Текущее время: 08 ноя 2026, 00:02
 Заголовок сообщения: Acer E5-573 UMA (da0zrtmb6d0 ) no power
СообщениеДобавлено: 29 окт 2020, 00:01
Hello everyone..
This laptop came with symptoms:
- no response to power button on battery
- when AC adapter is connected, charge and power leds comes on then power led goes off after 1 second while charge still on
- no response to power button with AC adapter connected
I've tried removing and reconnecting AC adapter for multiple times and the board started, it happened only for one time
removed the board and start checking and tracing the problem,3.3v is ok at the power button, +3VPCU is on but found that SPI GD25B64 has 0v on pin 8 with no shorts to ground (comes from +3v_s5), reconnecting AC adapter rises +3v_s5 for couple of seconds then it drops to 0v..
removed GD25B64 and +3v_s5 rises and keeps on but no power led, replaced with new flashed chip and it behaves the same, +3v_s5 rise then fall, this is where I've noticed that power led stopped working, soldered the original bios chip but power led stopped behaving like it was before ..
traced down +3v_s5 to find that it's enabled by S5D signal by S5_ON signal and both are 0v, reconnecting AC adapter and S5_ON/S5D comes on for couple of seconds then goes off..
tried replacing PU4 and PQ1,PQ2,PQ3,PQ4,PQ5,PQ6,PQ8 but nothing changed..
found that SYS_SHDN# is always high, is that normal ?
Where should I dig ?
removing PR1,PR3,PR16 and PQ3 should bring S5D as always live with all driven +3v_s5 and +5v_s5 and +1.05v_s5 with no need to S5_ON signal, is that correct ? is it a good idea to try ?
edit: replaced RTC Clock Y2 and AS393MTR-E1 PU6, tried both GD (originally installed on board) and Winbond (used in schematics) BIOS chips,,,, no avail
 Заголовок сообщения: Re: Acer E5-573 UMA (da0zrtmb6d0 ) no power
СообщениеДобавлено: 04 ноя 2020, 04:13
Problem was a bad KBC, I don't have a programmer and no identical replacement found..
Laptop given without repair..
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer E5-573 (DA0ZRTMB6D0) Не включается
[ На страницу: 1, 2 ]
Sus256
55
16795
21 окт 2017, 18:18
Sus256 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire E5-573 (DA0ZRTMB6D0) проблема с дискретным видео
Koe
08 янв 2018, 01:10
Koe Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Acer Aspire E5-573-38KH (DA0ZRTMB6D0, REV:D, ZRT) Постоянная загрузка по LAN в первую очередь
overmax
23 дек 2021, 18:38
ger1977 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. aspire e5-573 (da0zrtmb6d0 rev d) включается только через 10 минут после перезагрузки
Muxa25
07 фев 2019, 11:39
Muxa25 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. E5-573-3848 (DA0ZRTMB6D0 Rev: D) Не включается.
rudikdmb11
22 фев 2019, 07:25
Azazehl Перейти к последнему сообщению
Сейчас этот форум просматривают: virusss и гости: 57
