Текущее время: 29 ноя 2026, 16:49
 Заголовок сообщения: Sony bravia KDL-48W590B blinking 8 time red light
СообщениеДобавлено: 09 ноя 2020, 22:11
Заблокирован
Hi i have problem with tv i doubt in firmware i download from sony site then format usb fat32 after that blue light is on and on screen circle doing proces of updating..I wait one hour but same..Maybe some one has firmware back up?
 Заголовок сообщения: Re: Sony bravia KDL-48W590B blinking 8 time red light
СообщениеДобавлено: 10 ноя 2020, 11:51
https://www.sony.com/electronics/suppor ... s/00086168
СообщениеДобавлено: 10 ноя 2020, 13:31
Заблокирован
I tried everything but same:(
СообщениеДобавлено: 10 ноя 2020, 14:46
https://www.sony.com/electronics/suppor ... s/W0011108
Expand [+] and try
"Check the Firmware Version of the TV"
"USB Installation Instructions"
https://www.sony.co.th/en/electronics/s ... s/00011057
https://www.sony.co.th/en/electronics/s ... s/00032065
СообщениеДобавлено: 10 ноя 2020, 16:11
Заблокирован
no at all does not do nothing ..
СообщениеДобавлено: 10 ноя 2020, 16:16
Are you sure that the electronic components is working properly, for example ESR of capacitors are normal?
Try temporarily like this:
1) Disconnect the TV from the Internet (change the password for wi-fi / pull out the cord)
2) Unplug from the outlet, take out the antenna cable, wait 5 minutes
3) We turn on the TV and the antenna, DO NOT CONNECT TO INTERNET
СообщениеДобавлено: 10 ноя 2020, 18:10
Заблокирован
Only came on screen circle nothing else no menu or etc..I format flash in root i did firmware from oficial site sony ..After turn on light is blue but usb doesnot doing nothing no update ..
СообщениеДобавлено: 10 ноя 2020, 20:01
https://www.sony.co.th/en/electronics/s ... s/00032661
https://www.sony.co.th/en/electronics/s ... s/00023479
СообщениеДобавлено: 10 ноя 2020, 20:24
Заблокирован
Thanks for answer ..I tried all option non of them does not do job..Only on screen circle spining..I test all voltage everything is corect instead five coil there is not votage at all..This is for processor power..
СообщениеДобавлено: 10 ноя 2020, 23:43
You have service manual and schematic diagram ?
СообщениеДобавлено: 11 ноя 2020, 10:15
Заблокирован
No i could not find..
СообщениеДобавлено: 11 ноя 2020, 11:22
https://elektrotanya.com/sony_kdl-40w59 ... nload.html
http://www.remserv.ru/cgi/download/SONY_RB2G
СообщениеДобавлено: 11 ноя 2020, 20:37
Заблокирован
Is possible program nand flash by ch31a programmer some wire connection? ,I dont have adapter for nand ..Maybe some other option?
СообщениеДобавлено: 23 ноя 2020, 13:02
NO
Вас обманули,это Шанхайский барс
Телефон вацап,вайбер, телеграмм 8914 577 2911 Борис
Помогу удалённо отремонтировать тв и другое
В этой теме нет новых непрочитанных сообщений. casper g870 wite led 3 time blinking
в форуме Ремонт ноутбуков | Laptop Repair
serwanjaf7
17 дек 2025, 20:01
В этой теме нет новых непрочитанных сообщений. Apple time capsule A1470 (A1470) нужна прошивка для Apple time capsule A1470
в форуме Apple
Adleon
11 янв 2019, 12:38
Adleon Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus x79 sabertooth cpu red blinking
в форуме Asus
myth77
18 апр 2017, 03:25
gitas Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Телевизор sony bravia android при включении срабатывает защита.
Lenovs
14
4238
18 дек 2019, 14:07
Aleksey_56 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony bravia kdl32r423a
putnikk8@gmail.com
09 янв 2023, 21:31
putnikk8@gmail.com Перейти к последнему сообщению
