hi guys i have a motherboard here with strange behavior when only ac is pluged worked ok when just battery is pluged also worked when battery and ac is pluged and its off, it charging and binking charging LED every 5Sec
problem is when battery and ac is pluged in and turn it on it turnes on but doesn't use Ac and battery is in use status is plaged in and use 0.0A when unplug battery it stay on and use AC and after repluging battery it switch to battery again looks like it use AC just when is off!
i have no idea what is wrong here! what about you?!
IOD
Заголовок сообщения: Re: Ideapad 300 (NM-A481) Not Use AC when battery is pluged
when laptop is off and AC and battery is pluged it use 0.8A and charge battery but when i press power switch current drop to 0.00 and use battery if i unplug battery ,laptop stay on and switch to AC
IOD
Сейчас этот форум просматривают: Mr_N, Монтер65 и гости: 32
