ilie321 писал(а):
k4g20325fd-fc03. can it be replaced with k4g41325fd-fc03
In theory - yes, but only if the same as your type graphics card was manufactured and had 6Gb memory; and you can take bios dump from that card.
This is a minimum requirement, but maybe will need change some configurations straps on board. For understand need look on both models and compare straps positions.
