Заголовок сообщения: Dell Inspiron N4010 (Intel) Need to change Discrete to UMA
Добавлено: 29 янв 2021, 11:25
Зарегистрирован: 25 сен 2018, 18:24 Наличности на руках: 8.00 Сообщения: 22 Откуда: Myanmar
Model : Dell Inspiron N4010 Board id : DAUM8CMB8C0 Rev:C
Laptop problem is discrete Graphic Chip. Sometimes no display and sometimes open, but when windows load it's only show gray screen and stop. When i reflow GPU, it's open normal for a while. But after a few minutes, it's happen again. Can i change this model from discrete to uma? I already try these things,
1. Remove PL6 2. Switch R119 to R112 3. Flash BIOS & EC from UMA only model.
When i try to do step 1, 2, 3 - laptop can't switch on.
MoneyBot
MoneyBot
Powerman
Заголовок сообщения: Re: Dell Inspiron N4010 (Intel) Need to change Discrete to UMA
