Текущее время: 21 май 2024, 02:43
hashwood
Заголовок сообщения: Aorus 1080TI + Zotac 1080TI please help Добавлено: 17 ноя 2020, 19:30 |
Зарегистрирован: 28 окт 2020, 18:27 Наличности на руках: 453.47
Сообщения: 204 Откуда: romania
Hello, I am new in GPU repair, I work on DSLR and Lenses. But I have multimeter, SMD rework, BGA rework and some electronics experience. I have two boards and I don't know if they have bad GPU, so they are useless. 1st. Zotac mini 1080TI (picture with voltage and impedance on all coils) GPU was reballed, GPU heats up but not like normal working cards more slower, it shows in device manager, but gives blue screen when installing drivers. What's strange is that all mosfet drivers gets relatively hot: uP1959 . Here is a picture with Thermal camera with the mosfter drivers: 2nd: Aorus 1080TI (picture with voltage and impedance on all coils) GPU heats up but very very slow, not showing in device manager. But voltages are ok. Can someone please help me.
BrasilBack
Заголовок сообщения: Re: Aorus 1080TI + Zotac 1080TI please help Добавлено: 18 ноя 2020, 14:44 |
Сообщения: 304 Откуда: Санкт-Петербург
Hi hashwood писал(а): Zotac mini 1080TI When booting with this card, does your screen power up and go blank after approx 30 seconds? hashwood писал(а): Aorus 1080TI Are you sure about 64 ohms at 12V rail? It seems not to be ok))
hashwood
Заголовок сообщения: Re: Aorus 1080TI + Zotac 1080TI please help Добавлено: 18 ноя 2020, 15:21 |
Thanks for your reply. No, Zotac doesn't power the monitor at all. Tested now, even after 120 seconds monitor remains off. Aorus 12V rail is not 64Ohms (my mistake), it's 2.9K Tested the signal lines, and pin 3 doesn't seem to be connected. Pin 4 shows 63K . I will try reflow, and if not will take the GPU down, and measure. Posted after 1 hour 2 minutes 48 seconds:took aorus chip down, it seems that pin 3 is not connected. I guess that chip is disconnected inside :( Posted after 8 minutes 40 seconds:But can you please tell me what does it mean if it powers on the monitor after 30 seconds?
BrasilBack
Заголовок сообщения: Re: Aorus 1080TI + Zotac 1080TI please help Добавлено: 18 ноя 2020, 23:14 |
hashwood писал(а): what this means? It points to memory side problems. Can be GPU memory controller fault, GPU doesnt fit right after reball, VMEM without a specified range, or memory failure. hashwood писал(а): segmentation fault Tested card should be first in system with monitor connected to it. There will be a black screen, just select boot device with MATS and wait for a few minutes. Test result will be at report.txt hashwood писал(а): chip is disconnected inside There is one chance remaining for this GPU-it should work with AMD platform, but at x8 speed. hashwood писал(а): Are they compatible ? They have different memory channels disabled, compare the boards. Resolder one memory module to right position. No other actions required.
BrasilBack
Заголовок сообщения: Re: Aorus 1080TI + Zotac 1080TI please help Добавлено: 19 ноя 2020, 14:22 |
hashwood писал(а): Can I disable F1 in bios, or exchange with another? No way to do this. Try to resolder a GPU. hashwood писал(а): should I take out the other This isnt necessary
maplesyrup
Заголовок сообщения: Re: Aorus 1080TI + Zotac 1080TI please help Добавлено: 27 апр 2022, 05:27 |
Зарегистрирован: 22 апр 2022, 06:51 Наличности на руках: 107.18
Сообщения: 36 Откуда: Canada
BrasilBack писал(а): There is one chance remaining for this GPU-it should work with AMD platform, but at x8 speed. my friends, I hate to resurrect a zombie, but can anyone explain this further? A nvidia GPU on AMD platform confuses me! Surely he means a NVIDIA card on an AMD motherboard & CPU, correct? And not an Nvidia chip on an AMD graphics card?
acidwise
Заголовок сообщения: Re: Aorus 1080TI + Zotac 1080TI please help Добавлено: 27 апр 2022, 10:09 |
Зарегистрирован: 11 ноя 2020, 16:05 Наличности на руках: 44.16
Сообщения: 52 Откуда: из дома
maplesyrup писал(а): Surely he means a NVIDIA card on an AMD motherboard & CPU, correct Yes. Basically, for Intel platform the first PCIe lane of the GPU must be functional, otherwise the card will not be recognized. This does not hold for AMD. Check also this thread: vlab.su/viewtopic.php?f=48&t=102422
