|[libInfra] info Threads: Console 333 1 Normal 329 64 Normal info ____________________________________________________________________________ Idle ;32m[encode] enable streamid[4] encode MemoryUsage 42949458460 0 60000 0/ 60000 Idle 0/ 60000 Idle nfo Src/RtspServer/RtspLiveServer.cpp 249 live channel:cam/realmonitor?channel=1&subtype=0&encrypt=1 end init ore play==== 0:35:56|[libInfra] debug ThreadBody Enter name = [NetAppCheckNetState], id = 369, prior = N64, stack = 0x564cbca4 40m10:35:56|warn m_run to false, m_stream: 1 c::stop
: [ "Region1" ] } , type = EventStart, device = (null) :35:59|trace CDevVideoEnc::setWorkFormat m_videoTitle[0] setWorkFormat: 1920, 1080,stream:0 , curQP=19, rcQMaxI=30 0:36:03|warn Src/Media/DevVideoEnc.cpp:780, inFormat is the same, do nothing 3|warn CEncode::supportRotate Rotate90 Caps failed. kbps, quality = 4,pack = 0, type = 3, h264profile = 3 3182 ok! val is 0x7ffc QP=17, willSetQP=25, maxQP=33, rcAlgo=5, rcQMinI=17, curQP=25, rcQMaxI=33 10:36:34|trace CFileLog::append detail = { "Code" : "VideoMotion", "Index" : 1 } , type = EventStop, device = (null) eoEnc::setWorkFormat m_videoTitle[0] setWorkFormat: 1920, 1080,stream:0 "Code" : "VideoMotion", "Index" : 1, "RegionName" : [ "Region1" ] } , type = EventStart, device = (null) etWorkFormat m_videoTitle[0] setWorkFormat: 1920, 1080,stream:0 ;32m[sensor] ar0330 set gain = [354] ] set ee_table[1] nsor] ar0330 set gain = [408] 0330 set gain = [452] sor] ar0330 2A set gain = [364]
2A set gain = [407] to LINE nf_ee switch,begin point is 0,nf_ee_mode is 1 5] A set gain = [423] ain = [395] 0m10:36:44|trace ----libMedia-------CDevVideoEnc::setWorkFormat: width: 1920, height: 1080 m_stream:0 Arena 0: system bytes = 6058756 in use bytes = 5336596 Arena 1: system bytes = 135168 in use bytes = 24600 Total (incl. mmap): system bytes = 27357956 in use bytes = 26525228 max mmap regions = 13 max mmap bytes = 21164032
![](images/spacer.gif) |
vova_w810i
Заголовок сообщения: Re: Dahua DH-IPC-HFW1200SP не грузится ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 01 фев 2020, 22:34 |
Вот лог команд printenv и help:
System startup
System startup
U-Boot 2010.06-svn4554 (Jun 19 2017 - 21:29:06) DRAM: 64 MiB gBootLogPtr:80b80008. Check Flash Memory Controller v100 ... Found SPI Nor(cs 0) ID: 0xc8 0x40 0x18 Block:64KB Chip:16MB Name:"GD25Q128" SPI Nor total size: 16MB hifmc100_get_erasesize:10000. partition file version 2 rootfstype squashfs root /dev/mtdblock6 fail to load bootargsParametersV22.txt fail to load bootargsParametersV21.txt fail to init bootargsParametersV2 In: serial Out: serial Err: serial TEXT_BASE:81000000 MMC: Hit any key to stop autoboot: 0 > printenv bootcmd=kload 0x82000000; bootm 0x82000000 bootdelay=1 baudrate=115200 ipaddr=192.168.1.108 serverip=192.168.1.1 gatewayip=192.168.1.1 netmask=255.255.255.0 bootfile="uImage" wifiaddr=00:12:34:56:78:91 da=tftp 0x82000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite dr=tftp 0x82000000 romfs-x.squashfs.img; flwrite dk=tftp 0x82000000 kernel.img; flwrite du=tftp 0x82000000 user-x.squashfs.img; flwrite dw=tftp 0x82000000 web-x.squashfs.img; flwrite dp=tftp 0x82000000 partition-x.cramfs.img;flwrite dc=tftp 0x82000000 custom-x.squashfs.img; flwrite up=tftp 0x82000000 update.img; flwrite tk=tftp 0x82000000 uImage; bootm loglevel=4 pd=tftp 0x82000000 pd-x.squashfs.img; flwrite BSN=3F0573DPAX00998 HWID=IPC-HFW2220M:01:02:02:4F:1E:00:01:00:00:00:00:258:00:00:00:00:00:01:00:00:100 devalias=IPC-HDW1220S ID=3H00BD5PAA00036 ethaddr=E0:50:8B:FA:D3:76 filesize=23D040 fileaddr=82000000 appauto=1 bootargs=mem=128M console=ttyS0,115200 root=/dev/mtdblock6 rootfstype=squashfs dh_keyboard=0 stdin=serial stdout=serial stderr=serial verify=n ver=U-Boot 2010.06-svn4554 (Jun 19 2017 - 21:29:06)
Environment size: 1103/262140 bytes > help ? - alias for 'help' base - print or set address offset boot - boot default, i.e., run 'bootcmd' bootd - boot default, i.e., run 'bootcmd' bootf - boot from flash bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol cfgRestore- erase config n for some time sync_uboot- sync_uboot - sync uboot to uboot-bak
test - minimal test like /bin/sh tftpboot- tftpboot- boot image via network using TFTP protocol true - do nothing, successfully usleep - delay execution for some time version - print monitor version > do nothing, successfully usleep - delay execution for some time version - print monitor version > sh tftpboot- tftpboot- boot image via network using TFTP protocol true - do nothing, unsuccessfully fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatls - list files in a directory (default /) flwrite - flwrite - write data into FLASH memory
fsinfo - print information about filesystems fsload - load binary file from a filesystem image go - start application at address 'addr' help - print command description/usage hwid - hwid - set hardware id and save to flash
kload - kload - load uImage file from parttion
lip - lip - set local ip address but not save to flash
loadb - load binary file over serial line (kermit mode) loady - load binary file over serial line (ymodem mode) logsend - get log buf loop - infinite loop on address range ls - list files in a directory (default /) mac - mac - set mac address and save to flash
md - memory display memsize - memsize - set mem size
mii - MII utility commands mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - mmcinfo <dev num>-- display MMC info mtest - simple RAM read/write test mw - memory write (fill) nm - memory modify (constant address) partition- print partition information ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables rarpboot- boot image via network using RARP/TFTP protocol rdefault- rdefault -recover default env
reset - Perform RESET of the CPU run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sf - SPI flash sub-system showvar - print local hushshell variables sip - sip - set server ip address but not save to flash
vova_w810i
Заголовок сообщения: Re: Dahua DH-IPC-HFW1200SP не грузится ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 02 фев 2020, 16:58 |
Прошил камеру вашей сборкой, не грузится, ошибка: ERROR: can't get kernel image! На всякой сохранил родной дамп, выложу здесь.
UBL Version: 1.43t(DM368 12/25/2012) Oscillator: 24MHZ ARM Rate: 216 MHZ DDR Rate: 173 MHZ start watchdog BootMode: SPI Starting SPI Memory Copy... DONE
DRAM: 128 MB SF: Got idcode ef 40 17 SF: Detected W25Q64 with page size 256, total 8 MB In: serial Out: serial Err: serial Ethernet PHY: GENERIC @ 0x03,id:221513 total gio 2 gio[22]=1 gio[25]=1 Fail: can't get cramfs super block. TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'upgrade_info_7db780a713a4.txt'. Load address: 0x80100000 Loading: WARN: emac_send_packet: No link
Retry count exceeded; starting again Fail to get info file! Init error! TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1 Filename 'failed.txt'. Load address: 0x80200000 Loading: WARN: emac_send_packet: No link
Retry count exceeded; starting again ==>use default images Wrong Image Format for bootm command ERROR: can't get kernel image! DHBOOT#
---------- Добавлено спустя 3 часа 21 минуту 32 секунды: ---------- Может попробовать залить прошивку через TFTP-сервер?
vova_w810i
Заголовок сообщения: Re: Dahua DH-IPC-HFW1200SP не грузится ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 05 фев 2020, 23:39 |
Вот лог:
Terminal log file Date: 05.02.2020 - 20:46:10 ----------------------------------------------- Checking DDR......OK
DRAM: 128 MB SF: Got idcode ef 40 17 SF: Detected W25Q64 with page size 256, total 8 MB In: serial Out: serial Err: serial Ethernet PHY: GENERIC @ 0x03,id:221513 total gio 2 gio[22]=1 gio[25]=1 Loading...DHBOOT# printenv bootdelay=3 baudrate=115200 wifiaddr=00:01:5b:00:77:88 ipaddr=10.12.10.28 serverip=10.12.9.27 bootfile="uImage" appauto=1 single=0 dc=tftp 81a00000 custom-x.cramfs.img; flwrite dr=tftp 81a00000 romfs-x.cramfs.img; flwrite du=tftp 81a00000 user-x.cramfs.img; flwrite dd=tftp 81a00000 data-x.cramfs.img; flwrite dw=tftp 81a00000 web-x.cramfs.img; flwrite up=tftp 81a00000 update.img; flwrite tk=tftp 80800000 uImage; bootm 80800000 gionum=22.25 gioval=1.1 dh_com=0 autosip=192.168.254.254 autolip=192.168.1.108 autogw=192.168.1.1 autonm=255.255.255.0 HWID=IPC-HFW2200B-V2:01:02:02:03:05:00:01:00:00:00:00:1B0:00:00:02:00:00:00:00:00:80 devalias=IPC-HFW1200S bootcmd=fsload 0x80800000 0x00060000;bootm 0x80800000 bootargs=console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=squashfs ,nolock mem=78M video=davincifb:vid0=OFF:vid1=OFF:osd0=OFF:osd1=OFF da=protect off all;tftp 81a00000 dm365_ubl_boot_8M_spiflash.bin.img;flwrite filesize=200 fileaddr=87000000 ID=TZC4LU190W00838 ethaddr=4C:11:BF:8B:6C:7B dh_keyboard=0 stdin=serial stdout=serial stderr=serial ver=U-Boot 1.3.6 (jerry) (Oct 13 2014 - 11:56:55)
Environment size: 1107/16380 bytes DHBOOT# reset Checking DDR......OK
Starting kernel ...
starting pid 148, tty '': '/etc/init.d/rcS' <6>MAC address is 4C:11:BF:8B:6C:7B TI DaVinci EMAC Linux version updated 4.0
r help eth0: MAC: <4c:11:bf:8b:6c:7b> IP: <192.168.10.210> netmask: <255.255.255.0> Gateway: <192.168.88.1> [libdvr] Gateway and ip are in different subnet
[bd6735] ....turn into find ZERO.....
May 22 2014 at 14:23:12. 5830. [dm365_ad] dm365_ad init:dm365_ad! C142_GB3A: Init PRTCSS Device
<6>CMEMK module: built on Feb 29 2012 at 17:52:18 Reference Linux version 2.6.18 File /home/hu_jianguang/cmenk/Trunk/src/module/cmemk.c ====: 0, 1 ioremap_nocache(0x85000000, 50331648)=0xc6000000 bi = 0, heap_size = 50331648 allocated heap buffer 0xc6000000 of size 0x3000000 cmem initialized 0 pools between 0x85000000 and 0x88000000 CMEM Range Overlaps Kernel Physical - allowing overlap CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x84e00000) ioremap_nocache(0x1000, 28672)=0xc5248000 ##: total_num_buffers = 1 no remaining memory for heap, no heap created for memory block 1 cmem initialized 1 pools between 0x1000 and 0x8000 IRQK module: built on Feb 29 2012 at 17:05:47 Reference Linux version 2.6.18 File /home/hu_jianguang/irq/Trunk/src/module/irqk.c irqk initialized EDMAK module: built on Feb 29 2012 at 17:01:49 Reference Linux version 2.6.18 File /home/hu_jianguang/edma/Trunk/src/module/edmak.c getjif init @ 091230 ##: HZ = 10 register getjif driver successful !
davinci display video device.
armboot para icrtest failed 1 0 CLOCK DISALBE nction. Id = 21
ture] VSERVER : Id 0, stream height 1080 m013 build at Oct 13 2014 :11:01:24 encode] Jpeg streamid:maxWidth =1920 maxHeigh =1080 maxsize=524288 VIDENC1_create is Done,streamid=1 ! msensor) Period_Max is 480 Inc V = 2 tate:0----
isable: CLOCK DISALBE DRV_vpssDisable: CLOCK ENABLE [0;32;32m[AEW] SVN NUM: 15695.
w_start window = (1920, 1080, 0, 2),frame =25.000000 269353662, id:131076 = 16 32m[AEW] ----icrInfo.icrBootState:0----
0_8M @ 224638M [libInfra] trace CThreadManager::CThreadManager()>>>>>>>>> 40m20:07:21|[libInfra] debug ThreadBody Enter name = NetFramework, id = 327, prior = N64, stack = 0x41823ca4 [bd6735] ....turn into DAY mode.... W] iris_cfg_over=1,irisStbpoint=126
tect_apert_state=1
e readCMOS DstTune flag is 0. " : "IP Camera", "IPC-HD2250C-V2" : "IP Camera", "IPC-HD2255C-V2" : "IP Camera", "IPC-HDBW2100E-V2" : "IP Camera", "IPC-HDBW2105E-V2" : "IP Camera", "IPC-HDBW2150E-V2" : "IP Camera", "IPC-HDBW2155E-V2" : "IP Camera", "IPC-HDBW2200E-V2" : "IP Camera", "IPC-HDBW2205E-V2" : "IP Camera", "IPC-HDBW2250E-V2" : "IP Camera", "IPC-HDBW2255E-V2" : "IP Camera", "IPC-HDW2100C-V2" : "IP Camera", "IPC-HDW2100S-M-V2" : "IP Camera", "IPC-HDW2100S-V2" : "IP Camera", "IPC-HDW2105C-V2" : "IP Camera", "IPC-HDW2105S-M-V2" : "IP Camera", "IPC-HDW2105S-V2" : "IP Camera", "IPC-HDW2150C-V2" : "IP Camera", "IPC-HDW2150S-M-V2" : "IP Camera", "IPC-HDW2150S-V2" : "IP Camera", "IPC-HDW2155C-V2" : "IP Camera", "IPC-HDW2155S-M-V2" : "IP Camera", "IPC-HDW2155S-V2" : "IP Camera", "IPC-HDW2200C-V2" : "IP Camera", "IPC-HDW2200S-M-V2" : "IP Camera", "IPC-HDW2200S-V2" : "IP Camera", "IPC-HDW2205C-V2" : "IP Camera", "IPC-HDW2205S-M-V2" : "IP Camera", "IPC-HDW2205S-V2" : "IP Camera", "IPC-HDW2250C-V2" : "IP Camera", "IPC-HDW2250S-M-V2" : "IP Camera", "IPC-HDW2250S-V2" : "IP Camera", "IPC-HDW2255C-V2" : "IP Camera", "IPC-HDW2255S-M-V2" : "IP Camera", "IPC-HDW2255S-V2" : "IP Camera", "IPC-HDW3100S-V2" : "IP Camera", "IPC-HDW3105S-V2" : "IP Camera", "IPC-HFW2100-B-V2" : "IP Camera", "IPC-HFW2100B-V2" : "IP Camera", "IPC-HFW2100D-V2" : "IP Camera", "IPC-HFW2100S-V2" : "IP Camera", "IPC-HFW2105-B-V2" : "IP Camera", "IPC-HFW2105B-V2" : "IP Camera", "IPC-HFW2105D-V2" : "IP Camera", "IPC-HFW2105S-V2" : "IP Camera", "IPC-HFW2150B-V2" : "IP Camera", "IPC-HFW2150D-V2" : "IP Camera", "IPC-HFW2150S-V2" : "IP Camera", "IPC-HFW2155B-V2" : "IP Camera", "IPC-HFW2155D-V2" : "IP Camera", "IPC-HFW2155S-V2" : "IP Camera", "IPC-HFW2200B-V2" : "IP Camera", "IPC-HFW2200D-V2" : "IP Camera", "IPC-HFW2200S-V2" : "IP Camera", "IPC-HFW2205B-V2" : "IP Camera", "IPC-HFW2205D-V2" : "IP Camera", "IPC-HFW2205S-V2" : "IP Camera", "IPC-HFW2250B-V2" : "IP Camera", "IPC-HFW2250D-V2" : "IP Camera", "IPC-HFW2250S-V2" : "IP Camera", "IPC-HFW2255B-V2" : "IP Camera", "IPC-HFW2255D-V2" : "IP Camera", "IPC-HFW2255S-V2" : "IP Camera", "IPC-HFW3100-V2" : "IP Camera", "IPC-HFW3100D-V2" : "IP Camera", "IPC-HFW3105-V2" : "IP Camera", "IPC-HFW3105D-V2" : "IP Camera" } }
/Ssdp.cpp 2278 ioctl error! DeviceType" : "urn:schemas-upnp-org:device:3.0-TZC4LU190W00838", "FriendlyName" : "TZC4LU190W00838", "Manufacturer" : "General", "ManufacturerUrl" : "http:\/\/\/", "ModelDescription" : "General IPC", "ModelName" : "IPC", "ModelNum" : "IPC", "ModelUrl" : "http:\/\/\/", "PresentationUrl" : "http:\/\/192.168.10.210:80", "SerialNumber" : "4c:11:bf:8b:9d:ed", "Udn" : "uuid:device_3_0-TZC4LU190W00838", "Upc" : "" }
5d4 lo ERROR (../../src/net/net.c|setRoute|663): delete route error setRoute: No such process tApp.cpp, 228. 20:07:23|[libNetApp] trace CNetApp::ARPPingSetIP() Start>>>>>>>>>> rn Src/UPnP/UPnPDevPoint.cpp:145, start,startOnline fail! er] warn CConfigManager::getConfig T2UServer is Json::nullValue! etApp] error CDeviceUdp::getComponentInstance failed, Src/AutoSearchIP/DeviceDiscover.cpp,36 p] trace CProviderManager::start()>>>>>>>>>>>>>>>>>> geGroup:[ { "Channels" : [ { "MaxPictures" : 0, "Path" : null } ], "FileHoldTime" : 0, "Memo" : "For Reading & Writing Files", "Name" : "ReadWrite", "OverWrite" : true, "PicturePathRule" : "%y-%M-%d\/%c\/jpg\/%h\/%m\/%s[%E][%O@%S][%R].jpg", "RecordPathRule" : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav" }, { "Channels" : [ { "MaxPictures" : 0, "Path" : null } ], "FileHoldTime" : 0, "Memo" : "For FTP Files", "Name" : "FTP", "OverWrite" : true, "PicturePathRule" : "%y-%M-%d\/%c\/jpg\/%h\/%m\/%s[%E][%O@%S][%R].jpg", "RecordPathRule" : "%y-%M-%d\/%c\/dav\/%h\/%h.%m.%s-%h.%m.%s[%E][%O@%S][%R].dav" } ]
s=50,new contrast=50, new saturation=50, new hue=50 e shmId=425997 done [libenc] remap osd done,index=0, virtaddr_sonia=0x48002000 [libenc] remap osd done,index=1, virtaddr_sonia=0x48016000 [libenc] remap osd done,index=2, virtaddr_sonia=0x4802a000 [libenc] remap osd done,index=3, virtaddr_sonia=0x4803e000 [libenc] remap osd done,index=4, virtaddr_sonia=0x48052000 [libenc] remap osd done,index=0, virtaddr_sonia=0x48066000 [libenc] remap osd done,index=1, virtaddr_sonia=0x4807a000 [libenc] remap osd done,index=2, virtaddr_sonia=0x4808e000 [libenc] remap osd done,index=3, virtaddr_sonia=0x480a2000 [libenc] remap osd done,index=4, virtaddr_sonia=0x480b6000 [libenc] remap osd done,index=0, virtaddr_sonia=0x480ca000 [libenc] remap osd donels = 0 els = 0 audio ERR] : FILE -> /home/jenkins/jk_slave_centos6/workspace/IPC_DH3.S0506_36XV2.420/tmp_build_dir/libaudio_DM365/src/audioenc/audioenc.c, LINE -> 209 : srcs=0x1,out of range,audioInCnt=0 kins/jk_slave_centos6/workspace/IPC_DH3.S0506_36XV2.420/tmp_build_dir/libaudio_DM365/src/audioenc/audioenc.c, LINE -> 384 : desc->srcs=0x1,stream=1,out of range :getConfig VideoInSensor is Json::nullValue! 0:07:25|trace CDevVideoEnc::setFormat channel = 0, stream = 0, size = [1920, 1080], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 4096 kbps, quality = 4,pack = 0, type = 3, h264profile = 3 ] set [0] format:width=1920,height=1080,bitrate=4096,fps=25,gop=50,qualityType=0,quality=4,size=0,type=3 = 1, size = [352, 288], fps = 25.000000, gop = 50, bitratectrl = 0, bitrate = 512 kbps, quality = 4,pack = 0, type = 3, h264profile = 1 create_encoder done! ret=0 ce CDevVideoEnc::setFormat channel = 0, stream = 4, size = [1920, 1080], fps = 1.000000, gop = 60, bitratectrl = 1, bitrate = 5120 kbps, quality = 5,pack = 0, type = 4, h264profile = 0 etConfig Talkback is Json::nullValue! ionDisable::m_cfgMotionEnable[channel:0]: 0 amicRange = 3,priv->caps.glareInhibition = 1,option->backlight = 0,option->wideDynamicRange = 0,option->glareInhibition = 0 am.rotate:0 [libfvideo] antiFlicker:0 [libfvideo] exp:0 [libfvideo] aemod:0 [libfvideo] vga:0 [libfvideo] wide:0 [libfvideo] glareInhibition:0 [libfvideo] backLightRange:3096 3096,5096,5096 [libfvideo] ad9923a_clamp:0 [libfvideo] advanceAe:0 50,0 [libfvideo] [fvideo_to_videodaemon]----cmd: 0x181246
eoEnc::setWorkFormat m_videoTitle[0] setWorkFormat: 1920, 1080,stream:4 code] set stream[4] format:width=1920,height=1080,bitrate=5120,fps=1.000000,gop=60,quality=5,type=4 16 format is same, do nothing. p:816 format is same, do nothing. web_icr_sensitivity_level =2
2m[AEW] -------sensor -- ae_ctrl------ light_freq=0, exp_mode=0,ae_mode=0,gain_min=0,gain_max=0,sht_min=2,sht_max=1578
t change gain :ctrl_parm.gain_min=1,ctrl_parm.gain_max=818,gain_min=0,gain_max=50 _freq=0, exp_mode=0,ae_mode=0,gain_min=1,gain_max=818,sht_min=2,sht_max=1578
l = 1, bitrate = 5120 kbps, quality = 5,pack = 0, type = 4, h264profile = 0 _min=1,gain_max=818,sht_curr=1578
ncoder->setWaterMark call 1 ok, 0 failed! returne:1>>>>> 0;32;32m[capture] 2048, 1536, 1920, 1080 > ault DVRIP Detect, id = 343, prior = N3, stack = 0x4b354ca4 20:07:27|[libStorage] trace m_netTimer.Stop()============== lse, "Name" : "SMB1", "Password" : "", "Port" : 445, "Protocol" : "SMB", "UserName" : "" } 28|[libStorage] trace CFtpClient::Start General : { "LocalNo" : 8, "LockLoginEnable" : true, "LockLoginTimes" : 3, "LoginFailLockTime" : 1800, "MachineName" : "TZC4LU232W00191", "MaxOnlineTime" : 3600 } , line : 113 20:07:28|[libStorage] error create cqfsPtr error,162,Src/iSCSIClientImpl.cpp = 347, prior = N64, stack = 0x4d358ca4 ----------< ...... 0:07:28|[libStorage] info CStorage::enableStatusCheckTimer>>StatusCheckTimer is enabled!!! 7:28|[libInfra] debug ThreadBody Enter name = NetWorkState, id = 350, prior = N64, stack = 0x4e3fcca4 too large: 7, set to 5 28|[Manager] trace get Vendor: General is_show_LocationInfo" : 1, "is_show_MP4DownLoad" : 1, "is_show_OSDinfo" : 1, "is_show_Syslog" : 0, "is_show_T2UServer" : 0, "is_show_VPN_Certificate" : 0, "is_show_azimuthDisp" : 0, "is_show_duck" : 1, "is_show_help" : 0, "is_show_mousecontrolptz" : 0, "is_show_startDeviceDiscover" : 0, "is_show_upnpMode" : 1, "is_show_whiteBalanceOutdoor" : 1, "mac_plugins_version" : 3, "show_ATM_config" : 0, "show_Device_type" : 0, "show_NAS_config" : 1, "show_SNMP_config" : 1, "show_auto_register" : 1, "show_bonjour_config" : 1, "show_comm_config" : 0, "special_GOP_728WP" : 1, "use_mac_plugins" : 1, "vendor" : "General", "videodetect_default_sensitive" : 58, "videodetect_default_threshold" : 4, "win_plugins_version" : 3 }
.42.42", "Port" : 36666, "StreamType" : "Main" }, { "Channel" : 0, "Enable" : false, "LocalAddr" : "192.168.1.102", "MulticastAddr" : "239.255.42.42", "Port" : 36667, "StreamType" : "Extra1" } ], "RTP" : [ { "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.4", "Port" : 40000, "StreamType" : "Main", "TTL" : 64 }, { "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.4", "Port" : 40008, "StreamType" : "Extra1", "TTL" : 64 } ], "RTPAudio" : [ { "AutoStart" : false, "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "Mixed" : true, "MulticastAddr" : "224.1.2.4", "Port" : 40002, "StreamType" : "Main", "TTL" : 64 }, { "AutoStart" : false, "Channel" : 0, "Enable" : true, "IPType" : "IPV4", "IPV6" : "FF15:0000:0000:0000:0000:0000:8000:0000", "Mixed" : true, "MulticastAddr" : "224.1.2.4", "Port" : 40004, "StreamType" : "Extra1", "TTL" : 64 } ], "TS" : [ { "Channel" : 0, "Enable" : false, "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.3", "Port" : 20000, "StreamType" : "Main" }, { "Channel" : 0, "Enable" : false, "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.3", "Port" : 20008, "StreamType" : "Extra1" } ] }
reamid=1, enable=1 reamSource.cpp:54 Get <IDevAudioEnc> Failed! channel:0 stream:1 set_videodaemon_framerate streamid=1, fps=2 1 c):m_run to true, m_stream: 1 IFRAME is done [0m32;32m[encode] set_videodaemon_framerate streamid=4, fps=1 0:07:30|trace updata_multicast_channel config:{ "Channel" : 0, "Enable" : false, "IPType" : null, "IPV6" : null, "LocalAddr" : "0.0.0.0", "MulticastAddr" : "224.1.2.3", "Port" : 20000, "StreamType" : "Main", "TTL" : null }
ddr" : "224.1.2.3", "Port" : 20008, "StreamType" : "Extra1", "TTL" : null }
RTSP Server success! listen port: 554 349 64 Normal 64 Normal ra] info [Pooled] 334 64 Normal ed] 326 64 Normal eMonitor 42949408440 0 1000 0/ 60000 Idle 60000 Idle ibInfra] info smbNetCheck 42949419930 0 15000 0/ 0 Idle nder 42949461240 0 60000 0/ 0 Idle r.cpp 249 live channel:cam/realmonitor?channel=1&subtype=0&unicast=false end init !!!! efore play==== 32;40m20:07:31|info ===add data src, before play==== RtspLiveServer.cpp 249 live channel:cam/realmonitor?channel=1&subtype=4&encrypt=1 end init 2m[AEW] write 0x3180 ok! val is 0xa089 Arena 0: system bytes = 4915972 in use bytes = 4762284 Arena 1: system bytes = 135168 in use bytes = 24224 Total (incl. mmap): system bytes = 26215172 in use bytes = 25950540 max mmap regions = 13 max mmap bytes = 21164032 AEW] read 0x3182 ok! val is 0x2
----------------------------------------------- Date: 05.02.2020 - 20:50:20 End log file
