Текущее время: 06 ноя 2026, 07:47
 Заголовок сообщения: lg 42lw4500 alloy comes with picture and sound and after a few seconds erases everything
СообщениеДобавлено: 27 июн 2020, 01:55
The first thing I did was to disconnect the flets cables from the main board and the t-con board and apply a rubber eraser to the contacts of the flets cables, in addition to general cleaning inside the TV. So I put an antenna and tuned in the TV channels. The TV worked for 10 to 20 minutes normally. Soon after, the TV only got the sound, but the image disappeared (the screen was black). I noticed that the mainboard processor is hot. I think just by changing the main board. If you could solve this problem without spending a lot of money and in a hurry, it would be ideal.
I'm thinking, just to make a test, to increase the size of the heatsink placed on top of the mainboard processor and analyze if the TV will stay on longer with the image. Other technicians remove the main board and wrap it all in aluminum foil leaving only the processor area open and place the board inside an electric oven for about 10 minutes at a temperature of around 200 degrees.
 Заголовок сообщения: Re: lg 42lw4500 alloy comes with picture and sound and after a few seconds erases everything
СообщениеДобавлено: 27 июн 2020, 04:11
The chip is very affected
warm, help for a while
Вас обманули,это Шанхайский барс
Телефон вацап,вайбер, телеграмм 8914 577 2911 Борис
Помогу удалённо отремонтировать тв и другое
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 01:11
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Toshiba C50-b-149 (la-b301p) Starts and shuts down after 6 seconds Need BIOS DUMP
в форуме Toshiba
draganzile
13 фев 2018, 02:52
В этой теме нет новых непрочитанных сообщений. Shappire 5870 1GB power cutoff after few second.
Micchaleq
11 окт 2018, 18:05
Micchaleq Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Creative Sound Blaster AE-7 или Creative Sound BlasterX AE-7 DAC
в форуме Аудиотехника
iljabaz
27 окт 2024, 11:43
iljabaz Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo X230 (ldb-2 mb 11232-1) No picture on LCD after short with fan connector
derick
14 май 2020, 18:54
richk Перейти к последнему сообщению
