Текущее время: 08 июл 2024, 07:20
 Страница 35 из 56 [ Сообщений: 1661 ]  На страницу Пред.  1 ... 32, 33, 34, 35, 36, 37, 38 ... 56  След.
 Заголовок сообщения: Re: need some help for ati cards with memory errors for making script
СообщениеДобавлено: 20 авг 2021, 12:20
Hello for those interested here it is 32gb image from my test hdd : https://mega.nz/file/E1h1HS6a#l3u5OOCgx ... sTc_rC9Rag
restore it with diskgenius
it has last dmgg and mats ans most of tserver versions; if you need to add more version tserver or mats just copy them in the same folder near the existing ones with diskgenius
if is not booting use restore boot with the boot-repair-disk-64bit.iso (you can put this image with Rufus on a usb drive ) https://sourceforge.net/projects/boot-repair-cd/
if you use restore boot open your hdd/usb with diskgenius and you need to copy grub.cfg to /boot/grub/ right click on grub.cfg -delete file directly then drag and drop the attached grub.cfg in that place and copy it
grub.zip
unzip first :)
now you can boot
-1 is for dmgg.py and tserver and it is working as before; example: python3 ./dmgg.py c0000000 1 16 300 (300 is optional and is frequency )
-2 is for mats . it will start test with 455.127 and 4MB but you can use 'ls' command and then select the version you want; for mats you will boot directly in 455.127 and report.txt will open after 3 second after the test is done
if for some unknown reason you want to go in graphical mode for linux first option after you enter in console mode just type 'startx' and wait
there is also a user called sh and its password is 1 ;you can log in it opening second console (alt f2) and log in
Последний раз редактировалось ilie321 20 авг 2021, 14:51, всего редактировалось 2 раз(а).
СообщениеДобавлено: 20 авг 2021, 13:47
ilie321 писал(а):
Hello for those interested here it is 32gb image from my test hdd :https://mega.nz/file/wkxCDQKT#_xtCfmVK3zRJ983mQjmgzViQ48l0G-dUZmOdd3K7yt0
Ссылка ведет на файл grub.cfg, не образ. Поправьте пожалуйста.
---------- Добавлено спустя 37 минут 45 секунд: ----------
hashwood писал(а):
Я получаю это сообщение, что не так?
Я уже отписывался по такому сообщению, вкратце была не допаяна банка, то есть неконтакт чипа с памятью может такое сообщение выдавать.
Ремонт ноутбуков и видеокарт в Самаре. 8 (906) 125 02 17
СообщениеДобавлено: 20 авг 2021, 14:51
thanks ; done
СообщениеДобавлено: 21 авг 2021, 01:16
ilie321 писал(а):
thanks ; done
there is a test for rx6800 in your image ?
СообщениеДобавлено: 21 авг 2021, 12:09
чем можна память протестить на RX6800 - в последнем китайском образе на вкладке написано что тестит но реально даже папки под нее нет из папки RX57009 не тестит - ошибка Navi видел в ютубе rx 5500 тестили dmgg.py но с rx6800 у меня не получилось - может посвежее надо dmgg.py ? ну или может где tserver такой есть ? :-)
СообщениеДобавлено: 23 авг 2021, 16:12
привет всем ,перерыл всю тему .... не могу найти ссылку на 70 гиговую полную версию для амд карт .. нужна версия с поддержкой R7+ R9
СообщениеДобавлено: 23 авг 2021, 16:16
найди в ютубе канал vik-on таб будут ссылки на гугл диск там было
https://drive.google.com/drive/folders/ ... mHDA1rztAb
СообщениеДобавлено: 23 авг 2021, 16:28
Воробей писал(а):
nope, my friend and also some strangers prooved working.
It does work from the mechanical HDD but I can't boot it from the SSD. I used the same SSD before with your images and it worked. I discovered that many files inside the image have wrong permissions, for example they have +x (executable). It looks like you copied many files from Windows or something like a FAT file system.
Maybe this is the problem?
СообщениеДобавлено: 24 авг 2021, 14:27
эх .. там только начиная с 470 и выше.... для старых ничего нет ..
нужно для r9 tahiti... есть у кого ссылка ?
или может что-то с этим имиджем надо сделать ?
СообщениеДобавлено: 24 авг 2021, 17:43
Тебе нужно искать 2.pmf и 5.pmf.
На ТServer тоже есть тесты на старые карты
СообщениеДобавлено: 25 авг 2021, 09:57
Воробей писал(а):
hmm... i'd say try to tweak voltages, also, are they fine ? like if memory controller gets lower power on lower cloks, but way less then required
there is a dedicaded phase for memory controller inside gpu [it's often located near pci-e slot], try to play with it. might give some results
the memory controller is a IR35201 and I can measure Vmem_ctr between 900mV at min load to 950mV at max load while in the BIOS it should be between 750mV@300MHz to 950mV@2000MHz
I know that with Polaris the minimum Vmem_ctr value has to be always less than the Vcore, but it isn't in my case so this could be the problem.
To check it I increased the Vcore at low frequencies to be at least 900mV (but not at 300MHz that cannot be changed and still has to remain at 750mV) but the card still doesn't work properly. I will try to change the BIOS to have always at least 900mV on Vcore
The VRMtool would have been usefull here but it is not compatible with the IR35201
I did another thread because here we are maybe out of thema viewtopic.php?f=48&t=117391
СообщениеДобавлено: 26 авг 2021, 15:15
just chmodded all in root... i'm so dumb LoL
nneeeet
---------- Добавлено спустя 1 минуту 43 секунды: ----------
dmgg?
СообщениеДобавлено: 26 авг 2021, 19:57
Hehe there is something what prevents loading system from a certain media. It was good before. The image does not have afree space - almost no free space. You could remove the whole xwindows subsystem and some other servers which are not needed. You will save some GB of space.
But remember, the UBUNTU is from Canonical with embedded spyware and "cooperation" with Amazon and others. Just have it in mind. Use pure debian or any other light weight linux such 0.5GB in size.
No need to put the whole system on the pendrive.
СообщениеДобавлено: 28 авг 2021, 18:58
maybe one day will, i'm now busy and lazy
СообщениеДобавлено: 28 авг 2021, 21:36
Could you please make tar.gz and post directories for R9 and R7 cards without uploading the whole images? The lowest model is rx480 but I need older Radeons too.
СообщениеДобавлено: 29 авг 2021, 23:44
Hello guys, when I try to test my rx 470 in tserver, I get this, any help? I tried ./agt - mem=1000 but it doesn't work. All I get is: "can't find mem= value"
Please help
СообщениеДобавлено: 30 авг 2021, 00:58
hAdy994 писал(а):
./agt - mem=1000
неправильно!,
должно быть так:
./agt -mem=1000
и только потом уже вводить команды для tserver
СообщениеДобавлено: 30 авг 2021, 01:17
I'm sorry, I forgot to correct that, I did indeed try ./agt -mem=1000 but that also didn't help!
СообщениеДобавлено: 30 авг 2021, 02:07
./agt -h
It will give you the list of sets of commands. And then you must select what you want to do. You have voltage commands, clock commands and so on.
./agt command (without -) will list all variables inside this command
so to use it later:
./agt -command variable1=value1 variable2=value2 ..........
СообщениеДобавлено: 30 авг 2021, 02:29
./agt -h
I tried ./agt -mem=1000 and it still didn't work!
even with ./agt -mem=1000, running ./tserver -boardtest=memfa gives me the same error "can't find mem= value"
Anyone got a backup link for this file? Mega.nz requires a subscription just to download the file otherwise I have to wait 1 hour between every 4GB of data downloaded! Google drive does it for free lol!
Posted after 2 hours 39 minutes 28 seconds:
Can you please also upload grub.zip to google drive? I need 15 messages...
СообщениеДобавлено: 31 авг 2021, 02:22
Привет всем
Развернул диск джениусом на 500-гиговый диск все пять разделов как у китайца в видео
RX 580-ю хотел попробовать тестануть. 1150 сокет.
в DOS нормально заходит
в 4 pmf ошибка 22, партишн что то не так, загрузчик по ходу что то там.
К линуксу с почтением, но не на одной волне.
Чего, парни, не хватает ?
Бут секьюрити в биос отключил...
СообщениеДобавлено: 31 авг 2021, 23:07
посмотри когда китаец разбивает веник на 5 разделов он ставит галочки на 1.2.3 раздел может поможет я сразу не заметил
СообщениеДобавлено: 01 сен 2021, 00:22
почитайте выше в этом топике - пробовать варианты - если вкратце - хард пробовать через сата через юсб мать пробовать в режиме легаси если позволяет у меня на H170 pro Gaming та же петрушка - пункт 4 не работает - но подключил хард просто по сата к старой амд плате на каком то атлоне и ддр3 без всякого юефи - все заработало
и да матс 455 с возможностью тестить модсом ну с голдами - вытащили из этого же образа и выложили - кидайте на флеху и пользуйтесь как душе угодно карты rx5500 rx 5700 все жалуются что не тестит rx6800 в строке написано а папки даже нет и из папки 5700 не тестит мне вообще больше нравится тест выложенный у VIK-ON везде едет из папки 590 ну нет старых карточек - типа r9 290 r9 390 280 380 - вот это из этого образа можно и юзать или ваще выдрать эти папки и всунуть в хард от VIK-ON - в общем внимательно перечитайте инфу из данной темы с момента выкладки crimfell данного образа - и уверен решите все свои проблемы
СообщениеДобавлено: 02 сен 2021, 05:01
Guys I am getting this error while testing rx 580!
I don't get this error while testing rx 470!!
Exception during attempt to execute test: TcoreSilicontarget: Failed to load ME microcode using toollib on Tonga/Ellesmere RF
Please help!
СообщениеДобавлено: 02 сен 2021, 18:35
Видеокарта на RX580. На экране в Фурмарке артефакты. Тесты памяти проходят нормально. Графические тесты (S3DTest), например STD004.001 выдаёт ошибку. Подскажите, знающие, это чипу конец?
Флюс Ersa 0FMKANC32 (SW32) https://vlab.su/viewtopic.php?f=109&t=136977
СообщениеДобавлено: 02 сен 2021, 18:58
Тестировалось через райзер?
как мне объяснял всему уважаемый @GalkinVV - цитирую "тесты gen3 (или как вы пишите S3DTest) - это тесты шины PCIe в режиме 3.0. Они могут не проходить по куче факторов, типа "в материнке принудительно выставлено 2.0" или "слишком длинный райзер" и т.п.
Если эксплуатироавть в режиме PCIe 1.1 или PCIe 2.0 - то оно может спокойно не проходить"
Артефакты какого рода? Хотя бы фото прицепили!
ломанные кривые - Это ГПУ.
полоски - квадратики - можно побороться....
Частоты повышали?
СообщениеДобавлено: 02 сен 2021, 21:37
Напрямую в плату карта вставлена. Плата какая то АМ2, так что шина там 2.0 не выше. И тесты эти именно 3D тесты, да и картинка соответствующая выводится, типа игрушки.
Про фото не подумал может позже сделаю. Ломанные кривые.
СообщениеДобавлено: 06 сен 2021, 13:55
всем привет, тест ак600.001 по всем банкам ошибки, подскажите что именно тестируется этим тестом?
СообщениеДобавлено: 07 сен 2021, 10:47
Gas_man писал(а):
Tell me, those in the know, is this the end of the chip?
I have a lot of such cards im my inventory. Last week I repaired only 3 cards. All other cards were garbage. Even yesterday I had a card with faulty 1 data line of the C0 memory chip on rx580. I replaced the memory and no change, the same bit of the data line reported by a tserver.
СообщениеДобавлено: 07 сен 2021, 12:58
Gas_man писал(а):
Since this topic is devoted to diagnosing banks (chips) of GDDR5 memory for video cards.
I decided to post here information that helps me understand the state of the dismantled memory from donors.
Measurements for SAMSUNG cans were made by me.
Image resized to 97% of its original size [360 x 198]
The measurements for the HYNIX cans were taken from the telegram channels from MIKHAI (like from @ Mihey3)
Image resized to 97% of its original size [360 x 223]
These measurements were taken from donors, they launched the card and kept the frequencies in the flesh up to 1980 MHz.
I took measurements "Voltage drops - continuity" "Black probe" - "-" "Red probe" - "+"
Who has any comments and clarifications.
I ask you to make the indicated measurements on new memory chips and post the values.
K4G80325FB-HC22 there is 12.5 - 13.5 kOhm on VDDQ
in diode mode new chip has 200 on VDDQ and 82 on VDD
used chip has 196 on VDDQ and 78 on VDD
В этой теме нет новых непрочитанных сообщений. Need memory test software/script for RX 6900XT ASROCK
[ На страницу: 1, 2, 3, 4 ]
thegregin
94
19529
01 июл 2024, 23:03
kaare123 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help help Help memory samsung detect micron (domate)
PT-AH
02 ноя 2022, 14:43
PT-AH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. memory test software/script for RX 6950XT
Vdfm
27 ноя 2023, 16:00
dapove15662 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX3080/3090 memory training errors вопрос
darker123
18
2680
05 янв 2024, 09:11
tonycstech Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. nvidia DTX970 gaming 4g vga cards help
serwanjaf7
22 май 2020, 06:52
vov4ik_il Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 7
cron
