Текущее время: 22 май 2024, 14:23
 Заголовок сообщения: DV6-3127DX (DA0LX6MB6H1 Rev H UMA) No image, long initialization
СообщениеДобавлено: 05 апр 2021, 11:08
hello everyone,
this laptop came with broken chassis on the left side with ripped off lvds cable, repaired the chassis and replaced lvds cable, now it's turning on but with no display on screen nor vga port..
i don't have a post card, using a USB flash drive with a led indicator shows activity started after 25 seconds from switching on..
all voltages are there:
+3VPCU PL11 = 3.38V
+5VPCU PL8 = 5.09V
+VCORE PL9 & PL10 = 1.05 / 1.18V after 25 seconds
+VGACORE_IGPU PL13 = 1.04v
+1.05V_VTT PL3 = 1.05v
+1.5VSUS PL4 = 1.55v
+1.05V PL14 = 1.04v
+1.8V PQ37 = 1.79v
+0.75V_DDR_VTT = 0.77v
DDR_VTTREF = 0.77v
On CN2 connector (without screen):
pin1&2 +3VLCD_CON = appeared after 25 seconds, 3.33v
pin2&3 EDIDCLK & EDIDDATA = 3.33v with activity after 25 seconds
pin5 +3V = 3.33v
LVDS lines resistance = 126kohm
pin29 +5V = 5.08v
pin36 DPST_PWM = 0v (with and without screen) ?!
pin37 BLON_CON = 3.17v
pin39&40 +VIN_BLIGHT = 19.50v
tried replacing the screen, lvds cable, CPU, RAM... no difference
tried multiple BIOS & EC's with no avail, it's now on a BIOS cut from official website..
measured PCH_DPST_PWM voltage at R267 and it's not there, the resistance can't be measured it's like it's floating/not connected to anything :du_ma_et:
is it the PCH to blame ?
i've tried to blow on the PCH but still nothing...
can i remove R267 and give a supply +3v to DPST_PWM, from +3VLCD_CON for example ?
why is it taking that long to initialize ?
 Заголовок сообщения: Re: DV6-3127DX (DA0LX6MB6H1 Rev H UMA) No image, long initialization
СообщениеДобавлено: 07 апр 2021, 09:30
Check pu18 maybe
СообщениеДобавлено: 07 апр 2021, 12:25
DioTheVLAB писал(а):
Check pu18 maybe
pu18 is for DSC only, not installed on UMA boards..
I've removed R267 and injected 3v in DPST_PWM, the screen switched on but still no image..
replaced U15, still nothing..
surprisingly LVDS_VBG = 0v and LVDS_IBG = 0.37v, reflowing the PCH doesn't help
the board gives image through HDMI only, no VGA/LVDS so PCH is my only suspect.. any suggestions ?
СообщениеДобавлено: 05 май 2021, 03:57
this one need pch replacement and i don't have the tools, given without repair..
thank you..
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DV6-3127dx (DA0LX6MB6H1 LX6-7 ) Нет изображения на экране
Kim_555
29 май 2015, 22:56
Серый Лист Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MacBook Pro 13 (A1278 820-3115-B) Power button long press to turn on
в форуме Apple
bridx
26 фев 2017, 02:26
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv plasma sony KDL-46ex725 image with black stripe at the top of the image
eletmoraes
06 сен 2017, 17:25
eletmoraes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. tv LG 42PQ30R has image defect as attached image
в форуме PDP
eletmoraes
21 ноя 2019, 02:43
В этой теме нет новых непрочитанных сообщений. Hp Pavilion Dv6-3052Nr (DA0LX6MB6H1 REV:H) Enable Uma
Ruslan4321
22 авг 2016, 17:12
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 27
