Текущее время: 19 май 2024, 04:15
Страница 1 из 1 [ Сообщений: 2 ] |
atamanul
Заголовок сообщения: Latitude d531, new problems . Добавлено: 01 дек 2012, 15:09 |
Зарегистрирован: 22 сен 2011, 14:31 Наличности на руках: 67.01
Сообщения: 7 Откуда: romania
Excuse translated by google. Hello!
2 faults curious. 1 - At startup, the fan runs continuously and fully. (Cooling system ok) possible faulty temperature sensor. 2 - SO loading very slowly, 10-15 minutes (SO is ok). CPU runs only la800mhz (from 1800MHz) and is loaded 100%. In Task Manager, taskmng.exe is very high 50% With I8kfangui monitoring, CPU temperature is 85 degrees (I can not monitor anything), CPU temperature is not real, not decrease not increase, real is 45-50 degrees.
Now curious> if I restart the system is running fine, except the fan and monitoring problems. Reported CPU temperature is still 85 degrees, unreal.
Regards Ata.
