Текущее время: 28 ноя 2026, 18:35
 Заголовок сообщения: Lenovo Thinkpad L530 (Intel) No Power
СообщениеДобавлено: 06 фев 2020, 06:04
Lenovo Thinkpad L530 No Power Problem. Connect with adapter and adapter light goes out. 19V line is short. I do not have schematic of this model. So i remove PR4002 Resistor (Fig-1) and connect with DC Power Supply to find short (hot component). Found shorted Capacitor near CPU and Replace with good one. But when i connect with adapter, it short again. Found Other capacitor near CPU short again. So i check Capacitor (Near CPU) with Multimeter and found 19V. When i connect Adapter (or) Power Supply, 19v is also here in CPU Supply Volt line (Fig-2). I think CPU Supply Volt may be 1V or nearly. But in this laptop 19v is there in CPU Supply Volt Line. I don't know Why? Please help me to find this kind of short.
Fig-1
https://drive.google.com/open?id=16UWvg ... TPJ1DD28pR
Fig-2
https://drive.google.com/open?id=12eOWh ... RTBV9gHiyf
Lenovo Thinkpad L530 (A)
https://drive.google.com/open?id=13hkrq ... VDW56yoiEJ
Lenovo Thinkpad L530 (B)
https://drive.google.com/open?id=18Q1-l ... 1uGeYUqjzl
 Заголовок сообщения: Re: Lenovo Thinkpad L530 (Intel) No Power
СообщениеДобавлено: 06 фев 2020, 07:07
check upper mosfet`s in cpu power (pu4301 pu4303 ?).
СообщениеДобавлено: 07 фев 2020, 18:50
First of all, thanks for your help. I found bad mosfet (PU4301). But i do not have this type of mosfet. So i tried to replace with some N-Channel mosfet by wire connection. Now laptop is power on but no display. CPU Core voltage is ok (about 1.1V). But a few minutes run replaced mosfet is so hot and wire connection is loose. Any short remain on motherboard? Or need to replace same type of mosfet.
https://drive.google.com/open?id=1-j0dT ... a7vN8yiSxY
https://drive.google.com/open?id=1OemCV ... _DJgwvT1AB
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ThinkPad L530 (Wistron LBF-1 11270-4) стартует со второго включения
Leo_vrn
5950
11 май 2017, 13:40
Leo_vrn Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ThinkPad L530 (Wistron LBF-1 11270-4) стартует со второго раза
wadim
22 июл 2018, 23:59
wadim Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Thinkpad l530 (Wistron) Стартует со второго раза
alleks975
05 апр 2020, 20:28
alleks975 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. thinkpad T60 (intel centrino duo) Висит на заставке Thinkpad
vhzr
22 фев 2020, 18:05
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. LENOVO ThinkPad DL470 (LENOVO ThinkPad DL470 ) Прошивка
в форуме Поиск BIOS
datacode
2260
17 июн 2022, 08:06
datacode Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 77
