Текущее время: 22 ноя 2024, 07:57
 Заголовок сообщения: RTX 2080 tracing disconnected pad under memory
СообщениеДобавлено: 12 мар 2021, 20:54
Hi all
First of all am sorry for posting in english in a russian forum but this forum is the only forum with such knowlage
I have asus rtx 2080 dual 8 gb with error on fbioc0 i replaced the module but the error remains now i removed the memory module and found a pad DQ1_a does not have a resistance to ground i removed the gpu and its not connected to any pin
If some knows where this pin is located under the gpu
Or if there is a schematic diagram of gpu pins it would be highly appreciated
Thanks in advance and best regards
 Заголовок сообщения: Re: RTX 2080 tracing disconnected pad under memory
СообщениеДобавлено: 13 мар 2021, 13:49
kindly any one knows if there is a schematics for rtx 2080
СообщениеДобавлено: 13 мар 2021, 14:25
here is schematics for msi 2080
viewtopic.php?p=793856#p793856
BUT it doesn't contain pages (5 and 10) you need:(
СообщениеДобавлено: 13 мар 2021, 14:51
BUT it doesn't contain pages (5 and 10) you need:([/quote]
thanks for the link but unfortunately i cant view attachments due to low point
you mean the available schematic does not contain what i need? :(
i just want to know where this pin DQ1_A for FBIOC0 is located under the GPU can i get this from the available schematic.
thanks
link for the image
СообщениеДобавлено: 13 мар 2021, 14:54
Yes, exactly.
СообщениеДобавлено: 13 мар 2021, 15:51
uncledim писал(а):
Yes, exactly.
sorry for asking too much but do you know any other way to trace this pad
thanks
СообщениеДобавлено: 13 мар 2021, 18:44
Народ, неужто ни у кого полной схемы нет?
It seems this pad routes to GPU completely in internal pcb layers, so..
Just idea:
- find all other control/data gpu pads, connected to C0 mem chip pads
- on gpu measure several corresponding ball's R and/or Vf to/from ground ball
- search gpu "mem-C0" area for any wired, but not connected pad, check if corresponding gpu ball has same R/Vf as measured before
СообщениеДобавлено: 13 мар 2021, 20:32
Just idea:
Thanks i will try that
СообщениеДобавлено: 14 мар 2021, 13:21
Just idea:
Found the broken trace too bad i removed the gpu anyway in the image below is where the trace goes near screw hole of heatsink if any one faced same issue
Link for the image
СообщениеДобавлено: 14 мар 2021, 14:30
may be that help you
В этой теме нет новых непрочитанных сообщений. RTX 2080Ti - possible to use unused memory Pad?
Assassin
14 сен 2020, 20:06
Assassin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Converter Rtx 2070s im Rtx 2080
TheMArcos
15 ноя 2020, 23:09
nemos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Predator Triton 500 Predator (Wistron Ghibli 18803-SC) Change GPU rtx 2060 to rtx 2080?
pcexpert8
25 сен 2022, 23:08
pcexpert8 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell G3 3779 (LA-F611P) Self-Charging when charger is disconnected
в форуме Dell
abuholm
02 окт 2022, 06:46
abuholm Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 3090 MSI SuprimeX = Error RTX 3080 Memory Training fbpa_2 (0x00000008)
PT-AH
14 фев 2024, 18:05
zettabyte Перейти к последнему сообщению
Сейчас этот форум просматривают: 999, madking и гости: 89
