Текущее время: 09 май 2024, 01:30
Часовой пояс: UTC + 4 часа
 Заголовок сообщения: EzBook 3 plus
СообщениеДобавлено: 14 авг 2020, 03:24
Hello,
Sorry I dont speak (nor write) russian.
I'm looking for the EzBook 3 Plus bios dump.
thank you for your help.
 ! Ciber SLasH писал(а):
Where indication of a platform?
link: >>> Ruled creations of a subject and definition of a platform of the laptop <<< oblige:
Requirements at creation of a new subject in the section on repair of laptops:
- provide the name of a platform of the device.
 Заголовок сообщения: Re: EzBook 3 plus
СообщениеДобавлено: 14 авг 2020, 16:41
Hello,
I did not read the forum rules carefully... thank you for not deleting my post.
My settings :
EZbook 3 Plus MB11 (Core M3-7Y30) with 128 Go SSD.
EJLNBJP01339
Since my bios is bricked I can tell the version.
I have seen this post and I'm interrested in downloading the bios...
viewtopic.php?f=251&t=100137
I will use CH341A programmer + SOIC8 SOP8 clip because the bios chip is 25Q64FVSIG. I can read write on it.
Please find attached more pictures which will tell more about the computer hopefully.
The computer get bricked when I tried to mod the bios with Aptio V AMI Firmware Update Utility + Intel ME System Tools v11.0 r1.
Thank you for whoever can provide me with the EZbook 3 Plus dump bios.
Regards
СообщениеДобавлено: 14 авг 2020, 16:51
See other side motherboard for detect platform.
СообщениеДобавлено: 14 авг 2020, 23:04
ok, thanks. I did not know this..
Posted after 1 hour 1 minute 12 seconds:
Hello again !
So here is the plateform :
SN : KBNP170404400019
S133KR120-K60B / 7Y30
I guess so ...
Thanks for your help.
СообщениеДобавлено: 15 авг 2020, 01:19
viewtopic.php?p=785890#p785890
СообщениеДобавлено: 15 авг 2020, 01:54
Hello,
Thank you for your help.
The thread you gave is about Teclast F6 Pro.
My computer is EzBook 3 Plus from Jumper.
Do you mean it is the same bios ?? is it because it is S133K rev 1.2 ?
I can't download yet so I can't test it.
Thank you in advance for your next reply.
Regards
СообщениеДобавлено: 15 авг 2020, 11:28
MAILED to the profile's email.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 15 авг 2020, 14:27
Hello,
Thank you so much RsM !!
It worked ! :bra_vo: :-) :ya_hoo_oo:
I have access to advanced menu too.
So much options but I did not change anything for the moment... Just trying if Windows is booting !
Thank you so much to everyone, especially RsM and Ciber Slash for your help !!!
Well now I have Teclast logo at boot ... not a big deal for me !!
This is how I did :
1) I received the Teclast F6 pro bios from Rsm by mail, saved it on my pc.
2) I used the CH341A programmer + SOP8 clip.
The big issue I had was the clipping was not good enough. I had a lot of write timeout failed although the chip detect was good but writing ...
After many attemps, I succeeded ... I did a "verify" from the software to check if the writing was good. I also checked with FlexHex software to compare the file provided by RsM and the one I saved from the chip after writing.
As I failed many times, I thought at some moment that my chip was faulty... but I tried more and succeeded... I nevertheless have bought the Winbond 25Q64FVSIG chip from Aliexpress just in case (I will reveive 5 of them in 2 weeks...).
This is my story !!!
Thanks again for this forum where I finally found some help !!
Regards and stay in good shape !!
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Jumper EZBook 3 Plus MB11 (S133K rev 1.2) BIOS dump
в форуме temp
Solderer
11
2649
24 авг 2020, 02:13
Solderer Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Jumper EZbook 2 дамп биоса
в форуме temp
igor28
14 окт 2017, 15:39
igor28 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. EZbook 3 pro он же YEPO 737A. Дампы BIOS
в форуме temp
Buhenwald
10 май 2018, 19:30
Buhenwald Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Jumper ezbook 3s
в форуме temp
renat
29 май 2018, 19:02
renat Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Jumper EzBook 3 Pro дамп флеша для ITE IT8987E-BXA
в форуме temp
JaguarX
02 апр 2019, 11:42
JaguarX Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 17
