Текущее время: 03 июл 2024, 11:25
 Заголовок сообщения: Dell 3550 (LA-B071P) not boot from hdd
СообщениеДобавлено: 09 июн 2020, 14:32
Hello Friends,
I have problem with Dell laptop. He don't want to boot from HDD properly. I can only choose boot option from "boot menu" and then i can boot anything (HDD, USB) what i want. But laptop don't want to boot Windows automaticly. It only works with boot menu, when i choose HDD, Windows in that case starts normaly
I tryed to change some options in bios but nothing works, still the same.
Next i read that can be bios dump problem, but when i trying to program chip with dump from this forum, laptop dont want to start. I get another one dump and it's the same. I did both, clean ME region, and replace with my original ME region in downloaded bios, but still the same. Maybe I'm doing somenthing wrong.
I find also KBC dump but i can't download picture for connect pins, and I'm not sure it will help. I want programm SPI first.
thank You in advance for your help
 Заголовок сообщения: Re: Dell 3550 (LA-B071P) not boot from hdd
СообщениеДобавлено: 09 июн 2020, 15:48
Try this
1. Power on the system, then go to BIOS Setup by pressing F2 and go to "General>Boot Sequence > Boot List Option".
2. Change "UEFI" to "Legacy" of Boot List Option.
3. Click "Apply","Exit" to save changes and reboot system.
Or
1. Power on the system, then go to BIOS Setup by pressing F2 and go to "General > Boot Sequence > Boot List Option".
2. Change "Legacy" to "UEFI" of Boot List Option.
3. Click "Apply", "Exit" to save changes and reboot system.
https://www.dell.com/community/Inspiron ... -p/5971157
СообщениеДобавлено: 17 мар 2021, 15:00
I was sure i did it before, but maybe not exact. This time it helps. Thank You very much.
В этой теме нет новых непрочитанных сообщений. Dell Latitude 3550 (la-b071p rev:1.0) Shut down after 30 sekundy
в форуме Dell
Slave82
11 фев 2019, 07:06
Azazehl Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Latitude 3550 (la-b071p rev:1.0) Выключается через 30 сек
в форуме Dell
ornellit
23 апр 2019, 17:34
recordsman Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell latitude 3550 (la-b071p rev 1.0) Чем прошить мультиконроллер MEC5085-LZY
в форуме Dell
dontwalk
19 авг 2021, 11:19
dontwalk Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL LATITUDE 3550 (LA-B071p) подобрать аналог
ValdemarKravets
20 окт 2021, 13:17
ValdemarKravets Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer TMP455-MG (AC82935) Default Boot Device Missing or Boot Failed
frigate
02 мар 2015, 10:49
frigate Перейти к последнему сообщению
