Текущее время: 21 ноя 2024, 19:05
TomaszR
Заголовок сообщения: Re: Asus DUAL-RX580-O8G does not accept drivers Добавлено: 18 авг 2021, 11:20 |
Зарегистрирован: 01 фев 2021, 18:45 Наличности на руках: 69.08
Сообщения: 47 Откуда: Poland
Pandemonium6 писал(а): Thank you very much for pointing me to this driver. There is a little bit better, they are unstable as they were but when I finally manage to start windows I have this kind of artifacts. This time the Windows did not start properly but it was this. What do you think? can you send me a picture via private message? because i can't open it here.
Pandemonium6
Заголовок сообщения: Re: Asus DUAL-RX580-O8G does not accept drivers Добавлено: 19 авг 2021, 08:16 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,139.72
Сообщения: 761 Откуда: Holand
The first card: CMD001:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppmode=perf -ppmempct=2 -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppsclkoffset=20 -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
Successfully restored DPM. Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
PowerPlay mode name "boot" mapped to numeric mode = 0
PowerPlay mode set to mode = 0
Mode = 0 : BOOT_STATE : LOW: ENG = 300 MHz, MEM = 300 MHz HIGH: ENG = 300 MHz, MEM = 300 MHz
SMC ucode version : 02.23.08.00 (0x02170800) MC ucode version : 2.20, 3
PowerPlay mode name "perf" mapped to numeric mode = 1
PowerPlay mode set to mode = 1
Mode = 1 : PERFORMANCE_MODE : LOW: ENG = 300 MHz, MEM = 300 MHz HIGH: ENG = 1360 MHz, MEM = 2040 MHz
SCLK offset applied successfully. CMD002:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
CMD003:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
Restoring DPM in boot mode, when sclk dpm is not enabled is not supported. Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
./tserverlite -cf=baco.cf -d=1 -q -tf=tserver.tmp.tf conf: -nw -log -eofe -d=gpu.* -linkspeed=3 tests: PM031.005 [status][Framework] PM031.005 [1] Pass 2517 msecs. Test Count: 1 [1;37;42mTotal Pass: 1[0;39;49m Total Fail: 0 Total Skip: 0 ============================================================ CMD004:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppmode=perf -ppmempct=2 -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppsclkoffset=20 -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
SMC ucode version : 00.00.00 (0x000000) MC ucode version : 2.20, 3
SCLK offset applied successfully. CMD005:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
CMD006:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppmode=perf -ppmempct=2 -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppsclkoffset=20 -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
SCLK offset applied successfully. CMD007:./agt -fancontrol=1 -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
Fan Speed Level : High CMD008:./agt -switchmclkinvblank=off -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
./tserverlite -autodpmtog=sclk,mclk,30,0 -pm_enable_logging=0 -cf=tserver.cf -tf=tserver.tmp.tf conf: -pr -pi -nw -log -eofe -d=gpu.* -linkspeed=3 -chkedc=all -edcthresh=50 -defaultedc tests: STD004.001 AK321.005 [error][GFX] S3DTest: CRC error on frame 00000: Expected 0x666f47f Actual 0xc15372d3 [error][GFX] S3DTest: CRC error on frame 00001: Expected 0x2b8da3fd Actual 0xab8d4e11 [status][Framework] STD004.001 [1] Fail 7630 msecs. [1;37;41m[error][Framework] Done executing STD004.001 Failed[0;39;49m [error][Framework] errorid: - STD004.001PA Test Count: 1 Total Pass: 0 [1;37;41mTotal Fail: 1[0;39;49m Total Skip: 0 ============================================================ [1;37;41m _/_/_/_/ _/_/ _/_/_/ _/ [0m [1;37;41m _/ _/ _/ _/ _/ [0m [1;37;41m _/_/_/ _/_/_/_/ _/ _/ [0m [1;37;41m _/ _/ _/ _/ _/ [0m [1;37;41m_/ _/ _/ _/_/_/ _/_/_/_/ [0m
Posted after 1 minute 10 seconds:The second card: CMD001:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppmode=perf -ppmempct=2 -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppsclkoffset=20 -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
./tserverlite -cf=baco.cf -d=1 -q -tf=tserver.tmp.tf conf: -nw -log -eofe -d=gpu.* -linkspeed=3 tests: PM031.005 [status][Framework] PM031.005 [1] Pass 2533 msecs. Test Count: 1 [1;37;42mTotal Pass: 1[0;39;49m Total Fail: 0 Total Skip: 0 ============================================================ CMD004:./agt -ppdpmrestore=sclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=mclk -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=vce -i=PCI:0000:02:00.0 ./agt -ppdpmrestore=uvd -i=PCI:0000:02:00.0 ./agt -ppmode=boot -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppmode=perf -ppmempct=2 -i=PCI:0000:02:00.0 ./agt -ppreadreg=ppreg.dat -ppsclkoffset=20 -i=PCI:0000:02:00.0 Warning: PCI domain number detected and ignored. AMD GPU TOOL version 2.3.42.89, Copyright (c) 2017 Advanced Micro Devices, Inc.
************************************************************ I had to STOP the tserver because nothing was going on... ... Error: child died with signal 2, without coredump ************************************************************ ============================================================ [1;37;41m _/_/_/_/ _/_/ _/_/_/ _/ [0m [1;37;41m _/ _/ _/ _/ _/ [0m [1;37;41m _/_/_/ _/_/_/_/ _/ _/ [0m [1;37;41m _/ _/ _/ _/ _/ [0m [1;37;41m_/ _/ _/ _/_/_/ _/_/_/_/ [0m
TomaszR
Заголовок сообщения: Re: Asus DUAL-RX580-O8G does not accept drivers Добавлено: 20 авг 2021, 14:22 |
Personally i don't think that problem will be with ram controller, if all your test are passed correct then problem might be with GPU. But from your previous messages i seen that both tests was failed, so there should be some information about error Can you send me a picture of artefacts via private message? because i dont have 15 posts to check your pictures.
Pandemonium6
Заголовок сообщения: Re: Asus DUAL-RX580-O8G does not accept drivers Добавлено: 21 авг 2021, 08:19 |
I have sent these jpegs to PM. I analyzed these cards again. They are very strange twins.
1. Number one - Linux cli works - boardtest=memfa C0 VRAM has 1 eror ".......... ......... ...1.... ........." always the same - HDMI connected directly to the card -> artifacts in memfa - boardtest=quickmfg goes to the certain point and stays there - No need to power cycle in order to issue another command
2. Number two - Linux cli works - boardtest=memfa always PASS, memory is good even at 2000MHz - HDMI connected directly to the card gives PASS in memfa, this test goes perfectly - boardtest=quickmfg goes to the certain point and hangs the card - This card requires power cycle after boardtest=quickmfg, only 5V is present and small LDO gives 3.3V all other voltages are gone. - I discovered that when I want to increase system clock from 300 to a higher value it immediately disables all voltages but I can increase memory clock without problems and run memfa test. This card does not react on commands for setting the fan speed 0,1,2, and 3. No reaction.
They both look good under thermal cam, no point heating or border heating of the GPU. All VRMs of the GPU are functional, 7-8% of duty cycle on each phase 0.900V.
PT-AH
Заголовок сообщения: Re: Asus DUAL-RX580-O8G does not accept drivers Добавлено: 23 май 2022, 03:05 |
Сообщения: 97 Откуда: England
Pandemonium6 писал(а): Should I say both GPUs are dead? Do you have a tip what to do next? Hello Look, this is really from the memories: when entering windows through another gpu everything is flawless. As soon as you use gpu-z, it will read your entire GPU. but if an error occurs only in one bit, it will cause confusion on both boards. then the pc freezes immediately. It's from memory. What software do you use to test the memories? I use linux for all of them up to the RX 580. always impeccable.
