Текущее время: 16 июн 2024, 15:04
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 01 ноя 2020, 11:45 |
Зарегистрирован: 27 фев 2020, 13:07 Наличности на руках: 304.76
Сообщения: 296 Откуда: romania
OK here you go 16gb image with all 3 option dmgg, ts... and mats: https://drive.google.com/file/d/1bMUCM1 ... sp=sharingto make this i removed some files used for other test except memory test so we can have only 16gb usb used; if you restore on hdd which is way faster than usb you need to create a 16gb partition ntfs and restore the image with disk genius ; if you use usb at list 16gb size restore directly(or format first) with disk genius also; after this is done restore boot with the boot-repair-disk-64bit.iso (you can put this image with Rufus on a usb drive ) https://sourceforge.net/projects/boot-repair-cd/then you need to open disk genius browse the created usb key or hdd to /boot/grub/ right click on grub.cfg -delete file directly then drag and drop the attached grub.cfg in that place and copy it Вложение: grub.zip unzip first :) now you can boot and you have 3 options :) test them and enjoy -1 is for dmgg.py script and it is working as before; example: 'cd /home/sh' then: python3 ./dmgg.py c0000000 1 16 (this works directly with the card if it is giving image but you can use the test card as second card in system and display image with a good working card; sometimes after few minutes the unused card will stop fans and is disabled so if you want to test again you need power off and start again) -2 it is for ts.... and it is working same as Chinese instructions 'cd /home/sh' .... -3 is for mats . it will start test with 400.184 but you can use 'ls' command and then select the version you want if for some unknown reason :) you want to go in graphical mode for first 2 option after enter in console mode just type 'service lightdm restart' and wait like 20-30secs
boblek
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 01 ноя 2020, 15:35 |
Зарегистрирован: 18 окт 2020, 22:05 Наличности на руках: 120.09
Сообщения: 56 Откуда: Москва
ilie321 писал(а): OK here you go 16gb image with all 3 option dmgg, ts... and mats: https://drive.google.com/file/d/1bMUCM1 ... sp=sharing to make this i removed some files used for other test except memory test so we can have only 16gb usb used; if you restore on hdd which is way faster than usb you need to create a 16gb partition ntfs and restore the image with disk genius ; if you use usb at list 16gb size restore directly(or format first) with disk genius also; after this is done restore boot with the boot-repair-disk-64bit.iso (you can put this image with Rufus on a usb drive ) https://sourceforge.net/projects/boot-repair-cd/then you need to open disk genius browse the created usb key or hdd to /boot/grub/ right click on grub.cfg -delete file directly then drag and drop the attached grub.cfg in that place and copy it Вложение: grub.zip [2.02 КБ] Скачиваний: 3 unzip first :) now you can boot and you have 3 options :) test them and enjoy -1 is for dmgg.py script and it is working as before; example: 'cd /home/sh' then: python3 ./dmgg.py c0000000 1 16 (this works directly with the card if it is giving image but you can use the test card as second card in system and display image with a good working card; sometimes after few minutes the unused card will stop fans and is disabled so if you want to test again you need power off and start again) -2 it is for ts.... and it is working same as Chinese instructions 'cd /home/sh' .... -3 is for mats . it will start test with 400.184 but you can use 'ls' command and then select the version you want if for some unknown reason :) you want to go in graphical mode for first 2 option after enter in console mode just type 'service lightdm restart' and wait like 20-30secs WOW! ---------- Добавлено спустя 1 час 47 минут 12 секунд: ---------- ilie321 писал(а): OK here you go You're a genius)
ilie321
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 06:41 |
You need second usb for the boot repair utility With disk genius use option restore partition from image file. You need a 16gb partition formatted ntfs. Grub https://drive.google.com/file/d/19xxt2I ... p=drivesdkAfter some tests with gas_man i need to update some files because for newer ati cards it is not working OK
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 07:12 |
Зарегистрирован: 31 янв 2019, 21:09 Наличности на руках: 390.39
Сообщения: 305 Откуда: Чебоксары
darker123 писал(а): boot-repair-disk-64bit.iso boot-repair-disk-64bit.iso ставиться с помощью RUFUS на отдельную флешку - эта флешка является восстановителем загрузчика. т.е. образ раздела USB1604.pmf распаковывается с помощью disk genius (обязательно CN или с официального сайта EN) А с помощью восстановителем загрузчика boot-repair-disk-64bit.iso восстанавливаем загрузку этого нового диска или флешки с распакованным образом раздела 1604.pmf
Последний раз редактировалось Gas_man 02 ноя 2020, 11:05, всего редактировалось 1 раз.
boblek
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 12:55 |
Gas_man писал(а): Надо проверять. Правильно-ли тестируется DMGG. надо статистику. Скорее всего нужно обновить подгружаемые драйвера Вроде все ок даже без драйверов amdgpu-install. Видимо хватает те что в ядре.
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 13:12 |
boblek писал(а): Вроде все ок даже без драйверов amdgpu-install. Видимо хватает те что в ядре. Вот у меня НЕТ - что-то не так. DMGG - показывает 7 и 8 банку TSERVER - Показывает кала А - 1 - 2 банка
boblek
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 19:40 |
Gas_man писал(а): DMGG - показывает 7 и 8 банку а менял e0000000 и тд?
boblek
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 20:32 |
ilie321 писал(а): You need second usb for the boot repair utility With disk genius use option restore partition from image file. You need a 16gb partition formatted ntfs. Grub https://drive.google.com/file/d/19xxt2I ... p=drivesdk After some tests with gas_man i need to update some files because for newer ati cards it is not working OK and for R9 290 cards in your build there is no сhinese test?
boblek
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 20:34 |
kripto.emre писал(а): hı friend if you have time Can you take a video to create usb What's the problem? at what stage? ---------- Добавлено спустя 4 минуты 36 секунд: ---------- serega2014Mog писал(а): с созданием флешки разобрался все работает хорошо только разницы между 1 и 2 пунктом не заметил и через 1 и через 2 пункт можно тестировать как и через скрипт так и через кит софт для амд. Может есть какая разница я так и не понял Мне кажется разницы нет, потому что я глядел груб меню там все одинаковое. Сделано чисто для юзабилити я думаю)
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 02 ноя 2020, 21:53 |
serega2014Mog писал(а): с созданием флешки разобрался все работает хорошо только разницы между 1 и 2 пунктом не заметил и через 1 и через 2 пункт можно тестировать как и через скрипт так и через кит софт для амд. Может есть какая разница я так и не понял Как мне объяснил ilie321 - в первом и во втором варианте подгружаются разные драйвера. ---------- Добавлено спустя 5 минут 9 секунд: ---------- boblek писал(а): а менял e0000000 и тд? Да, я сначала определил через "lspci -v" к какому адресу нужно обращаться. Так же пробовал сдвигать на 16 мб (e1000000) и на 32 мб (e2000000) начало теста - везде 7 и 8 банка и это не в первый раз. Ранее такие же показания были когда только вышел этот тест - dmgg.py P.S. донорских чипов Hynix для 8 Гб карт пока нет. Если у кого есть доноры на память - выкуплю ))) Может кому пригодиться:
anton127
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 03 ноя 2020, 05:51 |
Зарегистрирован: 29 июн 2018, 10:00 Наличности на руках: 450.22
Сообщения: 370 Откуда: Урал
Gas_man писал(а): Ранее такие же показания были когда только вышел этот тест - dmgg.py P.S. донорских чипов Hynix для 8 Гб карт пока нет. Если у кого есть доноры на память - выкуплю ))) Может таки поднять эти 2 несчастных чипа да отреболить? Или пока не сталкивались с окислами? По моему опыту в проблемах памяти окислы под памятью гораздо чаще встречается, чем битая банка.
boblek
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 03 ноя 2020, 10:51 |
Насчет 7 и 8 банки да, у меня это ошибка на двух картах появилась, возможно совпадения. Перепаяю посмотрим, что изменится. ---------- Добавлено спустя 38 секунд: ---------- Gas_man писал(а): Да, я сначала определил через "lspci -v" к какому адресу нужно обращаться. Так же пробовал сдвигать на 16 мб (e1000000) и на 32 мб (e2000000) начало теста - везде 7 и 8 банка и это не в первый раз. Ранее такие же показания были когда только вышел этот тест - dmgg.py P.S. донорских чипов Hynix для 8 Гб карт пока нет. Если у кого есть доноры на память - выкуплю ))) А китайский тест пишет мне про микрокод.
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 03 ноя 2020, 11:07 |
boblek писал(а): А китайский тест пишет мне про микрокод. У меня ошибка с микрокодом на других картах - там я грешу на ГПУ. (эти карты у меня в винде не показывают изображение. А если второй картой, то всегда ошибка 43 - прошивку менял на сток, патчил - не помогает. boblek писал(а): Перепаяю посмотрим, что изменится. Давай-давай. Интересно знать результаты
uncledim
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 04 ноя 2020, 16:09 |
Зарегистрирован: 22 дек 2016, 12:07 Наличности на руках: 1,135.36
Сообщения: 1102 Откуда: Moscow
12ozMouse писал(а): почему может не работать комбинация клавиш? в свежих образах archlinux не работает. Можно сократить вывод, поставив фильтр по VID (к lspci -v добавьте -d 1002:)
boblek
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 04 ноя 2020, 17:05 |
12ozMouse писал(а): Подскажите плиз знающие люди... Решил заюзать скрипт dmgg.. в общем все ок, но вот адрес определить не удается. т.е. не скроллит по Shift+pgup/pgdown. Почему может не работать? клавы две попробовал. что я делаю не так? Но при этом пробую e0000000 d0000000 показывает или два канала проблемных или все вообще. пробовал и другие наугад (b, с, F) - та же песня. при том на рабочей 470(3 вечера игрался на ней часов по 3-4 без проблем) - тоже ошибки) в общем чисто ламерский вопрос ))) как сроллить и почему может не работать комбинация клавиш? капс и намлок пробовал отключать/включать и т.д. Ну у тебя видимо дистрибутив такой. Пиши lspci -v | less и будет тебе счастье.
12ozMouse
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 05 ноя 2020, 02:49 |
uncledim писал(а): (к lspci -v добавьте -d 1002:) написал lspci -v -d 1002 - бороду какую-то выдало))) надо изучить вопрос boblek писал(а): Ну у тебя видимо дистрибутив такой. Пиши lspci -v | less и будет тебе счастье заколосилось) скроллит даже стрелочками после такой команды))) а как вернуться потом и продолжить команды? мне пришлось ребутнуть ))) ругается вот так: chip 3 and/or 4 is faulty at adress: 0 chip 1 and/or 2 is faulty at adress: 512 chip 5 and/or 6 is faulty at adress: 1024 chip 7 and/or 8 is faulty at adress: 1536 т.е. вся память у меня мертвая? и видак работает))) попробую его потестить еще с пристрастием. я его воткнул для понимания как должно быть, когда все ок, а оказалось что не совсем все ок))) до него на 470 от xfx были артефакты вертикальные полосы. справа крайний и от центра экрана влево. Заменил 2 банки с такой же карты, но с мертвым чипом. артефакты теперь фантомные по всему экрану и ругается скрипт как раз на те банки, которые менял(D. 7 и 8). может усадил плохо. разбираюсь. нуб совсем пока в видаках
Последний раз редактировалось 12ozMouse 05 ноя 2020, 04:29, всего редактировалось 1 раз.
pEEp
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 05 ноя 2020, 04:19 |
Зарегистрирован: 25 сен 2018, 20:41 Наличности на руках: 710.36
Сообщения: 1115 Откуда: Севастополь
Gas_man писал(а): DMGG - показывает 7 и 8 банку TSERVER - Показывает кала А - 1 - 2 банка Личная статистика показывает, что в 70% случаев виноват D-channel, т.е. DMGG не ошибается. Из оставшихся 30% львиную долю забирает C-channel. B и А - практически всегда целые, за редким исключением. boblek писал(а): Насчет 7 и 8 банки да, у меня это ошибка на двух картах появилась, возможно совпадения. Перепаяю посмотрим, что изменится. Изменится... Должно измениться!
