Текущее время: 22 ноя 2024, 05:21
 Заголовок сообщения: component identification help
СообщениеДобавлено: 27 июл 2020, 06:41
save guru's, does anyone know what component this would be? I need to find the datasheet, he is responsible for the Vpex of a gtx1050ti asus
 Заголовок сообщения: Re: component identification help
СообщениеДобавлено: 27 июл 2020, 10:26
RT8809BGQW (08=)
RT7296FGJ8F (08=)
СообщениеДобавлено: 28 июл 2020, 06:10
thanks madking, I managed to make this Vpex and Vmem board, but Without Vgpu, could you help me find the possible fault, and what pins should I check on the PWM Up9501S?
some pins:
1 - 70mv
2 - 2.34v
3 - 76mv
4 - 50mv
5 - 0
6 - 2mv
7 - 0
8 - 0
12 - 1.12v
17 - 1v
18 - 5v
20 - 0
37 -12v
47 - 3.3v
48 - 3.3v
what else to check?
СообщениеДобавлено: 28 июл 2020, 10:20
TheMArcos писал(а):
3 - 76mv
EN - no normal
search 5pin logic ic
СообщениеДобавлено: 29 июл 2020, 08:36
madking писал(а):
TheMArcos wrote:
3 - 76mv
EN - no normal
sorry, I made a mess, in reality pin 2 has 76mv and pin 3 has 2.34V
СообщениеДобавлено: 31 июл 2020, 05:54
hi guys, up9501 datasheet that I found on the upi website, let me see if I understand ... vready and vrhot are signal outputs or signal inputs?
I still can't understand why I don't have Vgpu voltage, apparently all the components around the pwm are normal.
СообщениеДобавлено: 31 июл 2020, 11:42
outputs open drain since they use resistor to vcc and also arrows are pointing to outside
also check in pdf the enable voltage 2.4 seams strange value
СообщениеДобавлено: 02 авг 2020, 22:05
ilie321 писал(а):
Posted: 31 Jul 2020, 04:42
I didn’t find the pdf on google, these images I took from the upi website, I’ve already checked the entire enable line and I couldn’t notice anything unusual, I was looking at the image and I saw that there are pins TP (11) and TM (21) , should there be any tension on these pins? what is his function?
thanks for listening.
СообщениеДобавлено: 02 авг 2020, 22:54
here they are: Test Pin & Thermal Monitoring
СообщениеДобавлено: 03 авг 2020, 02:35
@Conqueror
do you have the complete pdf of this datasheet? if you have can you make me available?
graciously.
СообщениеДобавлено: 03 авг 2020, 06:10
datasheet
СообщениеДобавлено: 03 авг 2020, 23:18
This is NOT a up9501 datasheet, this is a uPi1608 datasheet - but it's similar as the uPi1608P by pin assignments. So one time we changed them well between ASUS Strix GTX950 & ASUS Dual GTX1060 ))))
up1608pq-ds-f0104.zip
СообщениеДобавлено: 14 авг 2022, 06:04
I also have this issues with uP95101P. The EN signal pin has no voltage. It is about 0.3V present. Did you solve the problem?
В этой теме нет новых непрочитанных сообщений. Asrock B75M - Need help with component identification
в форуме ASRock
latitude
24 окт 2016, 10:18
i001546 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sandisk Extreme 240GB SSD component identification
zoom21
01 дек 2015, 01:35
hamityanik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Sony Vaio SVT13137CXS (Mbx-265) Identification of component
в форуме Sony
abuholm
06 янв 2016, 21:34
wotanel Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. TOSHIBA C55-B (LA-B303P) Identification Of Component
в форуме Toshiba
abuholm
18 фев 2016, 14:52
abuholm Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Envy X360 (Wistron Laduree-SKY MB) Identification Of Component
abuholm
08 янв 2018, 22:28
9free_mind Перейти к последнему сообщению
Сейчас этот форум просматривают: SCIF и гости: 91
