Текущее время: 02 июн 2024, 16:53
 Заголовок сообщения: Asus GTX 1050Ti
СообщениеДобавлено: 20 авг 2020, 15:59
hello guys, I need to help on a gtx1050ti, the card does not have Vgpu voltage, follow the information in the images, I would like to know what is the red circle ci, because I believe it is the reason for the failure, there is no voltage present in none of your pins.
 Заголовок сообщения: Re: Asus GTX 1050Ti
СообщениеДобавлено: 22 авг 2020, 18:35
Can you read the marking on red circle IC? On photo it is unreadable.
Also which IC pins are 0OHm-to-ground?
The only IC that I saw on GPUs in TSOT23-8 without a choke/coil near is up1801 - "programmable high-precision reference voltage".
Вложение:
UP1801-reference-voltage.zip
Its top marking is N21. It was near PWM controller, but the card was another: high-power AMD 290/390.
There is a lot of TSOT23-8 voltage converters, but thaey are always near choke/coil
  • Top marking 08= Richtek RT7296F
  • Top marking ADP Monolithic Power MP1475
  • Top marking AMX Monolithic Power MP1475S
Is there a small choke/coil on the other side of the board near that ic?
СообщениеДобавлено: 22 авг 2020, 20:10
the code is: S74A ASU6C1
Pin 3 and 6 it has 0 ohm in relation to GND
There is not
СообщениеДобавлено: 22 авг 2020, 23:36
TheMArcos писал(а):
There is not
I mean on the *back* side of card. Sometimes thin chokes/coils are placed there.
СообщениеДобавлено: 23 авг 2020, 01:26
unfortunately there is no
СообщениеДобавлено: 14 апр 2021, 08:46
Hi, Team,
I will add one more question regarding same ASUS GTX1050Ti board.
I have dead VRAM voltage FBVDDQ formation chip. Its marking its "6X=4E A2B"
Its 10 pin chip possibly ground pin under it. I did not able to find it on google, aliexpress/ebay or China manufactures chip markings database.
Can anybody recognize this chip.
I did found on MSI 1050TI schematic similar chip uP1537 but pinout is not as per Asus PCB.
Thanks in advance.
СообщениеДобавлено: 14 апр 2021, 20:27
Found it. Its Richtek RT8125C/D
В этой теме нет новых непрочитанных сообщений. ищу сопротивления на ГПУ GTX 1050ti и GTX 1060
tiny0little
19 авг 2022, 18:49
Andrelyx Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS GTX 1050ti не выводит изображение.
serega1576
11 май 2018, 08:40
serega1576 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Bios для Asus GTX 1050ti Phoneix
Doom59
25 июн 2019, 13:42
Doom59 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus GTX 1050TI expedition включается раз в сутки
[ На страницу: 1, 2 ]
azizjon2191
30
3030
01 фев 2021, 21:33
azizjon2191 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus GTX 1050TI expedition нет питания ядра и памяти
TEPMuT234
06 мар 2021, 19:08
TEPMuT234 Перейти к последнему сообщению
Сейчас этот форум просматривают: Error_2022, Yandex [BOT] и гости: 19
