Текущее время: 19 май 2024, 01:12
 Заголовок сообщения: use mats in card that the video, it is possible?
СообщениеДобавлено: 10 авг 2020, 19:12
is it possible to use MATS to evaluate a non-video card? I have a gigabyte gtx 970 that does not display, accessing via the processor's integrated video, it is recognized by the device manager and the GPU-z, however it does not show clocks or information about drivers and memories.
is there any way to do a scan via mats?
 Заголовок сообщения: Re: use mats in card that the video, it is possible?
СообщениеДобавлено: 10 авг 2020, 23:03
Asus GTX970
Mats 400
mats version 400.184. Testing GM204 with 20 MB of memory starting with 0 MB.
Read Error Count: 0
Write Error Count: 0
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0 0 0 0
FBIOA1 0 0 0
FBIOB0 0 0 0
FBIOB1 0 0 0
FBIOC0 0 0 0
FBIOC1 0 0 0
FBIOD0 0 0 0
FBIOD1 0 0 0
Failing Bits:
None
Error Code = 00000000 (OK)
---------- Добавлено спустя 13 минут: ----------
autotest mats 367
viewtopic.php?f=48&t=86101&start=60
"https://yadi.sk/d/hu0_AoW04DyIPQ поправил запуск mats -e 20"
СообщениеДобавлено: 11 авг 2020, 00:04
yes, of course.
Nevertheless, I'm using Mats on a motherboard without ANY integrated video - here viewtopic.php?f=48&t=96805&p=722215#p722215 you can translate & understand how to use mats in blind mode.
СообщениеДобавлено: 12 авг 2020, 16:14
Thanks madking And conqueror, I can't do it on the 970, the pc shuts down right away, as if I can't hear a video card, but when trying on a 1050ti it was running for a few minutes before shutting down and mine gave the following dignified:
should i assume the gpu died?
mats version 367.38. Testing GP107 with 20 MB of memory starting with 0 MB.
Errors found. Use -matsinfo for details.
This message will only appear once.
SUBPART RANK0 RD ERR RANK0 WR ERR UNKNOWN ERR
FBIOA[ 31: 0] 0 3948288 0
FBIOA[ 63: 32] 0 2550173 0
FBIOB[ 31: 0] 0 2638284 0
FBIOB[ 63: 32] 0 3948288 0
Rank 0 Failing bits:
A000 A001 A002 A003 A004 A005 A006 A007 A008 A009 A010 A011 A012 A013 A014 A015
A016 A017 A018 A019 A020 A021 A022 A023 A024 A025 A026 A027 A028 A029 A030 A031
A032 A033 A034 A035 A036 A037 A038 A039 A040 A041 A042 A043 A044 A045 A046 A047
A048 A049 A050 A051 A052 A053 A054 A055 A056 A057 A058 A059 A060 A061 A062 A063
B000 B001 B002 B003 B004 B005 B006 B007 B008 B009 B010 B011 B012 B013 B014 B015
B016 B017 B018 B019 B020 B021 B022 B023 B024 B025 B026 B027 B028 B029 B030 B031
B032 B033 B034 B035 B036 B037 B038 B039 B040 B041 B042 B043 B044 B045 B046 B047
B048 B049 B050 B051 B052 B053 B054 B055 B056 B057 B058 B059 B060 B061 B062 B063
Read Error Count: 0
Write Error Count: 13085033
СообщениеДобавлено: 28 авг 2020, 23:46
please give us more info: if
can the BIOS be readed from the card? could you write another BIOS (--protectoff, and -6 option next step)?
I think 80/20, because of if the card could be recognized via device manager - it must be seen via MATS, except of the BIOS problems (BIOS chip died or wrong BIOS were programmed)
В этой теме нет новых непрочитанных сообщений. Mods không nhận card ai có thể giúp tôi?
thanhnamvl86
13 ноя 2019, 13:09
virus-cyber Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2080Ti - possible to use unused memory Pad?
Assassin
14 сен 2020, 20:06
Assassin Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. is it possible to test the ps4 joystick without using the console (video game)?
eletmoraes
2370
30 окт 2022, 11:57
primalphoenix Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Mats tserverHello, does anyone know how to use these files?
azzed
07 фев 2023, 22:41
zaytsevphoto Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Monster P370EM (Clevo P370EM) Bios mod new video card add support
в форуме Clevo
bub2245
04 июл 2016, 18:24
bub2245 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 19
