Текущее время: 22 ноя 2024, 15:22
 Заголовок сообщения: Gigabyte GTX 960 4GB "Please power down and connect...."
СообщениеДобавлено: 30 июн 2020, 14:14
Hi guys. Card model is gv-n960oc-4gd. Card is starting up but on a screen you can see "please power down ......". There is no short at any vcore mosfets all values are also same and correct. There is almost 1v at all vcore coils but only one (bottom one which take power form pcie slot) gives correct osciloscope signal, the rest 3 coils give flat signal. I have replace ina 3221 but no change. Looks like PWM controler doesnt want to turn on rest of a missing phases. It is NCP81174 and only G1 output gives a correct value (~0,5 volt) which operate a bottom phase, rest G2,G3,G4 output give around ~1,4 volt which i belive dont turn rest of the missing phases on. There is no missing components at the board beside one which i am not sure 100% is it missing or it should be empty (look at picture). A week ago i had similiar problem with asus strix gtx 980. There are 8 phases 7 working and 1 was not and same "please power down...." I had to give up on it after i have changed ina 3221, pwm controler, and phase driver and also everything was looking fine beside that at the last not working phase pwm controler was giving 3.3 v signal to the driver and to the rest working ones it was around 0.2 v as i remember. Please advice where should i look coz i am out of any more ideas. Thank you
http://eximage.ru/image.php?di=HH2W
 Заголовок сообщения: Re: Gigabyte GTX 960 4GB "Please power down and connect...."
СообщениеДобавлено: 30 июн 2020, 14:28
find q505 (6 pin) and q506 (3 pin). measure the voltage on them and come here. we will prompt))
СообщениеДобавлено: 30 июн 2020, 17:13
Thank you for fast replay. I did mesure. Look at the picture please.
http://eximage.ru/image.php?di=CJ4Q
СообщениеДобавлено: 30 июн 2020, 18:06
fine )) we found error signal. missing resistor r516 10k. soldering that and all be OK.
 Заголовок сообщения: Re: Gigabyte GTX 960 4GB "Please power down and connect...."  [РЕШЕНО]
СообщениеДобавлено: 30 июн 2020, 18:43
Yes it was missing resistor. Card is working fine now. Thank you very much for help. :co_ol:
В этой теме нет новых непрочитанных сообщений. Zotac GTX 970 4GB "please power down and connect..."
dani82
09 янв 2022, 13:41
Pandemonium6 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac GTX 970 Dual пишет "please power down and connect the pcie power cable for this graphics card"
pccraster
15
752
16 окт 2024, 14:23
Raptor_3000 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ZOTAC nvidia 680 4gb "Please power down and connect...."
Anton01041988
04 мар 2024, 01:09
takavara Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. KFA2 Gtx1080Ti please power down and connect the pcie power cable for this graphics card
serenkiy
18
3114
11 июл 2022, 18:48
serenkiy Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI GTX 1070 Gaming X 8G "connect the pcie power cable for this graphics card"
TomaszR
23 апр 2024, 14:14
dron102 Перейти к последнему сообщению
Сейчас этот форум просматривают: bsb5068 и гости: 102
