Текущее время: 21 ноя 2026, 03:59
MoneyBot
Заголовок сообщения: RTX 2080TI, 3 memory chips broken? |
MoneyBot
Assassin
Заголовок сообщения: Re: RTX 2080TI, 3 memory chips broken?  Добавлено: 27 май 2020, 07:04 |
| Интересующийся |
Зарегистрирован: 14 май 2020, 19:12 Наличности на руках: 78.21
Сообщения: 61 Откуда: germany
Update: I have tested first with simple reflow with flux, memory A1 and B0 still remained unimpressed, but B1 are now fine - no errors. So, i have desolder A1 and B0 chips and can see the issue...the solderpad on the memory chip itself are tore off, still stick on solder balls on the graphic card PCB. unbelievable. So memory chips physicalical damaged so i must solder new chips - and - card is now working fine I dont know what i should do with B1 that was repaired with simple reflow...i think i will change it also, or what do you mean?
