Текущее время: 21 ноя 2024, 22:06
 Заголовок сообщения: Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion. фанспины! без видео, без звонка, без коррозии
СообщениеДобавлено: 09 мар 2021, 15:02
recently they brought me this mac, and it turns on it does the reset and then works with full fan and no chime and no video also no sign of corrosion in the board, any idea?
Недавно они принесли мне этот Mac, и он включается, он выполняет сброс, а затем работает с полным вентилятором, без звука и видео, а также без признаков коррозии на плате, есть идеи?
 Заголовок сообщения: Re: Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion. фанспины! без видео, без звонка, без корроз
СообщениеДобавлено: 09 мар 2021, 16:44
Here is an idea:
Find an experienced technician with appropriate tools, spares and knowledge.
He will bring this A1466 to life for a fair amount of money.
Sticking Feathers Up your Butt Does Not Make You A Chicken.
(c) Tyler Durden
СообщениеДобавлено: 09 мар 2021, 17:39
High fan spinning - usually result of one or more sensors faulting.
- LIO-board with flexcable replacement,
- trackpad with flexcable replacement,
- battery replacement,
- SMC reballing,
No image - be sure, if realy no image or no BKLT?
Do You have any image at external miniDP port?
It's possible, that screen eDP cable is damaged.
No chime - flexcable and connectors from MLB to LIO-board was damaged, or no 5V_S4/1V5_S0SW_AUDIO.
If You have spare parts - verify integrity of flexcable and it's connectors at MLB and LIO.
At 11 an 13 pins is placed SMBUS for FinStack thermal sensor,soldered at LIO board.
СообщениеДобавлено: 10 мар 2021, 13:00
- SMC reballing,
hello there, i have a donor a1466 and i allready checked lcd panel + io cable i tried also to external monitor with mini display port and nothing, i did all the power rail measurements below :
PPBUS_G3H 8.56v
PPBUS_S5_HS_COMPUTING_ISNS 8.55v
PPBUS_S5_HS_OTHER_ISNS 8.55v
PPDCIN_G3H_ISOL 14.94v
PPDCIN_G3H 14.94v
PP3V42_G3H 3.41v
PPVRTC_G3H 3.31v
PP5V_S5 5.08v
PP5V_S4RS3 5.08v
PP5V_S0 5.08v
PP3V3_S5 3.31v
PP3V3_S4 3.31v
PP3V3_SUS 3.31v
PP3V3_S3 3.31v
PP3V3_S0 3.31v
PP3V3_S4SW_SNS 3.31v
PP3V3_S0SW_SSD 3.32v
PP3V3_S4_TBTAPWR 3.31v
PP1V8_S3 1.78v
PP1V2_S3 1.19v
PP1V05_SUS 1.04v
PP1V5_S0 1.49v
PP0V6_S0_DDRVTT 0.59v
PP1V05_S0 1.04v
PP1V05_S0SW_PCH_HSIO 1.03v
PPHV_S0SW_LCDBKLT 0v
PP15V_TBT 0v
PP3V3_TBTLC 3.30v
PP1V05_TBTCIO 0.98v
PPVCC_S0_CPU 1.79v
Posted after 2 hours 8 minutes 2 seconds:
Re: Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion. фанспины! без видео, без звонка, без коррозии
i just noticed blown F7700, i replaced and checked with my donor panel still nothing, customer said lcd was flickering and for days and suddenly black screen, then it give the macbook to 2 different service stores, after that she brought it to me i also noticed that someone did rework on cpu it has flux around it and the protective black film burned, so i figured out that , from begining the problem was on lcd panel and F7700 fuse, then the guy that reworked the cpu damaged it, and the mac stopped working. Topic Closed thanks for the help.
В этой теме нет новых непрочитанных сообщений. Α1466 (820-00165-02) No fanspin,doesnt turn on
в форуме Apple
kosmo555
09 ноя 2020, 18:54
andriyd1 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro a1278 ((820-2936-B)) POST проходит,мелодия chime играет и на этом тишина
в форуме Apple
Kilowatt
23 фев 2015, 10:34
Frozen Blade Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. A1466 (820-00165-a ) Замена 820-00165-a на 820-3437-b возможна?
в форуме Apple
vitas-iv
11
2895
25 июн 2022, 15:51
vitas-iv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo S820 выключается при поступлении звонка. Дисплей в полоску.
в форуме Lenovo
pro100susanin
3638
18 фев 2019, 17:42
satoshi Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS X415J (X415JA R4.2) Повреждения от коррозии, отсутствующие SMD-компоненты
RandomR
30 окт 2024, 17:30
RandomR Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 41
