Текущее время: 25 ноя 2026, 11:09
 Страница 1 из 1 [ Сообщений: 17 ]
 Заголовок сообщения: Gigabyte GTX 1070 Mini memory voltage missing
СообщениеДобавлено: 12 июн 2021, 21:19
All resistances looking ok. All voltages correct except memory, it's 0v. Mosfets test ok. Replacing RT8816A controller didn't fix the problem. Enable voltage and VCC 5v present, Vref not present. Anyone had similar case?
 Заголовок сообщения: Re: Gigabyte GTX 1070 Mini memory voltage missing
СообщениеДобавлено: 15 июн 2021, 22:50
Have same problem not once. Bad contact of mosfets. Remove , wash and stay back.
СообщениеДобавлено: 16 июн 2021, 21:07
Will try and report the results. Thanks
СообщениеДобавлено: 18 июл 2021, 21:56
Reseated mosfets low and high side, everything remained the same. There was no discoloration beneath. :du_ma_et:
СообщениеДобавлено: 21 июл 2021, 12:28
After replacement of RT8816 for the second time got Vref refin 2v and 1.5v and output low 120mv. At least some improvement.
СообщениеДобавлено: 21 июл 2021, 21:52
Replaced original high side mosfet with 4c10N, voltage jumped to 3.5v OVP didn't do anything. Maybe low side mosfets were faulty too and couldn't short excessive voltage. Overall I did burn memory and gpu likely.
СообщениеДобавлено: 22 июл 2021, 02:45
What resistance do you have on the memory rail now and what resistance was before? 3.5V means that you did something bad with the voltage feedback. It can happen when a user spills a water on the resistor divider and if he has a bad luck he can kill everything on board.
СообщениеДобавлено: 26 июл 2021, 00:23
0 Ohm resistance on memory now, before was 100 ohm. I didn't touch any resistor, it was weird case from the beginning. Gigabyte sucks.
СообщениеДобавлено: 26 июл 2021, 08:35
Поднимите дроссель возможно короткое со стороны преобразователя. И вам могло немного повезти.
СообщениеДобавлено: 27 июл 2021, 20:14
There are already dead memory banks, damage is done, I did test a few removed.
СообщениеДобавлено: 27 июл 2021, 21:20
Это как у сапера одна ошибка и на небеса.
СообщениеДобавлено: 03 авг 2021, 17:57
This is not a Gigabyte's fault. I remember I killed one board by myself, you are not alone.
In Nvidia card 0 ohms on VRAM means probably also dead memory controller inside your GPU. Sad but true.
I had also a dead card, 1070 Ti if I remember, with Micron memories and a resistance was around 36 ohms. Very suspicious, but after an hour it degraded to 3 ohms and a high side mosfet had blown away. This time it was not my fault. The card was already dead. After I removed all memory chips the GPU still had 12 ohms on Vmem.
I removed GPU, replaced mosfet and all voltages are OK now :-)
СообщениеДобавлено: 04 авг 2021, 14:06
Иногда случаются чудеса!
СообщениеДобавлено: 15 сен 2021, 12:17
Out of curiosity I removed all 8 banks and inductor, resistance remained 0. Gpu dead :( lesson learned the hard way.
СообщениеДобавлено: 15 сен 2021, 18:27
Hi, can you help me? I have the same card with damaged resistor. Here is photo
download/file.php?id=174706
СообщениеДобавлено: 15 сен 2021, 19:15
It's 0 Ohm resistor (R556) in red circle.
СообщениеДобавлено: 15 сен 2021, 19:18
Thank you
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 Founders - no Memory Voltage, with external Memory-Power all fine
Assassin
23 авг 2020, 22:26
Assassin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 04:42
black7705 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. gigabyte gtx 1050 низкое напряжение на nvvdd - gigabyte gtx 1050 low voltage on nvvdd
TheMArcos
16 мар 2021, 15:28
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Msi gtx 1080ti trio missing bios chip voltage
frankmnld
2218
16 янв 2021, 20:13
frankmnld Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. evga gtx 750 ti no memory voltage
pcexpert8
1615
05 июл 2022, 09:12
pcexpert8 Перейти к последнему сообщению
Сейчас этот форум просматривают: Azat078, Frennis, Маньяк и гости: 116
