Текущее время: 26 ноя 2026, 04:53
 Заголовок сообщения: Dell Inspiron (N5010 P10F001) Screen compatibility issues
СообщениеДобавлено: 07 май 2021, 00:25
Hello everyone,
Got this laptop with power and charging problems, got fixed and it started working perfectly except that lcd display has two vertical lines.
The laptop was given to the owner..
A week later it came back with a new problem, laptop powers on and gives 8 beeps - so the lcd screen was gone, i've tried cleaning lvds cable pins from both sides and both screen/motherboard connectors, the screen turned on again for a couple of times then off again with 8 beeps code..
Screen was replaced with a new one, it still beeping 8 times, lvds cable replaced... Still the same !
Tried tons of new screens from Samsung/LG... Nothing !
Some of the tested screens that didn't work:
LTN156AT02
LTN156AT05
LTN156AT10
LTN156AT24
LP156WH4
Original screen is LP156WH2(TL-AA)
Found a 100% working used LP156WH2(TL-E1), but it didn't work !
Grabbed another laptop from a different customer and found an identical LP156WH2(TL-AA) screen, tried it and it works :sh_ok:
Are those dells compatible with a specific screen or something is wrong with it ?
Bios update ?
 Заголовок сообщения: Re: Dell Inspiron (N5010 P10F001) Screen compatibility issues
СообщениеДобавлено: 07 май 2021, 07:16
GPU or VRAM malfunction.
AMD 216-0774007?
СообщениеДобавлено: 07 май 2021, 11:26
AMD 216-0774007?
Surprisingly, I hadn't noticed that the graphics driver isn't there, installed drivers and BOOM...a BSOD !
the customer didn't mention any problems with his graphics :ps_ih:
reflowing the chip didn't help so i've remade it to UMA, tested with a couple of screens and all of them worked perfectly..
thank you :co_ol:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell inspirion n5010 (n5010) Стартует ,не загружается черный экран
в форуме Dell
Sus256
25 июн 2017, 12:26
TSARIVAN Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell inspirion n5010 ((n5010)) север
в форуме Dell
Sus256
3665
21 апр 2018, 18:04
В этой теме нет новых непрочитанных сообщений. HP DV6-1270 (DAUT1AMB6D0 REV:D) chip compatibility
tarum2003
23 июн 2020, 16:16
tarum2003 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 645 G1 (Inventec 6050A2567101-MB-A03) Video Compatibility
xe_d_sono
03 дек 2023, 16:19
В этой теме нет новых непрочитанных сообщений. Dell Insprion 7567 (bbv00/10 la-d993p rev 1.0) No screen, black screen.
в форуме Dell
anarasgarli
22 фев 2018, 13:23
anarasgarli Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot] и гости: 42
