Текущее время: 21 ноя 2024, 21:11
 Заголовок сообщения: Zotac GTX 960 2GB- 6pin PCIE Power not recognized
СообщениеДобавлено: 25 сен 2021, 19:32
Hi all!
A friend of mine brought me a defective Zotac GTX 960 with a failing power detection.
Even though the 6 pin PCIe power cable is plugged in, the card says "Plugin PCIe power cable and reboot".
Since I have no schematics it is hard to find out the NVVDD_PGOOD trace.
I checked if the Controller (NCP81174) sends a Power good signal and the signal VR_RDY at pin 3 is high. So I assume the controller is not sending a bad signal (?).
As always I appreciate your help! :-)
 Заголовок сообщения: Re: Zotac GTX 960 2GB- 6pin PCIE Power not recognized
СообщениеДобавлено: 28 сен 2021, 22:59
OK. I found out that I was measuring rubbish. Since NVVDD has nothing to do with the issue I have posted here.
I found a schematic that at least partly is common with my gtx 960.
But I have no idea to start my analysis.
Is LOWPWR_Mode high if that issue occurs? Is it GPIO12_LOW_PERF?
Are there any tutorials out there where I can start to learn what means what on Nvidia cards?
From my IT understandings would a high signal always be "true" = 1. But I am no electrician.
Would be glad if someone could tell me where to start my journey :-)
Posted after 2 hours 13 minutes 18 seconds:
Can someone tell me the values of R516 and R501? I cant measure their value and there is nothing printed on them (?) ...
СообщениеДобавлено: 29 сен 2021, 01:20
thrinrot
Look at here:
viewtopic.php?p=887380#p887380
Use an online translator :a_g_a:
现在的也越来越难修啊,生意真是不好做啊!
© Конфуций из Шэньчжэня
 Заголовок сообщения: Re: Zotac GTX 960 2GB- 6pin PCIE Power not recognized  [РЕШЕНО]
СообщениеДобавлено: 01 окт 2021, 17:31
Thanks for your advice. Found out that both resistors R516 and R501 were defective.
After changing them to 2.7k Ohm (R501) and 10k Ohm (R516) Resistors, the card is back to live again :-)
В этой теме нет новых непрочитанных сообщений. Zotac GTX 970 Dual пишет "please power down and connect the pcie power cable for this graphics card"
pccraster
15
739
16 окт 2024, 14:23
Raptor_3000 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. 1050Ti KFA2 LP works/работает in PCIE x1 but not/но нет in PCIE X16 (X8)
cxav
24 фев 2023, 20:44
karlan Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Viewsonic VG2030WM does not recognized DVI & VGA inputs
в форуме ViewSonic
latitude
28 ноя 2015, 15:53
hdd8181 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Mscbook A1278 (820-3115B) Battery not recognized
в форуме Apple
abuholm
14
5753
19 июл 2015, 14:38
dupahuj Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Inspiron 15 (3558) (Wistron Iris Bsw/Dbm) Audio Codec not recognized in Bios
в форуме Dell
abuholm
06 окт 2016, 16:28
abuholm Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot], madking и гости: 64
