Текущее время: 17 ноя 2026, 13:24
 Заголовок сообщения: Fight with GTX 770 OC 4GB memory
СообщениеДобавлено: 23 июл 2020, 21:58
Hello everyone, this is my first post.
I've been struggling with the GTX 770 OC 4GB card for a few days.
After the initial check with the meter i put in into the computer and it works until the driver is loaded. The memory program showed that block C had errors. The card itself has 16 dice and the program showed only 5? What is the memory numbering?
Thanks in advance for the advice
 Заголовок сообщения: Re: Fight with GTX 770 OC 4GB memory
СообщениеДобавлено: 24 июл 2020, 03:01
check out "nano report.txt"
СообщениеДобавлено: 24 июл 2020, 09:45
Yes, I know the entire report is in this file. Linux is no stranger to me.
After what is in the picture, I have nothing else, because it has been overwritten
The error is on line
FBIOC [31:0] RANK0 WR ERR 16
Maybe there is some parameter that shows more precisely?
СообщениеДобавлено: 24 июл 2020, 10:51
jak zrobić raport „nano report.txt” i umieścić go w tym miejscu, wtedy zostanie udzielona bardziej szczegółowa odpowiedź
a odcinki z nagłówkiem „head report.txt” nic nie znaczą
how to make "nano report.txt" report and put it here, then a more detailed answer will be given
and episodes headed "head report.txt" mean nothing
СообщениеДобавлено: 24 июл 2020, 11:49
You are right. I was using the program for the first time.
I forgot that the head command only shows 10 lines :)
When I'm home, I'll test again.
So for the future, how does the memory count when they are on both sides of the card, eight on one and eight on the other?
СообщениеДобавлено: 24 июл 2020, 12:33
M1 and M508 - A1 HI(63:32)
M3 and M506 - A0 LO(31:0)
M8 and M504 - B1
M7 and M503 - B0
M6 and M502 - C1
M5 and M501 - C0
M4 and M505 - D1
M2 and M507 - D0
СообщениеДобавлено: 24 июл 2020, 19:26
Something went wrong :D
Is it the fault of the GPU itself or bad soldering?
SUBPART RANK0 RD ERR RANK0 WR ERR UNKNOWN ERR
FBIOA[ 31: 0] 0 1683032 0
FBIOA[ 63: 32] 0 1593231 0
FBIOB[ 31: 0] 0 1684981 0
FBIOB[ 63: 32] 0 1615035 0
FBIOC[ 31: 0] 0 1547868 0
FBIOC[ 63: 32] 0 1735637 0
FBIOD[ 31: 0] 0 1796984 0
FBIOD[ 63: 32] 0 1730810 0
СообщениеДобавлено: 24 июл 2020, 20:28
GPU reball - if it doesn’t help - GPU R.I.P.
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 04:42
black7705 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gtx 770 4gb palit jetstream
andrey89417
09 фев 2017, 09:32
andrey89417 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Palit GTX 770 4gb. Помогите опознать элемент
[ На страницу: 1, 2 ]
Allex99
32
7758
04 янв 2019, 15:49
Allex99 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gainward Gtx 770 4gb
Winsent Wega
19 дек 2018, 04:23
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte GTX 770 4Gb GV-N770OC-4GD Rev 2.0 Сильно раскаляется SMD
КомпБит
2943
01 июн 2020, 16:33
КомпБит Перейти к последнему сообщению
Сейчас этот форум просматривают: fred24, kolia1984, semmi32 и гости: 105
