Текущее время: 29 ноя 2026, 17:08
 Заголовок сообщения: Gtx 980ti evga hybrid burned elements smd
СообщениеДобавлено: 15 фев 2021, 23:42
Hello guys I have 980ti with burned elements, could someone send photo of that burned area? Or someone tell that elements or send scheme. Thank you brothers!
 Заголовок сообщения: Re: Gtx 980ti evga hybrid burned elements smd
СообщениеДобавлено: 16 фев 2021, 00:01
p-mosfet, like q501
СообщениеДобавлено: 16 фев 2021, 07:23
Ok thank you, what could cause that problem? Is that 12v line?
СообщениеДобавлено: 16 фев 2021, 11:24
this is a steering cirсuit. burn is not a rare malfunction. perhaps due to an incorrect time delay when opening the transistors, a counter current occurs and one of the mosfets burns out.
СообщениеДобавлено: 16 фев 2021, 20:01
Okey i have a lot of that mosfets, but PCB is too damaged to put it back only, i think that q501 is fine. I don't know where is the gate for that q502 cause is burned and around q502 in red circle is missing one of the resistors and it don't have traces to solder. Source and drain for mosfet is easy to rebuild but that gate and that resistors. Also I don't know their values and value of c501. Could someone help?
And when I looked more in PCB there was no q532 and capacitor and resistor i soldered 7002k but I don't know I'm right and dont know values of capacitor and resistor.
Thank you guys, I want very much that card because it has nice cooling system and it's looks great :)
СообщениеДобавлено: 17 фев 2021, 03:12
I think that is 12v line so guys, can i bypass that mosfets? just straight connect 12v directly
В этой теме нет новых непрочитанных сообщений. Gtx 1070 evga vmem burned
xxkachellxx
06 апр 2021, 12:40
xxkachellxx Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. EVGA GeForce GTX TITAN X HYBRID ищется BIOS !!!
Вадимчик
2772
13 янв 2019, 00:30
Вадимчик Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. EVGA 980TI CLASSFIED
sinukov_formoza
11 июн 2018, 23:29
sinukov_formoza Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. EVGA 980ti. Прогорела фаза. Как в Биосе понизить частоты,TDP.
molle
01 мар 2019, 21:54
В этой теме нет новых непрочитанных сообщений. Looking for bios mod 980ti EVGA
menzy
2115
07 июн 2020, 15:42
Сейчас этот форум просматривают: Google [Bot], psc_007, ruzalit и гости: 117
