Текущее время: 21 ноя 2026, 04:09
 Заголовок сообщения: Lenovo Flex 2 - 15 (LF15M) No picture
СообщениеДобавлено: 26 июн 2020, 08:39
Hello everybody.
I've got Lenovo Flex 2-15 for repair with no picture. All voltages are present, battery charging is working fine, motherbord takes about
0,5 Ampers and that's it. I've reprogrammed the bios and still the same problem. They say it might be a problem with graphic chipset but
I would like to make sure this chip is faulty before I replace it. Could you tell me how to connect the diagnostic debug card to see what
error this card will show me? The KBC is NPCE285GA0DX and I need the pinout of LPC interface to this chip please.
 Заголовок сообщения: Re: Lenovo Flex 2 - 15 (LF15M) No picture
СообщениеДобавлено: 26 июн 2020, 08:49
Did you try to disassemble the coil
СообщениеДобавлено: 26 июн 2020, 10:36
Yes, I did and no change, still no picture on LCD and HDMI.
СообщениеДобавлено: 26 июн 2020, 15:22
lenovo flex 2-15 fl15m mb 13308-1 clear-me 8 mb
Ekli dosyalar
try this bro
СообщениеДобавлено: 28 июн 2020, 00:41
I would like to check out this bios but I have not enough points to download it. Can you send it to me with PM?
СообщениеДобавлено: 30 июн 2020, 13:09
Ok. I could download this bios file now and I programmed my eeprom but still the same no pictures and motherboard takes about 0,5A without battery. Any other suggestions? Could be KBC faulty?
СообщениеДобавлено: 13 июл 2020, 21:44
Finally I have found the fault. There were two faults in this board, first was the faulty bios and the second was faulty ram memory and that's it. Now after reprogramming new bios and replacing ram memory laptops is working fine. Thank you everybody for help.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Flex 2-15 (LF15M MB) Нет изо на матрице, через HDMI работает
Prochenok
5002
19 дек 2016, 19:01
antares_87 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Flex 2-14 (LF15M MB 13308-1) Не работает клавиша Delete
Neadekvaten
3214
15 май 2018, 17:07
Neadekvaten Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Flex 2-15 (wistron LF15M) Перевести плату в UMA
Ivanches
20 июн 2019, 12:56
Ivanches Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. lenovo flex 2-15 (LF15M MB 13308-1) Не включаеться
velcom91
13 апр 2020, 14:59
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Flex 2 15D (LF15M) Автостарт
[ На страницу: 1, 2 ]
hzog
32
5833
29 май 2020, 16:23
hzog Перейти к последнему сообщению
Сейчас этот форум просматривают: Majestic-12 [Bot] и гости: 69
