Текущее время: 29 ноя 2026, 17:06
 Заголовок сообщения: Asus GTX 1060 6gb Strix only 12v
СообщениеДобавлено: 19 мар 2020, 20:01
Hello everyone, I would like to apologize if I can't be clear, I'm Brazilian and this is my first topic, I've been following the forum for some time with the help of the Google translator, but I couldn't find any topic where there was a problem similar to mine. , but let's go:
this asus gtx1060 strix in question has no voltage beyond 12v, and i've already looked for a lot of information and i haven't found where the 5v is generated, in some points there is the 3.3v that comes from the PCI, could someone tell me where the 5 are generated volts of that plate, so I can proceed?
 Заголовок сообщения: Re: Asus GTX 1060 6gb Strix only 12v
СообщениеДобавлено: 19 мар 2020, 20:21
Я не знаю эту карту, но она, вероятно, сзади.
СообщениеДобавлено: 19 мар 2020, 21:02
hello, here is a picture of the back part, there are only 1 ina3221 and 2 ci's 3949s that I believe are responsible for the fan.
thanks.
СообщениеДобавлено: 20 мар 2020, 01:38
Чувак, почему ты ищешь 5v. Тщательно опишите проблему, укажите все параметры.https://images.app.goo.gl/hKXDS6BBua8LEyZb6
СообщениеДобавлено: 20 мар 2020, 10:49
TheMArcos
in this case, first you need to find 1.8 volts. after the formation of this voltage, the rest appear. Check the chokes PL1 and PL3. one of them will ring on 8 pin BIOS chip, this will be 1.8 volts. the other will form 5 volts accordingly.
measure the resistance at the chokes pl1, pl2, pl3, pml2. write the result here. we’ll think about whether to repair this card at all.
ps. foto is too bad
СообщениеДобавлено: 21 мар 2020, 21:32
I was looking for the 5 volts because I believed it was missing in the nc671 vcc, but the image you sent clarified me a lot, thank you very much.
yes the PL1, is connected to the bios chip but without voltage.
after I saw the image that the mikazuki sent I checked the resistance in PL3 and it was 56ohms, that is very low, so I tried to inject 5v into the coil and I felt a slight heat in the GPU, did I end up killing the gpu or the she would already be dead, but it wasn’t supposed to reach 5V, right? I removed the gpu anyway, so I could inject the voltage and see if I can find out where the short circuit is, at least for the sake of learning.
PL1: 880 ohms (now without the gpu)
PLM2: 55ohms
PL3: 15k ohms
PL2: 970 ohms
aleksros писал(а):
ps. foto is too bad
Sorry, next time i will try to send a better picture
Is this resistance so low?
and thank you all for your help.
В этой теме нет новых непрочитанных сообщений. Zotac GTX 1060 6gb cannot install driver | Zotac GTX 1060 6gb не может установить драйвер
katoda22
16 апр 2025, 06:41
wupaul2001 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. переделка блока питания ATX в блок для fujitsu 12v only
в форуме Ремонт ИБП | UPS repair
romanck
30 май 2019, 14:53
romanck Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte Rx 570 4GB - Only 12v and 3.3v
TheMArcos
28 мар 2020, 19:19
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Palit GTX970, only draw round 600mA @ 12V, no picture
Assassin
26 июл 2022, 13:44
SimbA Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. China 12v 20A не поднимается 12v нету питания на микросхеме
Sparkster
4580
29 апр 2018, 09:14
spesso Перейти к последнему сообщению
Сейчас этот форум просматривают: EvilMisss, mrstemr, psc_007, ruzalit и гости: 112
