Текущее время: 29 ноя 2026, 16:40
 Заголовок сообщения: XFX RX 480 FAULTY
СообщениеДобавлено: 01 май 2020, 08:37
I have 5 RX-480P8DBA6 that doesnt work
They were mined long time ago, problem is Blue screen after windows is loaded, in Linux, Screen is freeze after it loads
Fans stop spining after crashing
I have same gpu working too if needed for test
 Заголовок сообщения: Re: XFX RX 480 FAULTY
СообщениеДобавлено: 01 май 2020, 17:50
If start at once 5 on a farm that probably from behind one faulty the dark blue screen turns out at driver start, to find faulty and to start without it. And if and at start on one dark blue screen that it probably degradation GPU also is necessary replacement of the chip by the working.
To try to start in Windows if there will be artefacts that probably problem with memory on them.
СообщениеДобавлено: 01 май 2020, 21:53
Gpu core works, already tested, also, sometimes if you install drivers while you are in Windows it works (but still no fan spin, even if it reach 89°), but if you restart the computer with drivers installed, it wont work, blue screen will appear (Driver Threat Stuck ir something like that)
It's not Driver related, nor BIOS, there's something on the board that is causing the issue but i dont know where to start
СообщениеДобавлено: 02 май 2020, 00:29
Your signs with not adjustable coolers at temperature 89 ° and the dark blue screen after reboot when the map should work under the driver specify on faulty GPU.
Now began to come across often such RX470, RX480 after work in mining with degradation GPU.
Try to put on one obviously serviceable chip GPU and whether be convinced of it business. Otherwise in any way not to check up any more.
СообщениеДобавлено: 02 май 2020, 02:22
Yes, already changed the gpu chip with a known working one, still same problem, also tried changing BIOS.
СообщениеДобавлено: 02 май 2020, 15:36
And with what all has begun at once on 5 maps? What, was network races on a farm or there were problems with the power unit?
Have checked up, have measured chains of primary food PLL and secondary memory and the processor, pressure correspond to the necessary sizes?
Cooler time do not cope to check up elements of this chain.
And BIOS to fill in firm with which penalties were delivered.
СообщениеДобавлено: 03 май 2020, 22:58
I'm a bit confused, what do i need to measure?
This is the card:
СообщениеДобавлено: 03 май 2020, 23:38
first - change thermal grease, may be all be ok.
СообщениеДобавлено: 04 май 2020, 00:27
I wish the problem was that simple.
СообщениеДобавлено: 04 май 2020, 10:29
and you should try to get started.
even the photo shows that there is a stone.
СообщениеДобавлено: 04 май 2020, 22:47
Dude, that's a working XFX you seeing here (the upper one), just dissasembly it for maintenance and took a photo, 55º on max load (100% fanspeed), i've already tried every simple thing with the non-working cards. Thanks anyway for your attention,.
СообщениеДобавлено: 09 май 2020, 04:07
我希望问题就这么简单
СообщениеДобавлено: 15 май 2020, 11:31
У меня такая же проблема с такой же картой как и у ВАС - viewtopic.php?f=48&t=97365
В этой теме нет новых непрочитанных сообщений. Возможна замена чипа с RX 480 на RX 580 MSI RX 480 Gaming X 8 GB ?
Crimfell
09 май 2022, 08:05
hualei16888 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. XFX RX 480 8 Gb - нет изображения
Gas_man
28
12128
27 мар 2022, 17:04
GerIlja Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX RX-480 оторваны пятаки
c-ishim
22 ноя 2020, 15:30
nosferatu13fd Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error
ll_r1d0_ll
2080
06 ноя 2022, 12:04
karlan Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Помогите опознать элемент в обвязке NCP81022. Карта XFX Radeon RX 480 RS 8GB D5
Wolferine
24 фев 2024, 12:28
Wolferine Перейти к последнему сообщению
Сейчас этот форум просматривают: Pahha и гости: 114
