Текущее время: 29 ноя 2026, 17:08
 Заголовок сообщения: RTX2080TI strange issue - all VRMs works fine but GPU still in reset state
СообщениеДобавлено: 12 июл 2020, 00:54
Hello there. i have a Palit Dual RTX2080TI here with strange issue...card wont dedect, also not in Windows with secondary graphic card, and on USB RiserCard it draw only round 1,5A@12V. All VRMs works fine, no mosfet report a fault, 5V and 1.8V present, up9512P PGood is high - but gpu still seems to be in reset state. I think gpu isnt become the vrm ready signal, but how/where can i check this? GPU is only slowly warms up, but not too much.
its a reference design pcb. any tips for me?
 Заголовок сообщения: Re: RTX2080TI strange issue - all VRMs works fine but GPU still in reset state
СообщениеДобавлено: 13 июл 2020, 16:50
Nothing? :( what can i also check? All VRMs works finde, checked with oscilloscope
СообщениеДобавлено: 13 июл 2020, 21:25
take a photo of your card, write on the chokes resistance and voltage
СообщениеДобавлено: 13 июл 2020, 22:35
Изображение Изображение
this one choke with 0V is - i think - normal. I think it's the load balancing system i heard from several teardown videos...or not?
about the lower 3 memory modules - i have desoldered it because one of them was already swapped, and so i was able to check the solder pads and the memory itself in diode mode - all 3 modules are ok.
Card was also not started without this 3 memorys.
draws only round 1,6A@12V without heatsink
СообщениеДобавлено: 13 июл 2020, 22:51
wash the crystal is not clear crack or thermal grease
- normal - USB-C
СообщениеДобавлено: 14 июл 2020, 01:54
Search visually and with mupltimeter beeps where the trace goes from the PCIE_RST (A11 on the PCIe connector).
On some cards it goes directly to gpu, on the others it goes to some logic IC (5-6 pin typically), and that IC output goes to the GPU.
PCIE_RST goes high (3V) to enable GPU, measure it.
If the logic IC is present - measure it's output voltage. This IC is often dead.
СообщениеДобавлено: 14 июл 2020, 08:01
Ok i will check it later.
Here some pictures from thermal camera - notting get excesive hot
Изображение Изображение Изображение
And crystal is fine
СообщениеДобавлено: 19 июл 2020, 10:17
ok, i have check where the A11 trace goe to, but i cant find anything (with multimeter beep). it Goes from A11 directly into the lower layers of pcb, and i have beep out every logic IC - but cant find the signal. possibly it goes direct to gpu?
i have also trace the pwgood signal from up9512p PWM controler - it goes to an 5 pin smd ic (similar to sot23-5 but smaler) an have only writen "L2" on it. PCB mark is U39 (front site of card)
СообщениеДобавлено: 06 авг 2021, 09:56
I guess I'm necroposting here, but did you ever figure out what was wrong with the card, or where A11 connected to?
СообщениеДобавлено: 04 сен 2021, 20:50
Solved mine, which had the same problem: viewtopic.php?f=48&t=117883
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. What are the chances that the gpu still works?
Platinfish
09 янв 2021, 12:46
Platinfish Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Xbox One S has all the voltages, but still won't start.
borisz94
30 сен 2024, 21:47
borisz94 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help SSD Markvision works fine for 5 seconds
ricarry
14 ноя 2024, 03:07
ricarry Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 1050Ti KFA2 LP works/работает in PCIE x1 but not/но нет in PCIE X16 (X8)
cxav
24 фев 2023, 19:44
karlan Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP Notebook 14-dq1040wm (DA0PADMB8F0) Strange Audio issue
abuholm
26 апр 2020, 20:16
Сейчас этот форум просматривают: psc_007, ruzalit и гости: 118
