Текущее время: 29 ноя 2026, 06:36
 Заголовок сообщения: HP 15-da0007ne (EPK50 LA-G07BP) no power / components missing
СообщениеДобавлено: 12 янв 2021, 23:58
Hi everyone..
This laptop came with no power at all, no +19v on the input, someone was missing with the input Fets, PQB12 & PQB13 aren't on the board, according to the images from the forum there should be EMB12N03 which I don't have so I've used P0903BEA, it doesn't work...
There's 19v on the drain of PQB11, at the source it jumps 0v~0.7v, the gate also jumps 0v~0.7v, I've noticed they've installed AON6426 on PQB11, according to the images it should be EMB04N03 which also I don't have... replaced with 4955N and it's still won't work..
Replaced PQB12 & PQB13 with B20N03, still won't work...
There's no short on the 19v or anywhere else..
Could it be an incompatible Fets or they should start ? if they're not please give some equivalent
 Заголовок сообщения: Re: HP 15-da0007ne (EPK50 LA-G07BP) no power / components missing
СообщениеДобавлено: 13 янв 2021, 22:55
I've found the gate of PQB11 is connected to PUB1 (BQ25A), replacing the charger didn't help..
I've took a tip from the forum to use the lowest possible RDSon so I've replaced PQB11 with MDU2653 (Rdson 3.5mohm) and still nothing, removed PQB12 and +19v appeared on PQB11's source with 25.5v on it's gate..
resistance at PQB12's drain (@PRB1) is 182 ohm ???
resistance at PQB13's drain (@PRB11) is 159k ohm
replaced PUV1 (RT8812A) didn't help also... where to dig ?
edit: using B20N03 on PQB12 & PQB13
СообщениеДобавлено: 01 фев 2021, 12:26
Oops..
Well i was wrong, there is a short on 19v
:ne_ne_ne:
Well, I've found a shorted dual-mosfet PQM1 marked "K4 AUB" (pe642dt it is), removed it and 19v appears across the board :co_ol:
PLM1 & PLA1 have very low resistance, PLM1 1.2 ohm, PLA1 1.0 ohm (reference is 0.7 ohm), and since there's no schematic for this board it appears that PLM1 is powering RAM and PLA1 goes to the CPU "SR3LC"
I don't have a similar mosfet, I've tried the much lower power AON7934 but it fried immediately..
injected 1.2v in PLM1, 2.1A consumed and nothing heats up, barely the CPU warms
injected 1.0v in PLA1, 4.1A consumed and nothing heats up, barely the CPU warms
is it normal resistance for SR3LC chips or I have a dead memory controller here ? :sh_ok:
СообщениеДобавлено: 25 фев 2021, 03:27
No answer found..
I believe the memory controller is shorted in the cpu, will close this topic..
Thank you
В этой теме нет новых непрочитанных сообщений. Toshiba battery (PA5109U-1BRS) missing components
в форуме Toshiba
cov
31 окт 2017, 17:27
cov Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP Pavilion 15t-au000 (DAG34AMB6D0 REV D) Missing components
bridx
31 июл 2017, 19:00
tamogavka Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo yoga 500-14ibd ( LT41 MB 14217-1M) components missing
vortex252
11 сен 2017, 17:34
next6 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus Rampage IV Extreme missing components
в форуме Asus
kodreanu
02 ноя 2018, 03:22
kodreanu Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 980 help identify missing components!
EYES
17 фев 2021, 19:55
EYES Перейти к последнему сообщению
Сейчас этот форум просматривают: Yandex [BOT] и гости: 185
