Текущее время: 22 ноя 2024, 07:20
 Заголовок сообщения: L850 (DK10FG-6050A2509901-MB-A02) Discrete to UMA
СообщениеДобавлено: 17 май 2020, 04:09
Good afternoon,
on this motherboard, the power supply and control components of the processor's video core aren't soldered..
according to the schematics, TPS51650 (U6600) is in 3+0 mode for discrete graphics, the schematics has a table showing resistors setup for 3+2 mode to enable UMA..
did anyone try to cut the power on the discrete GPU and solder all missing chips and components and set U6600 to UMA mode ?
should it successfully work ? is BIOS flashing needed ?
Thanks in advance
 Заголовок сообщения: Re: L850 (DK10FG-6050A2509901-MB-A02) Discrete to UMA
СообщениеДобавлено: 17 май 2020, 10:45
Technically, it is possible, But it's easier to buy a board with UMA Graphics
Ремонт ноутбуков г. Чита.
СообщениеДобавлено: 19 май 2020, 03:50
Thanks for reply, it's not an easier option for me where I live, also I can't order it from abroad since the whole country is locked down..
Can't believe I'm the first one trying this conversion! I'll give it a try an hope it works, will be happy to reply with good news :)
СообщениеДобавлено: 09 июн 2022, 06:22
The first board failed with intel graphics driver, another board came but decided to do full conversion this time,
it works flawlessly with intel graphics driver running and no bios mod needed :co_ol:
Here is how to:
U6600 3+0 to 3+2:
Under U6600:
iGPU Phases:
Under iGPU Phases:
PCH:
Under PCH:
Disable 3.3v_DGPU Power:
Disable 1.8v_DGPU Power:
Disable 1.5v_DGPU Power:
Graphics Driver:
В этой теме нет новых непрочитанных сообщений. Toshiba L850 (DK10FG-6050A2509901-MB-A02) Discrete to UMA
в форуме Toshiba
tarum2003
07 апр 2022, 09:53
tarum2003 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. l855-c2m (dk10fg-6050a2509901-mb-a02) нет изо
в форуме Toshiba
oboje
3468
14 май 2016, 14:50
oboje Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba Satellite L855 ((DK10FG-6050A2509901-MB-A02) ) Пост код 28.
в форуме Toshiba
Abbas Abbasov
31 янв 2018, 16:39
kod.begemot Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. l855 (dk10fg-6050a2509901-mb-a02) Нет Изо.
в форуме Toshiba
wowa-x
2213
05 дек 2018, 21:03
wowa-x Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. L855-149 (DK10FG-6050A2509901-MB-A02) Отключение дискретной графики
в форуме Toshiba
Generallist
18 июн 2019, 17:54
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 26
