Текущее время: 23 май 2024, 21:47
v1406
Заголовок сообщения: HP DV6 DEAD. QUANTA UT3 +3V/+5V OK Добавлено: 24 окт 2012, 19:22 |
Зарегистрирован: 24 окт 2012, 19:03 Наличности на руках: 55.00
Сообщения: 4 Откуда: DELHI
Dear All, Hello ! I am looking for a solution to a dead HP DV6-1235ee laptop with the following motherboard: Foxconn ML1-H94V-0E253117 168UT30001-094D quanta ut3 schematicsPU1:: ISL6262 PU2:: RT8206B PU3:: 8119LN PU4:: P2805 PU5:: ISL6251 som of the voltages i measured: DC jack = 19.93V +VA = 19.90V +VAD = 19.71V +VIN = 19.71 V +5VPCU = 5.25V +3VPCU = 3.45V +5VALW = 5.25V+12VALW = 8.70V ?? is it fine or is overloaded somewhere?Voltages At EC (KB3926)9, 22, 33, 67, 96, 111, 125 (3VPCU) = 3.4V 037 3920_RST# = 3.3V 127 LID_EC# = 3.25V 086 ACIN (ACIN_1) = 3.1V
019 NBSWON#1 =3.4 / 0V (before /after power button) 090 DNBSWON#1 3.4 / falls to 0.2V gradually rises to 0.5V and settles there95 RSMRST# 0V / 2.8 V only for half a second when you press the power button and then falls back to 0V
16 SUSC# 30 mV / 275mV again falls to 30 mV 06 SUSB# 30 mV / 550 mV again falls to 30 MvBIOS ( U22 sheet no 34) Pin no. name voltage 1 BIOS CS# 0.18 V isnt it too low?2 BIOS RD# 1.64 V 3 SPI 3P 3.4 V 4 VSS 0 V 5 BIOS WR# 0.25 V 6 SPI CLK 1.5 V 7 SPI 7P 3.4 V 8 VDD 3.4 V I would request you to kindly let me know what is going wrong which is preventing the rsmrst voltage from getting high. it tries to go high but falls down immediately to zero. I dont know what to do now. kindly show me the path to tread. thanks in advance. Вложение: HP DV6 DWG2JPG.jpg Вложение: HP DV6 BACKSIDE.jpg
Ciber SLasH
Заголовок сообщения: Re: HP DV6 DEAD. QUANTA UT3 +3V/+5V OK Добавлено: 24 окт 2012, 21:08 |
Модератор |
Зарегистрирован: 29 окт 2010, 00:27 Наличности на руках: 899.44
Сообщения: 7775 Откуда: Питер
v1406 писал(а): +12VALW = 8.70V ?? is it fine or is overloaded somewhere? Must be +12V - check PD12, PD13, PC62, PC63, PC70, PC71 v1406 писал(а): RSMRST# 0V / 2.8 V only for half a second when you press the power button and then falls back to 0V
Update bios on the programmator. If RSMRST# zero too - replace EC.
v1406
Заголовок сообщения: Re: HP DV6 DEAD. QUANTA UT3 +3V/+5V OK Добавлено: 25 окт 2012, 16:37 |
Dear Sir,
Thanks for your quick reply. I checked the components around PD12 and PD13 and they are fine. nothing wrong with them.
someone told me that this +12ALW supply can be low in the starting and will become +12V only after the laptop has booted up........ as per him this +12V can not be reason behind the DEAD laptop.
But, when i see page no 43 of the schematic, (Discharge/3VS5/5VS5) its hard to believe that +12V is not needed. Because MAINON, SUSON, S5_ON............. etc all are connected to this +12VALW. so, i am not sure about the role of +12VALW supply at startup.
Secondly, the rsmrst is 0V when the power button is not pressed. when the power button is pressed, rsmrst becomes 2.8V for half a second but then again falls down to 0V. I think there is some short etc due to which the supply shuts down itself as safety mechanism.
I request you to kindly guide me about the possible reason behind this .
Regarding the BIOS, the pin 1 is low. is it a corrupt BIOS or possibly bad EC.
Please guide about this so that i can reach the fault by measuring voltages stage wise...
many thanks for taking interest in my problem.... written not in your language....
really appreciate this.
thanks again
Ciber SLasH
Заголовок сообщения: Re: HP DV6 DEAD. QUANTA UT3 +3V/+5V OK Добавлено: 25 окт 2012, 21:04 |
Модератор |
v1406 писал(а): when the power button is pressed, rsmrst becomes 2.8V for half a second but then again falls down to 0V. First: replace EC and program bios.
Ciber SLasH
Заголовок сообщения: Re: HP DV6 DEAD. QUANTA UT3 +3V/+5V OK Добавлено: 26 окт 2012, 09:08 |
Модератор |
v1406 писал(а): sir before replacing EC i want to be doubly sure that that EC is faulty. If RSMRST# not work properly - is bad EC or bad SourthBridge. Therefore I offer program Bios, replace EC. Otherwise replace SourthBridge.
