Текущее время: 03 ноя 2026, 08:02
 Заголовок сообщения: Msi R7 370 2g armor turns on and off 2 seconds later
СообщениеДобавлено: 01 апр 2020, 20:49
hello friends, i received this card here for repair second the client stopped giving video "suddenly", these cards have a chronic problem that the first mosfet goes short and 12v coil that filters the voltage of the pci express opens, well, knowing I quickly detected the mosfet in a short time and replaced the coil, when testing the video deeu card normally (even the oxen, because the heatsink had not yet been installed), I cleaned the plate, mounted the heatsink, turned on, loaded the windows, but after about 2 minutes on (I hadn’t installed the drive yet), the card started showing vertical artifacts, so I turned off the card, when trying to rewire it doesn’t go past the bios anymore, it starts from the video but at the time of loading the windows it shuts down.
this is the version of my card (I took the image from another topic):
 Заголовок сообщения: Re: Msi R7 370 2g armor turns on and off 2 seconds later
СообщениеДобавлено: 01 апр 2020, 21:16
Hi! Vertical artefacts are characteristic for memory in first time, second time for gpu. Power of memory good? Can you post photo artefacts? Thanks.
СообщениеДобавлено: 01 апр 2020, 21:53
Thanks for the answer
in this period when I opened the topic I decided to perform the gpu reballing, and now the board is running normally, so I noticed that the fans are running at 100% and do not accept adjustment (msi afterburn), the gpu shows that it is running 20% but the noise is hellish hahahaha, now I need to find out what is causing this uncontrolled RPM
СообщениеДобавлено: 09 май 2020, 03:56
hello everyone, the card started showing this type of artifact, is there any way to know which memory could be causing this? or will I have to replace it with the memory modules?
СообщениеДобавлено: 09 май 2020, 17:30
When you reball gpu in it fix contacts, perhaps. It's artefacts characteristic for memory, contacts memory to gpu, contacts in gpu. Try warming up gpu.
СообщениеДобавлено: 10 май 2020, 01:13
when i heat the gpu, do they temporarily disappear, do you really need a reball then?
СообщениеДобавлено: 10 май 2020, 02:59
TheMArcos писал(а):
when i heat the gpu
How do you warm the GPU?
СообщениеДобавлено: 10 май 2020, 03:03
I put a little bit of flow I melted with the blower and then I put it to reflow on the arch ir6000
СообщениеДобавлено: 10 май 2020, 04:18
TheMArcos писал(а):
ir6000
Frico IR6000?
СообщениеДобавлено: 10 май 2020, 06:10
in my country the brand is "arch" :-)
СообщениеДобавлено: 10 май 2020, 19:16
gpu reball executed, VGA under test (heaven bech, msi kombustor, 3d mark ...)
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 01:11
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell inspiron 3542 (Cedar_intel-mb 13269-1) Turns off after 2 seconds
в форуме Dell
alexkundara
21 июн 2020, 17:17
alexkundara Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo T460s (Compal NM-A421) After 10 seconds turns off. No screen, no beeps.
derick
30 ноя 2020, 19:55
derick Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Legion Y540 (NM-C221 Rev 2.0) Turns off after 32 seconds..
mohammedsf
13 июн 2025, 17:45
mohammedsf Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Ps3 20 seconds turn on and off
essuman32
08 окт 2025, 22:32
Alexsanic Перейти к последнему сообщению
Сейчас этот форум просматривают: Skillful, Yandex [BOT] и гости: 69
